Question about Mitsubishi Televison & Video
I have a HS-U55 VCR. I put in a tape, and I couldn't get power to stay on and the tape is stuck in there.
4 Suggested Answers
sharcnet
  • 2130 Answers
SOURCE: Mitsubishi HS-U61 SVHS
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor. Unplug the unit and take the cover off. Hopefully there will be enough clearance so you can get to the tape. Try to find the motor and belt that is responsible for operating the eject mechanism. The motor will look like a shiny cylinder, about the diameter of a quarter and will have a plastic pulley attched to the shaft. You can rotate the pulley and belt with your fingers and manually eject the tape. If the tape is around the spindles and video head, you will need to manually move the mechansim that retracts the spindles and returns the tape to the cartridge. While you may be successful in getting the tape out, you need to find out what caused the problem in the first place. Putting in another tape will most like become stuck again unless the problem is identified and resolved. Also look for a broken spring or cracked gear (missing teeth) in the eject mechanism. Please let me know if I can be of further assistance Good luck! - Jim
Posted on Feb 28, 2008
alltechserv.
  • 32 Answers
SOURCE: A video tape has become stuck in my Mitsubishi VCR
Hi, Suggest call a local tv repair shop. Thanks.
Posted on Sep 22, 2009
vinceisaac
  • 2432 Answers
SOURCE: HS-u760, tape was stuck.
hi welcome to fixya
do you mean sir the loading mechanism is stuck up?. ok unplug then re plugged first the vcr to reset the electronic board circuit. now if still the mechanism doesn't go back to its original position turn off and unplugged again the unit. then check the drive belt for capstan motor if not in proper place then replaced if worn out. make sure no foreign material that blocks to the mechanism and all the pinch roller that guide the tape are in proper place. then at the same time you need to check the servo drive board for the motor if the voltage is present, if none it might main board failure. at this time you can ask for the supplier for technical assistance.hope this will help you thanks for consulting the fixya.
Posted on Sep 11, 2011
Will not eject tape
take the top off the VCR, you will see where the tape is hung up. Reach down and release the tape and pick it up, now close the top.
Jul 31, 2012 | Mitsubishi HS-U575 VCR
How to Remove a Stuck-Up Tape
Take the top of the VCR off and remove it manually. If you don't do this you risk ruining the tape.
May 03, 2011 | Mitsubishi HS-U760 S-VHS VCR
I have a Mitsubishi HSU48. The tape is stuck in the VCR. I cannot get it out. Do you have any suggestions
I had this problem with this specific machine. These answers have all been general to any VCR. The Mitsubishi HS-U448 has its motor underneath the machine. You don't have to remove the top cover at all. Just remove the bottom plate and spin the motor (the correct direction) to completely eject the tape.
Dec 23, 2010 | Mitsubishi HS-U448 VCR
Tape stuck will not eject
open vcr look for a belt on the right side of the vcr and begin manually turning it until the tape ejects
Jan 04, 2010 | Mitsubishi HS-U770 S-VHS VCR
Sep 22, 2009 | Televison & Video
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
Feb 28, 2008 | Mitsubishi HS-U447 VHS VCR
Language setup for Mitsubishi HS-U510 VCR
try holding down the power button for 8 + seconds upon first starting the vcr. the language option will again be afforded you. see the manual.
Nov 07, 2007 | Mitsubishi HS-U510 VHS VCR
Error message E4 and stuck tape
Yes with care. Simply remove the cover and with care unwrap the tape. If you must break the tape - but make sure all residual tape is cleanly removed. Re assemble and put a tape head cleaner through- following the instructions.
Jun 22, 2007 | Mitsubishi HS-U445 VHS VCR
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
