Question about JUMP START SYSTEM
Turn key all dash lights appear but engine won't turn
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Could be a starter relay or the starter itself, or it could be the neutral safety switch not set where it should be.
Posted on Oct 17, 2013
Engine started and ran 2 seconds and turned off, after 5 tries it will not turn over.
First off, you will need both batteries connected for the amperage to be available to start a diesel. Secondly, when you turn the key, the vehicle will not crank over? Does it make any sound at all? DO the power door locks work with the key fob?
Oct 10, 2015 | 2010 Dodge Ram Pickup 3500
2001 Chev Malibu. Turn key on to start car, won't start. No warning lights on no lights on gauge panel. Radio works, dome light work.
check the ground leg to your engine.. it runs off the neg. battery terminal. will connect to frame and engine.. pull it off, wire brush it put it back.. you radio will work, 'cause it draws much less current, and is grounded in dash.
Jan 11, 2013 | 2001 Chevrolet Malibu
Car will not start when ignition key is turned. All warning lamps light up, enginee doesn't even try to start even with the clutch depressed
1. So the car was running normally and then on one occasion you put in the key to start it and all the warning lights flash up on the dash and the starter motor will not turn the engine over. Is that correct.
2. When you last drove the car were any warning lights appearing on the dash.such as check engine warning, engine overheating, electrical charging warnings etc.\
3. Has any work been carried out on the car recently.
4. How old is the battery in the car.
Dec 23, 2012 | 2010 Jeep Patriot
MY PLYMOUTH GRAND VOYAGER 'S HEADLIGHT'S AND DASH LIGHTS WORK, BUT THE ENGINE WON'T TURN OVER. THERE IS NO SPARK COMING FROM THE ELECTRICAL WIRES.
When you say no spark, are you talking about the spark plugs, or just the general wiring?
If the engine won't turn over, then it isn't moving, and if it isn't moving then you need to check the following in this order:
1) Does the battery have power i.e. around 12.4 volts or over?No? Charge, test or replace battery.
2) Do the car's head lights dim considerably if turned on when attempting to crank? Yes? Possible lack of battery charge or faulty battery.
3) Assuming the battery is fine, can you turn the dash warning lights on and off with the key? No? Faulty ignition switch.
4) Is there a click sound when you turn the key, but no starter motor spin? Check starter motor connections or replace starter motor.
If none of the above prove to be of help, then please report.
Oct 31, 2012 | Plymouth Cars & Trucks
I got a 1999 chevrolet tahoe. when i put the key in the ignition the head lights,and the dash light comes on but it won't even turn. i change the starter and got a new battery and it still won'
well if you have a dvom/voltmeter check the power at the starter terminals. the main terminal should have power all the time the key wire should have power only when the key is turned to crank engine. if you have power at both then i would start looking at grounds
Mar 30, 2012 | 1999 Chevrolet Tahoe
2009 HHR won't start. Battery is good.
Is the security light on or blinking?If not then do you have power to the starter.You can check this with a test light.You should have power when you turn the key to start.The test light should light up.Should be the small wire.I believe it is purple in color.If the security light is on then you will have to get the codes to see what is causing the no start.Hope this helps.Good luck.
Dec 07, 2011 | 2009 Chevrolet HHR
Battery is fine but when i turn the key nothing happens. it won't turn over.
blow horn, see if lights in dash light up then turn key all the way like you start car if lights go out and no engine clicks are anything u hhave starter probelms replace it
Sep 04, 2011 | 2004 Dodge Dakota
My toyota corolla 2006 model has the maint. required lights on. what does that mean?
It means your car needs an oil change, based on mileage. If you take your car to get the oil changed, they can reset the light for you. If you want the light off now, try holding in the odometer reset button, with the key on but engine off, until little dashes appear then one by one dissapear. This procedure may need to be done either on the odometer total mileage or trip A mileage or trip B mileage.
Step 1: Have car off.
Step 2: Push and hold in trip reset button.
Step 3: While still holding button in, turn key to ON, but engine off. Wait for the little dashes to appear and disapear. If it doesn't work on the odometer setting. before turning key off, switch to Trip A setting. If the procedure doesn't work on the odometer setting or Trip A, try Trip B setting.
Step 4: Turn key off. Then start car. Maint. required light should be off.
Jul 15, 2011 | 2006 Toyota Corolla
95 grand cherokee no start, it turns over but won;t start, trying to find the pcm connector pin out diagram
If you don't have a check engine light that lights up on the dash when you turn your ignition key to on, then your ecu has gone bad, internally.
Nov 04, 2010 | 1995 Jeep Grand Cherokee
JUMP START SYSTEM Logo
Top Vector Vehicle Parts & Accessories Experts
Lawrence Oravetz
Vernon Taylor
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
