Question about Husqvarna Viking 1
Hi, I lower the presser foot and touch the foot control, but unfortunately, the machine gives a message that the presser foot is not lowered, although it is. I cannot do a thing now. How can I rectify it? Thanks.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Does your machine have a two stage presser foot position?
Posted on Oct 19, 2013
Testimonial: "I don't think so."
5 Suggested Answers
  • 192 Answers
SOURCE: Presser foot wont raise and lower
Does the presser foot move at all when the machine is first turned on?
Do the needle and feed teeth calibrate when the machine is first turned on?
You probably need to locate your nearest authorized repair center.
Posted on Jun 12, 2008
  • 371 Answers
SOURCE: pressure foot too high cannot be lowered
sounds like the pressure foot lifter is stuck. Usually the height of the pressure foot is a manual adjustment done by a service technician. Suggest that it be serviced by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
RichSew
  • 194 Answers
SOURCE: presser foot control -- Viking Husqvarna #1 sewing machine
There is a presser foot pressure dial on the left end of the machine, make sure it is on 3 or higher.
Posted on May 27, 2010
Testimonial: "Thanks--Don't know how the wheel was moved, but that fixed the problem. Now if I could only find the owner's manual!! "
sewinsnap
  • 135 Answers
SOURCE: presser foot problem
there is a problem with the computer in your machine
Posted on Aug 12, 2010
In the middle of embroidery how to change Presser foot height on the epic husqvanna
Touch the presser foot up button once to raise the presser foot. Touch again and the presser foot will raise to extra lift position, and the feed teeth will be automatically
lowered to make it easier to get heavy fabric under the presser foot.In embroidery mode, the extra lift makes it easier to insert or remove the hoop.
Here is a link to your manual: http://www.husqvarnaviking.com/SiteMedia/Products/Machines/DESIGNER-EPIC/Manual/Designer_epic_manual_EN.pdf
May 01, 2018 | Sewing Machines
Error message foot too high. To correct this, it is necessary to restart the machine. Unless it is impossible to continue sewing.What is the problem?
Try taking your presser foot off and lower the presser foot lever. Does the error code go away? The machine won't sew without the presser foot to hold the fabric down, but without threading the needle, will the machine run without the presser foot? Now try the standard presser foot (usually J ) and if you get the error code then the sensor at the top of the presser foot assembly is out of adjustment. Without knowing more about your machine this is all I can suggest.
Good luck,
Bob
May 30, 2017 | Sewing Machines
Is there a larger foot rest or a way to lower and extend foot rest
Foot rest? Are you referring to the foot control unit or a presser foot? If it is presser foot, most likely you do not have the correct presser foot for your machine. Search the internet for the "make model presser foot" (substitute make & model with your machine make & model). There are basically 3 presser foot styles--low, high & slant. They are not interchangeable.
If you are talking about the foot control, sometimes you can find other foot control units for your machine, possibly even generic units.
Dec 28, 2016 | Sewing Machines
When trying to embroider I keep getting a Lower the Presser foot message when it is already lowered!!
You don't state the brand/model of your machine. If it is computerized model, the machine is not recognizing the presser foot's position. If there is a glass eye on the foot, make sure it is clean of any dust, lint, or fingerprints.
Jul 19, 2015 | Sewing Machines
What should I do when error message E1 hapend
An "E1" message appears on the panel. Description: The foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) and the reverse/reinforcement stitch button was pressed while the presser foot is raised.
Lower the presser foot lever before continuing the operation.
Mar 02, 2010 | Brother CS-6000
Presser foot 7 lever on Pfaff 1471
You may not be using the correct presser foot for your machine.
Sewing Machine Feet
You may be using a low shank when your machine needs a high shank.
May 12, 2017 | Kenmore 15218 Mechanical Sewing Machine
Presser foot lever
Hi and welcome to FixYa,
Initially, pls try a reset. This could be accomplish by unplugging the SE-270D from the mains. After an extended period, plug back in and power on normally. In some variations, there would be a reset button/key/switch.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 24, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
91 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
