Question about Acer Power 1000 PC Desktop
Will not accept my bios password
Need to access my hard drive
    Problem Solver:
  • 18 Answers
Safely shut it down and then pull the power cord. Making sure you are grounded (touch metal on the computer case and don't shuffle your feet on carpet), look on the motherboard for a little plastic piece (jumper) the kinda looks like a skinny chair and usually says "PSWD" next to it. Pull that, then safely plug the computer back in to power and turn it on. You should see a screen that tells you the password has cleared. You can do what you need to do in BIOS or you can replace the jumper and do what you need to do. Either way, the password will not be set unless you set it again in BIOS while the jumper is on the motherboard.Will not accept my bios password - 7e1a8302-ab25-44c4-8aea-83dbe920c40a.jpg
Posted on Oct 17, 2013
How to remove hard disk password from PC?
That is two different things.
A BIOS Password makes you enter a password to boot the machine up. To get rid of this you need to google
make model remove bios password
This requires shorting two pins on the motherboard.
A Hard Disk Password is something different. The requires a password to access files on the hard drive, but not the operating system. To defeat that, you need to reformat and reinstall Windows.
remove bios password Google Search
Apr 30, 2017 | Hard Computers & Internet
Can't install new hard drive because of a bios password. How do I remove it?
Remove CMOS battery; after some time BIOS should reset to fabric conditon, without password
May 13, 2015 | Dell Inspiron 15 (N5050)
How do I use the password protection?
Your questions isn't too specific but I hope this helps
There are several ways to incorporate password protection. You can set the computer to require a boot up password in the computer BIOS. You have to enter the computer BIOS as soon as you turn it on; with a Dell press [F2], with HP press [Esc] and select system configuration. In the BIOS you can set the BIOS Administrator password - controls the ability to change BIOS settings, the computer boot password - when enabled it requires the user to enter the bootup password before the computer will boot, and set the hard drive access password - controls the users ability to access a hard drive.
The next level of password protection is at the operating system level - account access levels, privilege levels, and passwords. Dependent of operating system you can also set hard drive encryption
Oct 28, 2014 | Maxell MAXDATA 503802 - FLIX8G HIGH-SPEED...
Old compaq presario 900 won't start. I see the Compag logo and then immediately black screen with blinking cursor. HDD is new Western Digital 250 GB, and tests ok with Seatools diagnostic. 1 GB memory...
Watch the screen as it boots up looking for the press F1 or DEL to access Setup. Your Presario may not be able to see the new HD in which case you will have to run second party software to access the HD. Get into the Setup BIOS and check for your new HD under hard drive detection if the BIOS can not find it, you will have to run other software to access the drive. If your BIOS gives you the option to start up the hard drive after a delay such as 1 or 2 seconds try that, as the BIOS on the hard drive and the BIOS on the motherboard may be clashing. Hope this Fixya up
Mar 20, 2011 | Computers & Internet
My password is correct but the smartware application does not accept it all over a sudden. what can i do to reuse my WD my passport essential 2.0 500gb drive
Hi
How to remove and unlock hard drive password? Is there any software to recover hard drive disk password? Where to download hard drive password cracker? Is it possible to reset the hard drive password?
According to manufacturers' website, if you forget your hard drive or hard disk password, there is no possible way to reset your password or recover data in the hard disk drive. Basically the hard drive is unusable. Scary right? However, this is often not true.
Most people are not aware that most hard disk drives have the ability to set a hardware password, just like the Bios password for motherboards, thus making the drive completely inaccessible unless a correct password is provided during the BIOS POST test. Usually these features can only be found in laptops, this is when you set a password on your notebook, the hard drive together with the motherboard becomes locked.
Most experts would say if you forget the original HDD or Bios password, there is no way of restoring it by generic system tools. Unlike the Bios password where there is a master key or with the removal of the bios battery, the password is erased from the flash memory thus the settings is restored to factory settings without the password, however, this does not applies to hard disk.
HDD Unlock Wizard is a user-friendly application which allows you to easily remove HDD password. IDE and SATA hard disk drives are supported. Both User and Master password can be removed. Please note that while unlocking, HDD Unlock Wizard will erase and re-certify the drive, meaning to say all data in the disk is lost and not recoverable. HDD Unlock Wizard incorporates proprietary unlocking algorithms which allow removing an unknown HDD password and making hard drive usable again. Download HDD Unlock Wizard now! 2.8MB only!
It may not be possible to recover the hard drive password or to unlock it; however, it is possible to remove the password together with the data, thus making your hard disk accessible and usable again.
Jan 16, 2011 | Western Digital My Passport Essential SE...
On my gateway laptop, I have an all black screen with a blue 4 inch box that prompts me for my HDD password. I don't have that password at all.
Hard drive passwords cannot be broken or gotten past. There are no special tricks unfortunately....most people that have an unknown hard drive password are forced to get a new drive and start over. If you know what the old BIOS password was, sometimes when people make a bios password they make the hard drive password the same. BIOS passwords and user account passwords can be reset......hard drives cannot. If you need the files from the hard drive....you might be able to access the files by removing the drive and using an IDE / SATA to USB adapter and connecting to a different computer.
Nov 11, 2009 | Gateway 450ROG Notebook
Forgot my password in cmos harddisk
The hard disk password is setup using the BIOS configuration, this password is stored on the hard disk and there are no backdoor passwords you can use except the password you created and if you know this password then you can remove it permanently using the BIOS configuration. Moving this hard drive into another laptop will not work either, it won't allow access to this hard disk.
Your only option is to purchase a new hard drive to replace the one with the password.
If you also created a BIOS password, you need this password to get into the BIOS configuration.
All these passwords are created by users to prevent unauthorized access into the laptop and hard disk.
Apr 24, 2009 | Acer Aspire 5602WLMi (LX.AB10J.002) PC...
Simpletech external hard drive is showing as write-protected disk
Usually a protected hard drive has been in a laptop and the hard drive password is setup from the laptop's BIOS configuration. This password is embedded on the hard drive's chip.
This password protects the data from unauthorized access and must be removed before reuse in another laptop or as an external hard drive.
There are no backdoor passwords available and needs to be removed using that laptop's BIOS configuration, you need to know the password to enable you remove the password peotection.
Mar 29, 2009 | Sony Computers & Internet
Trying to find a way to reset or bypass the HDD1 user password on my Toshiba A135-4527 laptop. It was reset somehow to something we do not remember. Hoping I do not have to replace the harddrive. Saw...
The hard drive password is set from the BIOS configuration where the hard drive was installed and you need to know the password to remove the existing password. You can only remove the password from that computer's BIOS and moving the hard drive to another omputer will not allow you to remove the password or access any data on that hard drive because the password is stored in the hard drive's firmware. This password protected hard drives prevents unauthorized access to the data on that hard disk.
Removing the BIOS battery will reset the BIOS but will not remove the password.
Some computers have been setup with Power On Passwords and/or hard drive passords and it is possible to hack/read the Power On Password that is stored on an EEPROM chip on the laptop, but it is not a simple process.
You will need to buy a new hard drive and now you also have a nice paper weight.
Feb 19, 2009 | Toshiba Satellite A135-S4527 Notebook
Acer Power 1000  PC Desktop Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
