Question about Samsung Cell Phones
Turns itself off @ sometimes problem with switching the device on.
    New Friend:
  • 3 Answers
U need to flash ur cell phone. Then it will work properly...
Posted on Oct 17, 2013
I have an HDX Industrial size pedastool fan that turned on and off by itself. Is that possible!??? U have to turn the knob for it to turn back on. How is that possible for it to turn back on HIGH SPEED ,,,...
Hi Crystal,
There are several possibilities. I am not familiar with your fan.
One possibility is "touch" switching. This type of control uses grounding of the device (in millivolts). Sometimes an electrical circuit loaded heavily will trigger these switching controls.
Another is motor overheat. Many motors have thermal overload protection, so when bearings (for example) start to fail and put additional strain on the motor. During this condition, a bimetallic strip opens the circuit and allows the motor to cool, (rather than overheat and become a fire hazard).
Your final comment, however, makes me wonder about the switch itself. If you manually turned the switch to off, and the unit turned on, the switch itself is suspect. If it cannot be opened up and examined, just replace it.
Doc
Oct 22, 2014 | Cars & Trucks
Turn sig. Switch does not shut off when you make a turn?
you don`t say what kind of car you have. there are turn signal cancelling lobes on the turn signal switch and sometimes they are cancelling springs that are pushed back when turning to cancel the signals. sometimes they break and require replacing, sometimes you have to replace the signal switch itself.
Sep 23, 2014 | Cars & Trucks
Electric fire place switches itself off. Why ?
If it only switches itself off when the heater is turned on, it is most likely an overheat-temp-sensor that is doing it. If you have had the fireplace for over a year, you may want to do a complete clean/vacuum etc of the unit. A decrease in airflow can lead to the temp sensor tripping. If that does not work, you should contact the dealer for service.
Mar 08, 2013 | Heating & Cooling
Fan just quit working one day. Nothing happens when I turn the light switches on and off.
Is it powered thru a light switch? Sometimes those do just quit. You can remove the old switch & replace it. Go to Lowe's/Home Depot, the switch itself is fairly inexpensive (probably less than $5). Remember to turn off the breaker to that room/switch before you do anything. The installation itself is simple - just wire + to + and ground it. Did you notice any kind of noise/smell before it stopped working? If the motor is burnt out - just replace the whole fan (unless you feel like tinkering with breaking it down & finding a replacement motor). Sometimes the lite switch on the fan itself will go out - parts for that can be found at about any larger hardware store, but sometimes that's not an easy repair (depends on what type of lite kit is on the fan). However, if that were the problem -it would not cause the blades not to turn, it would only keep the lights from coming on. Try replacing the light switch that turns the fan on/off first (the one on the wall, not on the fan itself) - hopefully that'll solve it for you. Good Luck.
Jul 13, 2011 | Hunter Fan 21623 Concert Breeze Ceiling...
PS3 Console switches on for no reason. I turn it off and sometimes 5 minutes later, sometimes 4 hours later it switches itself back on.As it is connected to the TV by HDMI it switches on the TV as well....
glenn_caroli
What most likely is causing this is another device grounding back to the PS3. Note with modern electronics they have contact switches. The work by competing the circuit to turn the device on or off.
So to test to see if it is a device causing this or an actual problem with the PS3 is to unplug all connections from the system. This includes your HDMI connection. At this point all you should have plugged in is the power cable.
Let the system set to see if it turns on. If it does not then we know it is not the PS3 that is the problem. Next start adding back in the other device until you figure out which one is causing the problem. Note I have had seen several cases where people had bad HDMI cables so you might test those first.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Aug 09, 2010 | Sony Playstation 3 (PS3) Console
Goes by itself and doesn't stop until it's turned off.
Undo the foot control and see if you have a little square thing in there call a suppressor, if you have then take it out and discard it
Mar 16, 2010 | Singer 7436 - INGENUITY
Olevia HDTV 26" Turns Itself Off and Now Will Not Turn On At All
I doubt the switch is at fault, a worsening power supply failure is much more likely.
There are several million components in circulation (capacitors) that have defective chemicals in solution and there are seemingly unrelated electronic items crapping out all over.
The faulty electrolyte was made in China after the formula was stolen from Japan and poorly copied.
The stuff was sold to several Asian manufacturers of the capacitors and used in a broad range of devices.
We'll be seeing many more failures before it gets any better.
Sorry-
Jun 08, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Tv switches off
set goes on 20 seconds it goes off
Feb 24, 2008 | RCA TruFlat 27F520T 27" TV
Cell Phones Logo
13 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
