Question about GE Spacemaker JVM1640SJ Microwave Oven
Have GE Spacemaker XL1800, Had a power outage & now it wont power up. No lights or anything. Checked the 2 fuses behind the control panel & both were good. Any other suggestions or should I just chuck it.
  • GE Master
  • 9,098 Answers
In addition to the fuse(s), it will have one or two thermostats (aka "thermal cutouts" or "TCOs") which can open, resulting in a loss of power.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Have GE Spacemaker XL1800, Had a power outage & - dee77f7.jpg You can see a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Along with the video there, you can find information on getting your controller repaired, if that's what's required.
You find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Oct 17, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Spacemaker XL1800 (JVM1860WD 002) Stoped Working.
The control panel has built-in surge protection, and the high voltage probably tripped that. It will have to be repaired, which we do nationwide for only $39.95 postpaid. By rights, I would say the electrician should be the one to see to the repairs, including removing the control panel assembly to send in for repair. We have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 Please let us know if you have any other questions.
Posted on Apr 13, 2007
SOURCE: micro stopped working
Try looking at the microswitches behind the door.
Posted on Apr 14, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: ge spacemaker microwave
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If it has a hood thermostat, that should read open, as opposed to the others, which should read closed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 02, 2008
SOURCE: how do i unlock the control panel on my GE
directions are behind the door toward the bottom left. all you have to do is press the clear/off button for three seconds.
Posted on Dec 31, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Spacemaker XL1800 Panel light is dim
It may be a weak VFD tube or it may be that the rear of the display window and front of the display glass are very dusty.
Sometimes you can clean it inside to brighten it up.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you can detach the keypad connector (as per attached photo) then remove the control panel screws.
Be careful not to crack the glass display when handling it, or it's a goner.
Then you can use a soft cloth (not a paper towel) and a mild cleaner (not ammonia-based) to clean the front surface of the VFD display glass and the rear side of the clear bezel (display window) that's attached to the keypad.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
If that cleaning didn't help, then you have a weak VFD.
On some models, we can replace the VFD tube with a good used type to provide many years of good service.
Otherwise, you can replace your control board / smart board.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 10, 2010
Testimonial: "After completing a lot more research, I concur the VFD is weak, and replacing the module is $80 -- but it still works fine. Not now."
Ge spacemaker xl1800
check inside microwave and replace fuse chek the control unit other wise any short circuit at high voltage unit.
Jan 28, 2014 | Microwave Ovens
Ge spacemaker xl1800 vent fan
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Profile Spacemaker XL 1800 36"...
GE xl1800 I have checked both fuses and still no power to the control panel. What is the next failure?
someone needs to follow the voltage into the unit--- The voltage goes to fuse and then to inverter that drives the unit---fyi if unit is not real expensive a repair may not be practical----use some precautions if not familiar with this kind of appliance.
Jun 08, 2012 | GE XL1800 1100 Watts Microwave Oven
How do i unlock the control panel on my GE Spacemaker XL1800?
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Where are the fuses located? The microwave just died, no power, lights, anything. There is power to the outlet though.
you have to remove the vent grill at top. take out the screw above your control panel. fuse should be in a housing behind panel. if not you have to remove mw wrapper to expose all componets
Jun 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have an JVM 1630,31 it stopped working after a power outage the house got cold and I turned the stovetop on for 5 minutes did I burn something out or was it because of the power outage? I replaced the...
Below refers to the manuals which all contain the wiring diagram.
Microwaves:
 Inside the actual case. It is not consumer accessible. Over-the-range models have the manual behind the grille or control panel.
http://www.geappliances.com/service_and_support/faqs/
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Micro stopped working
Apr 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Apr 13, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
43 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
