Question about Texas Instruments TI-83 Plus Calculator
Missing value table y - Texas Instruments TI-83 Plus Calculator
  • Texas Instru... Master
  • 7,993 Answers
You are not being clear so I will have to guess what you mean.
If you press the Table key without entering a function in the Y= editor, you will only generate the x-values but not the y-values. The calculator has no way of knowing what function you have in mind.
Posted on Oct 17, 2013
Performance 254mm .FMTC1500TK
Contact the manufacture or a local True Value hardware
Jan 02, 2014 | Saws
The Y-values listing is missing under the [2nd] graph button. Only the
If you want the table to be generated, you must use the table feature. You can generate a table also after you draw (graph) a function.
Enter a function in the Y= editor, then press GRAPH or SHIFT GRAPH (TABLE). If you press GRAPH, you will see a graph. If you want the table and are not interested in the graph, press SHIFT TABLE.
Mar 25, 2012 | Texas Instruments TI-83 Plus Calculator
In Sequence mode, the U(n) value is missing from the table on a TI-83 plus. How do I get it back?
If you erase the second column of a table (whatever your reasons) you can regenerate it by reinserting the function in the Y= editor.
Enter the function then press [2nd][GRAPH] to regenerate the table.
Sep 09, 2011 | Texas Instruments TI-84 Plus Calculator
I have a TI 84 plus and when I hit second graph it goes to table where I can insert y values. by accident erased my Y values and only have the x column. Can I get the Y values back?
If you have a function that generated the table, you can recreate both columns again. Just enter the function, then press SHIFT GRAPH. The table will be regenerated.
For values you entered yourself there is no way to recover them. You will have to reenter them again.
Sep 02, 2011 | Texas Instruments TI-84 Plus Calculator
Configure.csv
CSV means:
A comma-separated values or character-separated values (CSV) file is a simple text format for a database table. Each record in the table is one line of the text file. Each field value of a record is separated from the next by a character (typically a comma, but some European countries use a semi-colon as a value separator instead). Implementations of CSV can often handle field values with embedded line breaks or separator characters by using quotation marks or escape sequences. CSV is a simple file format that is widely supported, so it is often used to move tabular data between different computer programs that support the format. For example, a CSV file might be used to transfer information from a database program to a spreadsheet.
Dec 27, 2010 | Acer TravelMate 2300 Notebook
Plz tell me Sir/Madam. what is Hlookup And give me example
Hi Geetad11
This is Horizontal lookup , used to look up value in a 2 dimensional table .It searches for a value in the top row of a table or an array of values, and then returns a value in the same column from a row you specify in the table or array. Use HLOOKUP when your comparison values are located in a row across the top of a table of data, and you want to look down a specified number of rows. The H in HLOOKUP stands for "Horizontal."
Formulae Syntax
HLOOKUP(lookup_value,table_array,row_index_num,range_lookup)
Lookup_value is the value to be found in the first row of the table. Lookup_value can be a value, a reference, or a text string.
Table_array is a table of information in which data is looked up. Use a reference to a range or a range name.
  • The values in the first row of table_array can be text, numbers, or logical values.
  • If range_lookup is TRUE, the values in the first row of table_array must be placed in ascending order: ...-2, -1, 0, 1, 2,... , A-Z, FALSE, TRUE; otherwise, HLOOKUP may not give the correct value. If range_lookup is FALSE, table_array does not need to be sorted.
  • Uppercase and lowercase text are equivalent.
  • You can put values in ascending order, left to right, by selecting the values and then clicking Sort on the Data menu. Click Options, click Sort left to right, and then click OK. Under Sort by, click the row in the list, and then click Ascending.
Row_index_num is the row number in table_array from which the matching value will be returned. A row_index_num of 1 returns the first row value in table_array, a row_index_num of 2 returns the second row value in table_array, and so on. If row_index_num is less than 1, HLOOKUP returns the #VALUE! error value; if row_index_num is greater than the number of rows on table_array, HLOOKUP returns the #REF! error value.
Range_lookup is a logical value that specifies whether you want HLOOKUP to find an exact match or an approximate match. If TRUE or omitted, an approximate match is returned. In other words, if an exact match is not found, the next largest value that is less than lookup_value is returned. If FALSE, HLOOKUP will find an exact match. If one is not found, the error value #N/A is returned.
Remarks
  • If HLOOKUP can't find lookup_value, and range_lookup is TRUE, it uses the largest value that is less than lookup_value.
  • If lookup_value is smaller than the smallest value in the first row of table_array, HLOOKUP returns the #N/A error value.
Example
The example may be easier to understand if you copy it to a blank worksheet.ramsoft.jpg
Oct 06, 2010 | Microsoft Excel for PC
Missing Y value in Table function
Have you tried resetting your claculator? then turn diagnostics on and see if that fixes it
Mar 12, 2010 | Texas Instruments TI-83 Plus Calculator
Trying to install office 2007 but keep getting error code 1606 cannot find network location %APPDATA%. What can I do to fix this?
