Question about KitchenAid Dishwashers
I want to replace the control board on a kitchenaid KUDC10IXWH 0. Do I have to remove the door panel. Removal of the control panel did provide access to the control board.
  • 1986 Answers
SOURCE: Removal of door panel/trim
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
Posted on Aug 14, 2009
  • 1986 Answers
SOURCE: 1998 safari van - removal of passenger internal door panel
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. then you just remove the bolts to the mirror
  • 37 Answers
SOURCE: kitchenaid dishwasher, control panel is not
I don't know your technical ability, but there is a fuse located next to the control board inside the console, this is a good place to start. Kitchen Aid is good about putting tech sheets on the back of the kickplate and it should have wiring and diagnostic info there. Just be sure to put the sheets back so the next service tech to work on it will have them :)
Posted on Sep 01, 2009
SOURCE: X5 Door Panel Removal
there are 4 torx T-15 screws, one in the rear map pocket, one under the air bag logo plastic clip, one under the wood trim (pry the trim off carefully), and one holding the door handle assembly (also revealed when you remove the wood burl cover). Pick up a pry tool at autozone, about 5 bucks to pry the clips out without breaking
Posted on Nov 24, 2009
  • 454 Answers
SOURCE: driver side door panel removal
Generic instructions to remove door panels:
1. Remove the screw(s) in the trim behind the door release handle and remove the trim.
2. Look for the screws in the arm rest and remove. Remove the arm rest.
3. Look for other screws (possibly under caps) and remove them.
4. Insert a wide flat blade between the door panel and the door. Find the plastic tabs which hold the panel to the door and gently pry the panel away from the door. Make sure you work as close to these plastic tabs as possible to avoid ripping the panel.
5. Work your way around the door prying the tabs out of the door.
6. When everything is free, gently lift the door panel straight up and out of the door.
7. Disconnect the electrical wires, and you are done.
8. There is a vapor barrier between the door and panel which must be gently peeled out of the way in order for you to gain access to the window and door latch mechanisms.
Posted on Jan 20, 2010
How do I remove door on KitchenAid microwave YKHMS2050SS-2 in order to replace the CTRL-ELEC control card inside the door?
The support page for YKHMS2050 series microwaves is here. There you can find your owner's manual, installation instructions, and exploded views with parts lists. It will help with disassembly. You can affordably order Kitchenaid parts from the Pros here.
Actually, I can probably repair your board for half or less than the cost of a new one. But it depends on your detailed symptoms. See my signature link below to e-mail me for full information or other free help.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 16, 2017 | KitchenAid Microwave Ovens
Kitchenaide dishwasher KUDS25SHBS1
I have listed COMMON problems / reasons why a dishwasher won't start..
The thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Dec 15, 2013 | KitchenAid Dishwashers
Having touch-pad problems with my KitchenAid KHMS2056SSS-0 range hood microwave. It's an intermittent problem where the touchpad activates itself and activates menu items.. and beeps each time. Resetting...
Usually the top vent front panel is held in by two screws and or clips, Get those off and the bottom of this peace should un hook, unless there are screws there also. if you can get this far, the rest will be obvious.
Oct 20, 2013 | KitchenAid Microwave Ovens
Need to replace door handle for Kitchenaid over-the-range microwave, Model: KHMS2050SSS - 0
You usually get better search results by leaving off any dashes or spaces in a model number.
Normally you have to separate the door panels (as shown in the photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful literature and exploded view diagrams with part numbers here and you can order parts from the Pros here.
May 21, 2013 | Microwave Ovens
How do you take off a microwave door and put a new one on?
KHMS155LSS0 - May 27, 2017
On many models you can open the door all the way and gently lift it off.
Otherwise, you have to do some disassembly.
The support page for your model, with manuals, is here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
May 27, 2017 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I have a Kitchenaid Dishwasher that the two panel lights labeled 'normal' and 'cancel' are blinking and it is will not run. Anyone have any ideas? .
That is a problem with the communication between the control board and the control panel...
Kill all power to the DW...
Remove the back of the door...
Then find the ribbon cable going from the control board to the control panel...clean the ends with alcohol...
Then try it again...if it still does it then replace the ribbon cable and the control panel...
Buy the parts from www.repairclinic.com they have a 365 day return policy so you can return any parts if they prove not to be the problem...click here..
heatman101
Sep 13, 2011 | KitchenAid KUDI01TBK Dishwasher
We just recieved our new kitchenaid heating element for the dishwasher, but it came with an electronic control or circuit board thing, and there is a note that both must be installed. We easily replaced...
The control goes in the door...it is easy to get to.
Just take the screws out of the inside panel of the door, they are around the outside edge of the interior of the door. The panel will then lift off and the control will be near the top on the inside.
Make sure the power is turned off to the dishwasher and then one by one remove the wires from the old board and place them on the new board. then remove the old board and fasten in the new one. replace the panel and then give it a trial run.
Everything should be working just fine but some of the timing will be a bit different.
heatman101
Apr 21, 2011 | KitchenAid Dishwashers
Just stopped and no power, breaker is fine
There is a thermal fuse (also known as a bi-metal) located inside the control panel of the dishwasher. The part number for the thermal fuse replacement is W10258275.
