Question about Canon Pixma MG5220 InkJet Printer
PIXA MP495 CODE 2.145.50 - Canon Pixma MG5220 InkJet Printer
Mp495 scan without cartridge
It's a funny thing but, after trying everything above, I just pressed the SCAN button on the printer, instead of trying to do it from a program in the computer. It scanned the document and launched MP Navigator!
Jun 29, 2012 | Canon PIXMA MP495 InkJet Printer
What ink will my canon mp495 take?
Quikshiptoner is a good site for ink and toner that I generally use. It has black and color ink for the MP495. I'd just go there and search for the printer you need and it should come up with the correct ink / toner that you need.
May 11, 2012 | Canon PIXMA MP495 InkJet Printer
Canon pixma mp495 error code E03
e03 is paperjam or out of paper error, make sure you have a decent amount of paper in the tray. open up all the doors on the printer and make sure there's nothing stuck inside the machine.
Apr 03, 2012 | Canon Office Equipment & Supplies
What does Error code P03 mean on Canon Pixma MP495
Download the manuel from this link below:http://www.manualowl.com/p/Canon/PIXMA-MP495/Manual/68096
It might have some trouble info for you. ;-)
Jan 29, 2012 | Canon PIXMA MP495 InkJet Printer
Canon PIXMA MP495 InkJet Printererror code 5200 problems
Here what I found for you. If it fixes your issue, don't forget to give me a good rate. Thanks
Print head temperature rise error or Error Code 5200
Condition: The print head temperature exceeded the specified value.
Problems and Solutions:
  • Turn off the printer and then turn on if error still persist replace Ink cartridge or print head thankyou for using
Aug 30, 2011 | Canon PIXMA MP495 InkJet Printer
Canon Pixa iP1600 "an ink
Try taking it out and putting it back in again. Reseat the cartridge. Also unplug the power to the printer and plug it back in. See if it will work then. It may just need to be power reset.
Thanks for using FixYa!
Aug 08, 2011 | Canon PIXMA iP1600 Printer
Canon MP495 Pixma scanner says this when I try to scan something. Cannot comunicate with scanner for these reasons: -Scanner is turned off -Scanner is disconnected (It is disconnected from LAN, if...
Regarding the Cannon scanner error 2145,50. The MG5220 does this also. The actual problem is that the scanner will not communicate with the computer correctly if it is connected through a USB hub. A direct connection to the computer cures it, for me at least.
I know, I had that problem. I am a retired electronics design engineer.
Jun 30, 2011 | Office Equipment & Supplies
Canon Pixma MG5220 InkJet Printer Logo
94 people viewed this question
old marine
old marine
