Question about Vacuums
Kenmore powerhead on the bottom of the upright the bar which you adjust has come off with a plastic thing , i cant figure out how to put it back on
    Sergeant:
    Champion:
  • Vacuums Expert
  • 357 Answers
Take it to your friendly neighborhood vacuum professional and ask for help.
Posted on Oct 21, 2013
4 Suggested Answers
SOURCE: Whispertone powerhead handle release replacement
Take a butter knife and/or flat head screwdriver and press forward on the four tabs that retain the pedal.
Posted on Jun 02, 2008
  • 66 Answers
SOURCE: beater bar won't turn--belt still but off of shaft
there is a reset button under the handle its gray and has a brush pic by it this should rest it.
and as far as puting the belt back on try going from the bottum plate it should just unscrew the four to six screws and pull it off hope this helps
Posted on Jan 25, 2009
ginko
  • 19396 Answers
SOURCE: sears progression kenmore canister va. Model
Hi.
The part is probably available as replacement.
Please click here to access part list and diagrams, and check if the part is available.
Regards.
Posted on Mar 03, 2010
Remove bottom of electrolux prolux upright vacuum. Hose is clogged.
You shouldn't have to remove disassemble the powerhead.
Lay vacuum on it's front. Between the tank and the powerhead is a black flex hose. Pull the end straight out from the powerhead. Then unscrew the tube from the tank using a clockwise turn. Remove the tube and visually check for clogs and splits. Clear or replace as needed.
If there's a clog in the powerhead behind the brush, this can be cleared using a wooden spoon handle or similar object.
If there's no clog in either place, there's a couple other possibilities. First, turn the vacuum back upright, open the hose flap, turn vacuum on, and place hand over opening to check for suction.
If there's a lack of suction, the bag needs replaced, the afterfilter beneath the bag needs cleaned, or the motor needs replaced.
If there is suction, put a coin in the opening inside the port and to the right as you're viewing the front of the vacuum. The coin should drop to the floor. A clog in thes section is unusual, but can happen.
If there is still no suction, take the vacuum to the nearest authorized Aerus Electrolux store for free diagnosis.
http://www.aerushome.com/storelocator/
Mar 11, 2011 | Electrolux Vacuums
How do I change belt in power head? Is there a
There could be 2 different ways to access the belt on the kenmore line of powerheads...
1) turn the powerhead over so that the bottom is facing up. IF there are screws on the bottom, remove them. There should be 2 either at the back where the rear wheels are, or one under the elbow, and one midway at the front under the lifter wheels. remove the screws, and there should be two tabs on the sides to remove the top cover. OR 2 tabs at the back of the unit near the screws to remove the top cover.
2) and this is the more common powerhead...
remove the light cover for the powerhead by pressing at the two sides and pulling the cover up. sometimes a screwdriver to pry open a little will help.
Remove the light bulb.
Remove the two screws.
Turn the head over and pry at both sides to pull the top cover off.
Good luck with either one.
Nov 18, 2010 | Kenmore Vacuums
Beater bar will not turn, think belt is broken, but do not know
the model number of the powerhead would be helpful - usually there is plastic cover with a lens for the light, push inward on both sides and the cover will pop offthere are two screws under that OR, there are two screws on the underside of the unit - it just depends on the style
Aug 18, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Can I buy a replacement powerhead for a Kenmore Magic Blue?
Power bar spins, but as soon as it't put on the carpet the beater brush quits spinning
Aug 11, 2009 | Kenmore Magic Blue 24195 Bagged Canister...
Kenmore Upright vaccuum self-propel won't work/engage
No, I can't solve it. However, if you go to SearsPartsDirect.com you can find diagrams for this vacuum. There are three. You can click on "View full size", highlight the image, and print it by saying "Print selection" in the Print dialog box.
Perhaps by looking at how the thing is put together you can begin to figure out where the trouble is. You can also order some of the parts for this venerable machine (but not all of them.)
John
Indiana
Mar 21, 2009 | Kenmore Vacuums
Hight adjustor does not work...
I think we got this figured out . . . . the height adjustment doesn't work when the vacuum is UPRIGHT, but when you disengage and lower the handle the plastic that is blocking the wheels from receding will rotate and then it can receive the plastic on the "top" of the wheel assembly. Try it and I think you will find that it works. I thought it was the wheels that were keeping the vacuum from working well, but that's not the case. Still don't know why it's gone to heck in 9 months.
Dec 29, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Hoover Windtunnel Bagless bolt fell off
With this self propell series, the entire bottom needs to come apart to re-install the nut. if it is one month old I would highly recommend taking it in for warranty service. What plastic is melted?
Nov 02, 2008 | Hoover U6630-900 WindTunnel Bagless...
Use a flat blade, it just prys off, a new on will press on.
May 24, 2008 | Kenmore 23313 Whispertone Bagged Canister...
How to put the belt on ?
first things first...take the powerhead off of the front of the kirby. If you look at where the powerhead connects to the front of the kirby and you'll see a large hook...turn the hook using the crank on the front of the powerhead so that the belt is pulled up and away from the brushes. (OFF position) The hook stretches the belt so that it can fit over the fan driveshaft (its the finger looking thing that sticks out of the front of the kirby when the powerhead is removed.)
Next, place the two "feet" of the powerhead onto the "perch" located on the front of the kirby (under the driveshaft opening)....lock it on by turning the silver lever on the top of the kirby (the one under the hood/light)
Now spin the knob on the front of the kirby from off to on. This releases the belt from that hook in the powerhead so it can rest on the driveshaft. Off means the belt is off of the drive shaft and the brushes won't spin. On means the belt is on the driveshaft and the brushes will be spinning. But remember, the belt has to be stretched open on that hook inside the power head BEFORE the powerhead is placed on the front of the kirby. Otherwise the belt won't be connected to the spinning driveshaft, and the brushes won't spin
Dec 06, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Vacuums Logo
15 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
