Bought a used 52" philips tv curved edges, color not correct, need new tube??? where and how much to buy?? any help in correcting this issue
  • 45 Answers
Use a unit called an electromagnet, and wave it around the TV. Your picture probably had a magnet too close to it.
Posted on Oct 17, 2013
4 Suggested Answers
  • 1153 Answers
SOURCE: mitsubishi ws-65905 color tube needed
What is going on with green? I may can help
Posted on Dec 26, 2007
  • 1030 Answers
SOURCE: Color Convergence
you will have to go into what is known as service mode... have to have a code to get into it
Posted on Jan 18, 2008
SOURCE: RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Posted on Sep 23, 2009
We have a RCA D52W23 rear projection TV. Now the color looks like it is in 3D. A friend has the same problem a few years ago and bought a part on line and fixed it themselves. What is the part and where...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 19, 2011 | RCA D52W19 52" Rear Projection Television
We just bought a Hitachi 65S500 tv secondhand. When trying to correct the convergence, the magic focus green color does not align the letters correctly in the horizontal position. When we try to correct...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
  • Screen looks 3D
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
69189a5.pngSOLUTION
Jan 10, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
52'' Projection TV SONY
this is a problem with the convergence chip. you can try to adjust the convergence in the menu settings of the t.v.
pin cushioning will correct the curves, convergence fixes color seperation.
write the number down before changing them, in case you make it worse.
Nov 11, 2009 | Sony Televison & Video
The picture curves in toward center of tv and looks like the colors are out of line.
These units had problems with there convergence power supplies. If the supply quits it will loose convergence correction. It could also be the convergence correction PCB itself. Have a repair shop check it out for you. Thanks
Oct 29, 2009 | RCA D52W23 52" HDTV CRT TV
My rear projection 51mp392h has color distortion on the bottom third of the screen,it curves up in the middle. Is this a picture tube
Hello tj444,
This is not a picture tube problem. This could be what is called pincushion distortion. It is caused when the is a malfunction in the deflection coils and the inability to correct for the curvatures caused by the CRT. The pincushion distortion can also be caused by the degradation of the functionality of the convergence amplifiers in the TV set. I would suggest that you have a TV technician examine the deflection circuitry and the pincushion circuit, this would also include the convergence amplifiers.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jul 12, 2009 | Philips Magnavox 51MP392H Rear Projection...
Tv will not turn on
If it is a convergence issue, you can unplug the cable that connects the two boards all the way toward the front. If the tv comes on with a VERY bad picture(no convergence) then your problem is in the convergence ckt. If not, you could have problem with your small signal board. Also, the "yellow" problem you are having is that the cooling fluid in your blue tube is getting cloudy and needs to be changed.
Jul 06, 2009 | Philips Magnavox 9P6034C 60" Rear...
Where to buy CRT TV Philips tube ?
Picture tube will not cause NO color problem, color circuitry problem.
Jul 18, 2008 | Televison & Video
Wd-52725 mitsubishi please help
Good day, anniedooday;
Your TV's color wheel is bad. Call an authorized service dealer to repair this. It's not an easy job.
Good Luck, big IRISH.
Jul 14, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Color and curve issues
  • I suspect you have a bad convergece problem. Requires replacing ic stks cost for servicer to due is 250.00 .If you
  • could solder and are good at repairing you could do this.
thanks doctor video
Jun 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergence issue resolved but concave picture remains
Set will need new convergence IC's.Requires chassis pull===technical & mechanical skill mandatory.After repair,re-aligment necessary.
Sep 26, 2007 | Philips 55PW9363 55" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
