Question about Bosch C108 94 95 96 97 Mercedes Benz Vacuum Supply Pump 0132006399 S320 S350d S420 S500 S600
When I turn on my right turn signal my left turn signal blinks
    Sergeant:
    Champion:
  • 202 Answers
Sounds like soemone has been in your wiring at the tail light. if they switched the two wires for the turn signals when they put it back together you would get that.
Posted on Oct 18, 2013
What would cause the turn signal to blink continuously?? The only time the left one stops blinking is when you use the right signal??
sounds like the turn signal switch in faulty.
i found some great info that explains the switch and its functions.
Self Canceling Signals How Turn Signals Work
(page 4)
Cheers!
Oct 30, 2014 | Cars & Trucks
1999 buick lesabre my right signal doesnt blink it stays solid , my left turn signal blinks fine i have to manually blink the right side every turn , i put the hazard lights on and the front left and right...
The easiest thing for you to do would be to replace the bulbs that are on that circuit. You should have one or two bulbs with a double filament, one for the brake and turn signal and one for the tail light.
If that does not fix the problem, someone will need to check the circuit for power from the turn signal switch. It takes all of the lights on one side to make the turn signal flash.
May 16, 2013 | 1999 Buick LeSabre Custom
Problem with turn signal when headlight is on
this sounds like a earthing problem , so check the wiring for the head lights, see if any wires are trapped between something, bare wire touching car body , anythingthat doesn't look correct, could also be the indicator lever itself with a problem , but check the headlight wiring first
Jun 03, 2017 | 2002 Chevrolet Express
92 buick skylark right side blinker does not work the bulbs are good left side works. you can here the turn signal quick blink noise when using right turn signal
check the front bulbs .
turn on the LEFT (fullt functioning ) turn signal ,
get out of the car and look at what lights are blinking in the front.
now turn on the right (broken) signal and note which lights are NOT blinking that had been on the fully functioning signal indicator.
Sep 28, 2011 | Cars & Trucks
Brake light, reverse light and turn signal issues
Hello. The symptoms you are describing are likely due to a poor ground. Temporarily install a new ground wire by securing a piece of copper wire to the frame with a self tapping screw. Use this ground wire along with the hot wire to see if each of these lights works. If it does, trace the ground wire back to the frame, unscrew it and clean up the metal with emery cloth so you reestablish a good ground.
Jan 28, 2010 | 2003 Ford Windstar
2006 Durango Turn Signal Issues
SOUNDS LIKE YOU HAVE A FAULTY MULTIFUNCTION SWITCH
Jul 27, 2009 | 2005 Dodge Durango
Bosch C108 94 95 96 97 Mercedes Benz Vacuum Supply Pump 0132006399 S320 S350d S420 S500 S600 Logo
Top Bosch Heating & Cooling Experts
 Mikey
Mikey
Steven's...
Steven's...
Stan Ford
Are you a Bosch Heating and Cooling Expert? Answer questions, earn points and help others
