Question about Christian Audigier Watches
Watch is not working - Christian Audigier Watches
Casio CPW-500H-1AV analog watch not working
That certainly wouldn't hurt - be sure you use good new batteries.
Aug 06, 2014 | Casio Watches
Put in new battery and watch will not work. Also put working battery in and still will not work
I realize this is not strictly a "fix", but if you have a watch with a problem it is best to take it into a professional. Watches (especially analogue watches) have many small, intricate pieces in them, that only professionals have training and tools to work on.
Nov 30, 2013 | Android Ceramic Watch with Sapphire...
Eco drive watch not working
Watch is not working had watch in window seal for the whole summer still not working
Feb 24, 2013 | Citizen 8700 BL8000-54L Wrist Watch
The watch is self widing. ait just stopped working
Yes I do. Don't try to fix your watch.
My watch maker friends have told me that generally speaking, the reason most self wind mechanical watches stop is: (1) they need cleaning or (2) the screw that holds counter weight in the watch (that actually does the winding) comes unscrewed. He said most of the watches that have been worked on by the customer have lost the screw.
My advice remains have your watch looked at professionally.
Any other concerns my friend?
Jan 14, 2010 | Watches
Seiko flightmaster fitted new battery watch wont work atall
Most likely the watch was damaged when the battery was installed. Quartz watches have fragile parts in them. The coils for instance are made of wire thinner than the hair on your head. It takes almost nothing to damage these wires and the coil. Dirt is a big problem. Since a quartz watch has no force behind the gear train the smallest particle of dirt can stop a quartz watch.
Either your watch will need a cleaning or damaged parts will need replacing.
A qualified watchmaker can do this work and get your watch back in working order for you.
Hope this helps,
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Oct 31, 2009 | Seiko Diver's Watch
Watches not working
good day,
hope this link below will solve your problem.
watches
Mar 25, 2009 | La Crosse Technology E. Howard Ambassador...
My watch has stopped working
mcdevito75 here, Unless you have a good knowledge of takeing apart, even just the back off your watch / pocket watch it"s best to look for a small watch repair shop in your area, but here is what you can do to possibly start your watch / pocket watch. If your watch / pocket watch hasn"t been wound in some time and that time varies from watch to watch, the oil in the watch can become a bit thick so as to not allow the mechanism to work smoothly, leave the watch / pocket watch in a warm place, window sill in the sunlight wrapped in a paper towel for anywhere between a few minutes to 1/2 hour, after the watch / pocket watch has been warmed up hopefully the oil in the mechanism has liquified enough to allow the movement to start working. You can also give the movement a little boost, after the watch /pocket watch is warm, pull out the stem as if to set the time of day, move the stem and hands, sometimes this action will get the watch ticking again. If this fails, BEST BET specially if this is an expebsive or keepsake watch, look for a small watch repair shop in your area for serviveing. approx. $45.00
Mar 19, 2009 | Colibri Mechanical Collection Pocket...
Watch new battery installed still wont work
First you have to check if the battery is on full power, as sometimes even brand new batteries are underpowered. Good battery should have 1.54 - 1.57 Volts of charge.
If battery is ok and watch still not working - get the battery out and clean (scrape) all battery related contacts with steel needle untill they are shiny. Use the dust blower to get rid of cmall dirt particles.
Replace the battery. Now the watch should work.
If the watch doesn't work after cleaning contacts, then this is mechanical fault and you will need watchmakers help.
Do not forget to rate, please.
Feb 03, 2009 | Bulova Watch
New watch has stopped
There are a few possible reasons why your watch is not working:
  1. The battery is dead (sometimes even new watches have a dead or dying battery in them).
  2. The plastic piece between the crown and the watch case was not removed (this protects the battery from wearing down until you receive the watch).
  3. You bought a watch with a damaged movement or somehow damaged the movement through usage and it just will not work period so you may have to return it, exchange it, or have it repaired
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
Jan 13, 2009 | Watches
Can't get my croton watch to work.
  1. The battery is dead (sometimes even new watches have a dead battery in them).
  3. You bought a watch with a damaged movement and it just will not work period so you may have to return it, exchange it, or have it repaired
Jan 05, 2009 | Croton Watches
Watches Logo
20 people viewed this question
Top Christian Audigier Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Christian Audigier Watch Expert? Answer questions, earn points and help others
