I have a Digistar HD LCD TV model LC-4010D. I have no remote for the TV. When I turn it on, the blue light turns on to show that it has power. But no picture or sound appears. It is currently plugged into a rogers cisco cable box but I've tried different cable sources. What do I do to get a picture?? Do I NEED a remote in order to use this TV or should everything work without a remote? Serial No. 766B00LC4010D000078
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 51 Answers
I'm not familiar with the tv set, however here are some things to try.
It's possible that the tv powers up in stand-by mode, so you'll need to find a way to turn it on completely. See if there are channel +/- buttons on the tv and try them.
If the remote might be necessary, try to see if you have friends/family with a universal remote control, such as a Logitech Harmony, to lend to you for testing. This way you can avoid spending money for nothing on a remote.
Googling on this brand and model gives a lot of negativity though: a lot of problems posting, but no support or even an online manual. Personally I've never heard of Digistar. It might've been a bad investment.
Posted on Dec 15, 2013
4 Suggested Answers
  • 98 Answers
SOURCE: My samsung TV won't show any picture/sound.
When the TV is on, need to check the back light is on(go back side & look into through)
If the back light is on -- need to exchange the Main Board
no back light -- exchange the Power Board --- 95%
exchange the LCD panel --- 5%(inverter)
Posted on Feb 06, 2009
  • 230 Answers
SOURCE: polaroid tlx-03210b lcd tv tv will not turn on
Yes I think that would be the problem, aswell as some dry (cracked solder joints). A bad cap is usually bulged on the top and looks like this:
http://www.auroracomputer.ca/images/bad_cap.jpg
hope this is helpful!
Posted on May 07, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
How to turn my TV back on?
are you sure the panel of LCD is not damaged?
Nov 09, 2014 | Televison & Video
Go to turn on tv and all I get is flashing red light and tv won't turn on. Was working the other day.what do I check?Sharp LC-26GA5U
Try unplugging the TV from the power point and leave unplugged for 5 min.
Or the batteries in the remote may be flat, try replacing the batteries.
If this doesn't work the TV may have a fault.
I hope this helps
MobileJB
Jul 13, 2011 | Sharp LC-26GA5U 26 in. HD-Ready LCD...
I have a Sharp LC-46E77UN TV. Remote will start TV green light on. No picture, just stays black. PVR is on and connected to TV via HDMI cable. Cannot turn off green light. Must use power button on TV and...
THe problem is in the set top box. Or common called the tuner box. IT looses the 5 volts to the main display and thus the monitor will go into a shut down state. THESE boxes are factory repair only and must be sent off to repair.
Feb 20, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Digistar PH-4210D Black Screen
Plasma tvs do not have "back lights" LCDs do. you probably have a bad driver board along with the upper or lower buffer board or maybe both, best to have a tv shop look at it.
Aug 30, 2009 | Televison & Video
Two light are blinkin' in from panel. and tv
This seems to be a common problem. I have the same issue. Repair man says its a power supply (he thinks). When the lights start blinking, press the power button on top of the tv (not the remote) and most of the time it will come on and work. I am going to try to replace my power supply and see if that fixes the issue. If so, I will update this post.
Aug 28, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Codes for 20" Digistar model tk2055d tv remote
THE BEST SOLUTION IS THE SIMPLEST ONE.
I suffered for 1 month shopping around for an universal remote control that has a code for the Digistar tv brand. It was in vain.
So just turn to the simplest way ..the programming with code search (on the guide of the universal remote control- which has not the code for digistar brand) In the paper it tell you exactly what to do. I bought a 3 device universal remote control.
On mine it showed five easy steps to follow and the remote finds itself the code and programs it .You do not put any code ever, the remote just simply WORKS perfectly. I have solved this problem just 5 minutes ago..Oh ...I forget..On the universal remote control instruction it said that you might have to press the ON/OFF button up to 200 times , so i thought "I never tried this one, better then waist days and months will no solution. I nedded to do it only for 30 times or so beffore the TV turned OFF, and than I pressed the ok button on my remote (probably to save it- or who cares-as long as you follow the instructions). Then I could turn back on the Tv and P{LAy with the remote without putting any code as the remote it programmed for the Digiistar brand..I'm so HAPPY...Try it and spread the "new"...It is Ironic ..it was there all the time...we look in more complicated zones and do not see the solution sitting under our nose:((:)))
GOOD LUCK!
Oct 19, 2008 | Televison & Video
Flashing red light
Same problem with my Sony. Unplugging for 36 hours solved the problem
Oct 05, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Need code
try code 238, if it does not work you will need to try the code search.
1) turn on tv
2) press and hold "code search" until indicator light comes on
3) release code search
4) press and release "tv", indicator light should blink once
5) aim remote at tv and press the power button until the tv turns off (you may have to press it 200 or so times)
6) once the tv turn off, press enter on the remote
Nov 17, 2007 | RCA RC-U703SP Remote Control
Televison & Video Logo
160 people viewed this question
Top Televison & Video Experts
