I have a studio master 708 I was using it with no problems then all of a sudden a short blow led and all lights stop working . Loss of sound but power supply and on switch still seem to be working . Any ideas
  • 28 Answers
Check fuses
Posted on Nov 03, 2013
BLINKING GREEN LIGHT AND WILL NOT POWER UP
You can check the Error code by doing the following.
On the Front panel hold down the Device and Menu Button for 5 seconds. The LED light will then start flashing the first set of flashing lights is for the "1"5 part of the code it will then pause for about a half second and start the ones place 1"5". The code will repeat 5 times before going off.
The Error Codes: 12 - Normal Operation; 21 - X-Ray Protect; 22 - Short Protect; 23 - Loss of Horizontal Deflection; 24 - Loss of Vertical Deflection.
The problem may also be in the power supply when you first plug the device in check how many times the Led blinks if it blinks for just over a minute the power supply is working fine. If the Led blinks repeatedly and does not stop the DM is not running.
This is a link to the service manual for you TV,
http://www.service-manual.eu/model.php?id=2710
Mar 02, 2011 | Mitsubishi WS-65909 65" Rear Projection...
I am not sure if this is a problem with power supply. Yesterday suddenly my machine stopped working. I wasnt using it. It just shut off. Now when I started the cpu, I see one green LED on the mother...
the problem is in your motherboard..this most cause unregulated flow of power from the source electric..but if the green led is off so its the processor.try to test it with a motherboard tester..or get another board that same spec with the you have,and transfer the processsor if it is working
Feb 10, 2011 | Cooler Master RS-400-PSAR-J3 400W ATX12V...
My Del studio 1737 laptop is suddenly stops working and it is not working at all . power adapter light will turn off when i connecting to laptop. Please help me
if the AC adapter LED goes out when connected to the power connection of the system, then the failure is most likely the motherboard has failed.
Try a different AC adapter, if no change then motherboard
Jan 22, 2011 | Dell Studio 1737 Laptop
My master dimer and companion dimer led lights went out and I can't turn the light fixture off. The light stays on but the switch does nothing. Do both switches need to be replaced or just one and how do I...
If you can't turn them off, then chances are that the dimming element within the master dimmer shorted. Some dimmers can get triggered by a hellacious bulb blow-out where a surge of current will ruin the semiconductors in the dimmer and, basically, short it out. If that's the case, I can't guarantee that nothing was broken in the companion, but zero dimming capability usually means the master dimmer.
Also, because its shorted, there's not voltage left around for the dimmer's to use to power up themselves - that's probably why the LEDs on neither device are turned on anymore. Replacing the dimmer should fix that.
Jan 09, 2011 | Cooper Wiring Devices Aspire Smart Dimmer...
My Alesis stopped working!!
it might have a fuse in it if not its prob. an amp inside
Dec 27, 2009 | Alesis io 2 Portable 2-Channel 24-bit...
Carrier Weathermaker 8000 - furnace does not ignite
having a problem with a weather maker 8000. It will not come on at all unless I shut down the switch on the side of the furnace. filters is clean. it will start to light then stop
Dec 10, 2008 | Heating & Cooling
No Picture just sound from Toshiba 37hl17
IT is the Y Sustainer board blowing fuses. IT has 2 fuses. I have worked on severl of this model and the Y Sustainer board goes bad and blows the fuses.
Feb 22, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
35 people viewed this question
 Grubhead
Grubhead