If you type in your model number you can utilize the exploded view parts diagrams at pcappliancerepair.com, appliancepartspros.com or searspartdirect.com to assist you in locating the part. The fuse is listed as item 6 under the "Control Panel Parts" section.
To replace the fuse, follow these steps:
1. Make sure the dishwasher is unplugged or the breaker is turned off.
2. Open the door and remove only the top screws directly behind the control panel.
3. Remove the protective cover from back of the control panel to expose the main control board.
The thermal fuse should be mounted to the control board. If you remove it and take a resistance check, it should read close to 0 ohms, if good. If bad, replace as necessary.
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Mar 18, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
Correct procedurer for removal of door panels to remove wing mirror for replacement
three fixing screws under door pull two on the handle and one under the electric door mirror control
May 04, 2009 | 2000 BMW 3 Series
Front right door window will not go up or down, it is electric. it works, some times, and some times not. it is in the down position. Would like to move to up position. I live in Arizona, I need it up for...
does it act the same whether you use the driver door switch or the passenger door switch? Please rate as fixya if this helps. thanks
here's repair procedure
Window Regulator, Front Door, Explorer Removal
srk~us~en~file=ani_caut.gif~gen~ref.gif WARNING: IF THE REGULATOR COUNTERBALANCE SPRING MUST BE REMOVED OR REPLACED FOR ANY REASON, MAKE SURE THAT THE REGULATOR ARMS ARE IN A FIXED POSITION PRIOR TO REMOVAL TO PREVENT POSSIBLE INJURY DURING C-SPRING UNWIND.
  1. Remove front door trim panel and front door trim shield . Refer to Section 01-05B .
Trim Panel, Front Door, Explorer Hi-Series, Two-Door and Four-Door Removal and Installation
  1. Remove the two screws retaining the front door trim panel (23942) located above the window regulator handle (23342) . Also remove one screw in the upper front portion of front door trim panel .
  1. Remove inside door handle cup (22634) at the window regulator handle using a screwdriver or sharp object. Retention nibs will flex for easy removal.
  1. To remove window regulator control switch (14529) and outside rear view mirror control (17B676) , use notch located at lower end of outside rear view mirror control using a screwdriver to lift and remove.
  1. Remove outside rear view mirror control from front door trim panel pulling wire harness from inside of front door trim panel .
  1. From bottom of outside rear view mirror control, remove two screws and disconnect connector from switches. NOTE: Do not pull on the front door trim panel to remove clips from the inner panel holes.
  1. At each plastic clip location, pry the front door trim panel away from the door inner panel using the front door trim panel removing tool from Rotunda Moulding Trim Kit 107-00401 or equivalent. NOTE: Pay special attention to the cut-out in the door trim panel for the door handle, so that it clears the handle during removal without breakage.
  1. When wiring and disengagement of trim clips is completed, it is recommended that to remove panel, lift slightly to remove flange at the top of door trim panel from trough in the glass weatherstrip.
  1. Disconnect socket and bulb from illuminated interior lamp (13776) before total removal of front door trim panel. For installation, follow removal procedures in reverse order. Replace any bent, damaged or missing plastic clips on the front door trim panel to the front door trim panel , firmly loading clips into slots provided on front door trim panel .
    Trim Panel, Front Door, Explorer Hi-Series Four-Door
  1. Remove inside door belt weatherstrip and glass stabilizer.
  1. Remove front door window glass as described in this section.
  1. Remove two nut and washer assemblies attaching the equalizer bracket.
  1. Remove three rivets (manual) or four rivets (power) attaching the regulator base plate to front door trim panel finish panel (23712) .
  1. Remove window regulator electric drive and front door window channel bracket from vehicle.
  1. Working on a bench, carefully bend tab flat to remove arm slides from front door window channel bracket .
  1. Install new window regulator electric drive arm plastic guides into front door window channel bracket and bend tab back to 90 degrees. Use care not to break tab; if tab is cracked or broken, replace front door window channel bracket . Make sure rubber bumper is installed properly on new front door window channel bracket , if replacement is made.
Installation
NOTE: The front door window channel bracket and window regulator electric drive are installed into the vehicle as one assembly. The front door window channel bracket may be disassembled from the window regulator electric drive as described in Steps 7 and 8 of Window Regulator, Removal.
  1. Install front door trim panel finish panel with preassembled glass bracket into vehicle. Set the regulator base plate to window regulator electric drive using base plate locator tab as a guide.
  1. Install three (manual) or four (power) rivets (385189-S100) to attach regulator to front door trim panel finish panel . Two 1/4-20 x 1-inch bolts and two 1/4-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (3-5 ft-lb). Equivalent metric retainers may be used.
  1. Install equalizer bracket.
  1. Install inside door belt weatherstrip and glass stabilizer.
  1. Lower regulator arms to access holes in front door trim panel finish panel . Install front door window glass as outlined.
  1. Adjust glass to ensure proper alignment with glass run. Cycle glass for smooth operation.
  1. Install front door trim panel and front door trim shield . Refer to Section 01-05B .
Apr 20, 2009 | 1994 Ford Explorer Limited
Dishwashers Logo
52 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