To resolve this issue, follow these steps:
  1. Click Start, click Run, type Regedit.exe, and then click OK.
  2. Locate and then click the following registry subkey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  3. In the right pane, verify that the values are the same as the values in the following table. If each value matches the table, go to step 7. For Windows XP and for Windows Server 2003, see the following table. Collapse this tableExpand this table Value name Type Value data AppData REG_EXPAND_SZ %USERPROFILE%\Application Data Cache REG_EXPAND_SZ %USERPROFILE%\Local Settings\Temporary Internet Files Cookies REG_EXPAND_SZ %USERPROFILE%\Cookies Desktop REG_EXPAND_SZ %USERPROFILE%\Desktop Favorites REG_EXPAND_SZ %USERPROFILE%\Favorites History REG_EXPAND_SZ %USERPROFILE%\Local Settings\History LocalAppData REG_EXPAND_SZ %USERPROFILE%\Local Settings\Application Data Local Settings REG_EXPAND_SZ %USERPROFILE%\Local Settings My Pictures REG_EXPAND_SZ %USERPROFILE%\My Documents\My Pictures NetHood REG_EXPAND_SZ %USERPROFILE%\NetHood Personal REG_EXPAND_SZ %USERPROFILE%\My Documents PrintHood REG_EXPAND_SZ %USERPROFILE%\PrintHood Programs REG_EXPAND_SZ %USERPROFILE%\Start Menu\Programs Recent REG_EXPAND_SZ %USERPROFILE%\Recent SendTo REG_EXPAND_SZ %USERPROFILE%\SendTo Start Menu REG_EXPAND_SZ %USERPROFILE%\Start Menu Startup REG_EXPAND_SZ %USERPROFILE%\Start Menu\programs\Startup Templates REG_EXPAND_SZ %USERPROFILE%\TemplatesFor Windows Vista, see the following table. Collapse this tableExpand this table Value name Type Value data {374DE290-123F-4565-9164-39C4925E467B} REG_EXPAND_SZ %USERPROFILE%\Downloads AppData REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming Cache REG_EXPAND_SZ %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files Cookies REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies Desktop REG_EXPAND_SZ %USERPROFILE%\Desktop Favorites REG_EXPAND_SZ %USERPROFILE%\Favorites History REG_EXPAND_SZ %USERPROFILE%\AppData\Local\Microsoft\Windows\History LocalAppData REG_EXPAND_SZ %USERPROFILE%\AppData\Local My Pictures REG_EXPAND_SZ %USERPROFILE%\Pictures My Music REG_EXPAND_SZ %USERPROFILE%\Music My Video REG_EXPAND_SZ %USERPROFILE%\Videos NetHood REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts Personal REG_EXPAND_SZ %USERPROFILE%\PrintHood PrintHood REG_EXPAND_SZ %USERPROFILE%\Documents Programs REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs Recent REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent SendTo REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo Start Menu REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
    Startup REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup Templates REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
  4. If any Name, Type, or Value does not match the table in step 3, right-click the Value name, and then click Delete.
  5. In the left pane, right-click User Shell Folders, point to New, click Expandable String Value, type the Name value that you want from the table in step 3, and then press ENTER.
  6. Right-click the value that you created in step 5, click Modify, type the value in the Value data box for the Value name, and then click OK.
  7. Locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  8. In the right pane, verify that the values are the same as the values in the following table. If each value matches the table, go to step 12. Collapse this tableExpand this table Value name Type Value data Common AppData REG_EXPAND_SZ %ALLUSERSPROFILE%\Application Data Common Desktop REG_EXPAND_SZ %ALLUSERSPROFILE%\Desktop Common Documents REG_EXPAND_SZ %ALLUSERSPROFILE%\Documents Common Favorites REG_EXPAND_SZ %ALLUSERSPROFILE%\Favorites Common Programs REG_EXPAND_SZ %ALLUSERSPROFILE%\Start Menu\Programs Common Start Menu REG_EXPAND_SZ %ALLUSERSPROFILE%\Start menu Common Startup REG_EXPAND_SZ %ALLUSERSPROFILE%\Start Menu\Programs\Startup Common templates REG_EXPAND_SZ %ALLUSERSPROFILE%\Templates
  9. If any Name, Type, or Value does not match the table in step 8, right-click the Value name, and then click Delete.
  10. In the left pane, right-click User Shell Folders, point to New, click Expandable String Value, type the Name value that you want from the table in step 8, and then press ENTER.
  11. Right-click the value that you created in step 10, click Modify, type the value in the Value data box for the Value name, and then click OK.
  12. Exit Registry Editor, and then restart the computer.
Sep 04, 2009 | Microsoft Windows Vista Home Premium with...
Visual basic program for binary search technique
This sounds like "homework".
A binary-search requires an "ordered" table of values.
Sort your values into the proper order.
LET TOP=1; * Point to first element in the table.
LET BOT=1000; * Point to the *LAST* item in the table.
LOOPHERE:
LET BINARY = 2;
LET MIDDLE=FLOOR((TOP+BOT)/BINARY);
IF VALUE(MIDDLE) = KEY THEN STOP;
IF KEY < VALUE(MIDDLE)
THEN TOP = MIDDLE;
ELSE BOTTOM = MIDDLE;
IF TOP = BOTTOM THEN STOP;
GOTO LOOPHERE;
END;
Mar 08, 2009 | Microsoft Windows Vista Home Premium with...
H look up
Hi vrusha,
Your right hlookup is very simular to vlookup, the key difference is it searches along the top row of the table, finds the matching data and gives you one of the below cells (depending on how you write the formula), just think of a vlookup on it's side.
The formula works like this:
=HLOOKUP(lookup value, table, row_index_number, range_lookup)
lookup value = is the value you want to match against the table i.e. ABBA
table = the range of cells that make up the table you want to search i.e. A1:D300
row_index_number = the number of rows from the top of the table you want to get the value from, 1 is the top of the table, 2 is directly below
range_lookup = if you want an exact match type FALSE, if you want the nearest match type TRUE
Jul 17, 2008 | Microsoft Office Professional 2007 Full...
Texas Instruments TI-83 Plus Calculator Logo
43 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
