Question about Canon Pixma iP4500 InkJet Printer
My printer thinks that no paper is loaded in the rear tray when I try to print on 4x6 photo paper
    Master:
  • 785 Answers
Some printers has special tray to put small papers in.
Posted on Oct 17, 2013
SOURCE: Paper Jam
No still jammed will contact the shop I purchased it from or ask the IT people I deal with at work if they have solution. Thanks
Posted on Dec 02, 2008
SOURCE: Canon IP4600 won't feed from rear tray.
It turns out that if you read the documentation VERY carefully it says that "if the application program specifies 8.5x11 plain paper and that is what is loaded in the front cassette you cannot print from the rear tray". It turns out that this is true even if you go to the printer driver and specify "rear tray" manually. The driver disregards the setting. You can force printing plain paper from the rear tray by going to the Canon "My Printer" icon and forcing ALL printing from the rear tray. If you do this, remember to change it back. You can also print plain paper from the rear tray if you specify the "allocation" option and the paper from the front cassette runs out. You can always print from the rear tray if the application that created the print job specifies something other than 8.5x11 without resorting to the forced override, e.g. printing a .jpg or .gif or something from an application like Paintshop or Printshop, etc.
Posted on Jun 13, 2009
SOURCE: Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Posted on Jun 16, 2009
SOURCE: printing 4x6 glossy paper photos on Canon MX700
I have a Canon Pixma MX700. I have printed many great photos but not it prints a faint image in the background but the rest of the photo is covered with black ink spots, what can I do to correct this problem?
Posted on Sep 27, 2009
cene765
  • 787 Answers
SOURCE: printer says no paper, but there is. Problem loading?
If not paper jam may has some problem with feed rollers on printer.First make sure that option to feed from cassette is turned on.Check this on maintenance mode.Аs the printer is in warranty better don't touch anything else and call Canon.
Posted on Nov 23, 2009
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
I want to print photos from my laptop onto four by six photo paper, and i loaded the photo tray with the paper, and changed the tray preference to photo tray, but it's still telling me that there's no...
You also need to change the paper type in printing preferences.You will find 4x6 and 4x6 with tab in th pull down menu where it says plain paper. Be sure to position the paper as far as it will go into the printer and close the paper controls to hold it there. Also fan it well before you put it in.
Dec 31, 2010 | HP Photosmart C5180 All-In-One InkJet...
How to load 4X6 photo paper
hi
  • Turn on the Epson 875DC and the attached computer. Make sure the cable between the two devices is securely in place.
  • Step 2 Remove any paper that is in the printer's feeder tray. Place the 4x6 photo paper printable side up in the tray, with the support sheet at the bottom of the stack of photo paper. Adjust the paper guides so they are pressed against the margins of the paper.
  • Step 3 Open the photos to be printed in your computer software program of choice. When you are ready to print the photos, click on the "File" link at the top of the window, then choose "Print." Click on "Properties" and select "4x6" for the paper size and "Photo Paper" under the paper type. Click "OK" to close the "Properties" window, then click "OK" again to print the photos.
  • Jul 02, 2010 | Brother MFC255CW All-in-One InkJet Printer
    I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
    Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
    1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
    2. Click Start and then click Control Panel .
    3. Click Printers and Faxes .
    4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
    5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
    6. Make sure that the Source is box is set to Photo tray .
    7. Click the Borderless Printing box if borderless prints are desired.
    8. Click Apply and then click OK .
    9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
    Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
    Smaller items will only feed crookedly into the printer document
    Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
    Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
    Printing envelopes:
    • Up to 15 envelopes can be loaded at a time.
    • The print side of the envelope faces down.
    • The envelopesare centered on the paper exit tray.
    • You print the envelopes with Landscape orientation.
    Printing cards:
    • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
    • The print side of the cards faces down.
    • The cards are centered on the paper exit tray.
    • You select Automatic, Normal, or Photo print quality.
    For images on how to correctly load the paper, download your printer user's guide:
    http://support.dell.com/support/edocs/systems/prn946/en/index.htm
    Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
    Will not go to photo tray to print 4X6 picture
    This is why Mac's are EVIL!!!! LOL, anyway try using the software, that comes with the printer, and tell it which paper type, and tray to use. Also try printing on a PC, and see if it works then, as you may have to live with this as the solution.
    Feb 22, 2008 | HP Photosmart 3210 All-In-One InkJet...
    Printing photos
    Of course you can use 4x6 photo paper
    you have select the paper size from page setup as 4x6
    and put the paper in the tray after adjusting the tray size
    Dec 27, 2007 | Samsung CLP 300 Laser Printer
    Hp photosmart d7160
    hp photosmart d7160
    how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
    Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
    Canon Pixma iP4500 InkJet Printer Logo
    old marine
    old marine
