Question about Medical
I brought a eye power tattoo kit off Amazon. Com ...the box is working,the foot petal works, I can hear it running but the gun isnt working. What should I do?
    Problem Solver:
  • 8 Answers
Contact the seller you got the item from. They should be able to assist you with your problem. If not then, ask them to send you out a replacement. If they wont then simply ask for a refund. When things like that happens on Amazon or Ebay, i always contact the seller to see if the problem can be resolved. If they don't assist with the problem, I get a refund.
Posted on Dec 01, 2013
  • Nikki Taylor
    Nikki Taylor Dec 06, 2013
    Is the amature bar moving? If not then make sure the coils aren't touching.
2 Suggested Answers
sinlacera
  • 12 Answers
SOURCE: i have a tattoo gun with no power supply. how can
get a **** power supply and don't be a dummy. you can get cheap one's and add a pc cooling fan so it wont blow up. that's the best you're gonna do if this is actually a concern of yours.
Posted on Aug 27, 2012
My eyepower tattoo machine quit working.is there a fuse in it that I can replace?
i also have an eyepower tattoo power supply which will turn on and display the setting but wont run my guns. i dont know if it is the power supply, clip cord or hot foot switch but if you get any tips please reply
Oct 02, 2013 | Computers & Internet
Dragonhawk tattoo gun
Not really my area of expertise.
But I bet I'm more qualified than most people.
(Mechanic, machinist, fabricator, welder, computer geek, etc)
Looking at the Dragonhawk Tattoo Gun shown in this example,
http://www.amazon.com/DragonHawk-Tattoo-Color-Deluxe-Case/dp/B0055EIFC6
,I see the gun works with Solenoids.
The coil is energized with electricity, and pulls the iron cylinder core back, and forth.
This cylinder then hits a flat metal bar, and the bar is connected to the tattoo needle. (Through the various mechanism)
A) Your power adapter is an AC adapter. It converts the AC voltages from your home, or business, into low DC Voltage.
First thing to check is that it IS delivering power.
LED light lit up on the AC adapter means it is GETTING power, but we do not know if it is delivering power to the gun.
A multimeter is used to check.
Now wait a minute...............
An inexpensive multimeter can be purchased for as little as $5 to $12, if you do not have access to one.
Available in a multitude of stores.
An auto parts store is but one example.
I have seen them on checkout aisle racks, at major discount stores.
Looking at the AC adapter, what style of plug does it have, for connecting to the gun?
I need to find out what the Positive connection is, and the Negative connection.
The multimeter Function Knob is set to DC Voltage.
If just a symbol, the symbol is a dotted line over a solid line.
[IF there is more than one DC Voltage scale, set it to the 0 - 50 Volts scale.
0 to 50 Volts DC ]
The Positive (Red) probe lead of the multimeter, touches the Positive connection, of the plug that connects into the gun.
The Negative (Black) probe lead touches the Negative connection, of the plug that plugs into the gun.
Voltage is read. Don't know what the voltage is, but YOU will.
Look at the AC adapter's label.
Input: 100 ~ 240 Volts / AC 50 ~ 60Hz
We need -> Output: xxVDC @ xxA
(xxVDC is how many DC Volts.
Let's use 12 as an example.
12VDC
xxA is how much Amperage.
Let's use 3.67A as an example
3.67Amp's, or 3.67 Amperes. Same/same)
AC adapter is putting out the required voltage?
Then the switch is checked next.
Check switch for continuity.
[ Check with multimeter set to OHM's. 1K.
NO AC adapter connected to gun.
Positive ( Red) probe lead to one side of switch.
Negative (Black) probe lead to the other side of the switch.
Turn the switch to on.
If the switch is good you will get a reading on the multimeter.
DOES NOT matter at this point what the reading is.
Just matters that you DO get a reading ]
Switch is good?
Then there is a problem with one of those coils, going around the cylindrical metal bar. Perhaps a wire going to them is broken off.
Or wires in the coil have burnt.
There is a set screw for adjusting how far the vibrating metal bar, is away from the cylindrical metal bar.
Determines the distance of the flat vibrating metal bar, to the cylindrical metal core in the coil.
If this has been adjusted too tight, the flat metal bar won't vibrate.
Doubt this is the problem, or you would have stated the gun 'Hums', but won't vibrate.
[The black cylindrical things are coils. The shiny cylindrical metal objects inside them are the vibrating cores ]
I suspect the AC adapter isn't putting out any power, or the switch on the gun is bad.
Post back in a Comment, about the design of the plug from AC adapter, that plugs into the gun.
Regards,
joecoolvette
Jan 21, 2013 | Computers & Internet
Cleaned gunn an no work
you can buy a coil replacement kit from almost any distributor or supplier personally i would do that when you cleaned the gun did you take it apart ?
Jul 29, 2011 | ART Cast Iron Coil Tattoo Machine Liner &...
The amiture bar is sticking to the coils when i run power to the gun . it won't bounce
sounds like you fried your coils or at least one of them if one loses any amount of power the other dominates i would buy either a new gun or a replacement coil kit
Apr 08, 2011 | ART Cast Iron Coil Tattoo Machine Liner &...
When doing line work what should your power box be on,and do you run it slower or faster for shading
i believe your power box should be between 110 and 120....and for shading you should run it slower....somewhere between 75 and 85.
Oct 15, 2010 | ART Cast Iron Coil Tattoo Machine Liner &...
What voltage do you tune your liner tattoo gun and shader tattoo gun?
i run my liner at 6.3 and my shader seems to work just find there to. u can make adjustments on ur guns to get that good sound. also it depends on ur gun
Jul 21, 2010 | ART Cast Iron Coil Tattoo Machine Liner &...
Tattoo gun set up
First off, all your information is ********. Any **** that says to get an apprenticeship is full of himself and all the info I have heard is useless and you guys are sucking your own dicks... Everyone works differently and there are alot of right ways. An apprenticeship is bs, no one has the time to sit around in a shop for no pay, and be someones ***** for over a year and do the grunt work only to work in a retail shop with little to no skills, because of people like some of you who wont help the guy trying to learn who may be a great artist. I did my time and took a formal apprenticeship, and did not learn anything but basic knowledge and how to survive without pay. I have been tattooing for aver 12 years and work in a very high end salon with plenty of clients who love my work. Learning is doing, and there are lots of ways to learn. Safety and sterility is the most important, never forget that... research that before you even touch a machine. Practice on fruit like oranges, old leather jackets or practice skins, they are easy to find. Tuning the machine is a process and takes some time, but is very important, and every power supply is different and requires different voltage. If you want the low down on tuning I will be happy to break it down from scratch for anyone who agrees to the fact that false information from some high and mighty ********* who is probably pretending they are the ****, and the give bad advice and create more shitty artists, then give me some thumbs up to this response and I will break it down like a real pro instead of leading you along and pulling the get an apprenticeship card, or "its not a gun its a machine" line. If it does not work for you, I will admit I am a ***** who does not know what he is talking about. I will answer by tomorrow if you are a so called "scratcher" and need help... Everyone deserves a chance and no one should deny anyone that right or give out ******** advice.
Feb 16, 2008 | Office Equipment & Supplies
Medical Logo
142 people viewed this question
Top Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Medical Expert? Answer questions, earn points and help others
