Question about Garden
Husqvarna 455 rancher chainsaw - you can start the saw run it for 3 mins it then cuts off and then wont start back till cooled off. whats the problem?
    Sergeant:
  • 322 Answers
Check the ignition module. as the saw heats up it causes the inside of the module to expand which causes it to stop producing spark. when it cools off it makes contact again and starts working right
Posted on Oct 17, 2013
spekgt
  • 60 Answers
SOURCE: 455 rancher chainsaw does not pump oil to the chain
If you look under the machine by the chain you'll see a flat head screw (next to the sprocket) which controls the bar and chain oil flow . Try to turn the screw and check if there's any oil flow to the chain . If not you will need to replace the oil pump (part # 537 10 55-02 which will cost you about $35.00) Hope this help
Posted on Aug 29, 2009
dontbother10
  • 2220 Answers
SOURCE: Fuel Mixture Husqvarna 455 Rancher Chain Saw
Page 17 of your Operator's Manual says 50:1.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Posted on Sep 25, 2009
dontbother10
  • 2220 Answers
SOURCE: What is Fuel Mixture Husqvarna 455 Rancher Chain
Duplicate post Close/delete
dontbother10
  • 2220 Answers
SOURCE: magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 22, 2010
dontbother10
  • 2220 Answers
SOURCE: , No.455 Rancher, 20" Gas - Powered Chainsaw: What is the oil mixture ratio for the Rancher 455...
50: 1; You can download an OM here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years and is what Husky suggests for your saw..
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 10, 2010
Trying to find the correct compression for a Husqvarna 455 Rancher chainsaw?
you wont... as per husky anything under 110 would be suspicious. I have seen those saws with the lower piston ring gummed up from a rich fuel mixture.
Nov 29, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 rancher new filters /plug get spark wont start put gas in cylinder and wont start what am i missing
Check to see if there is a leak in the air purge bulb (primer bulb), sometimes they crack and allow air in and don't push the gas through properly. Here is the manual for your saw.
Cheers!
http://www.manualslib.com/manual/514275/Husqvarna-455e-Rancher.html#manual
Sep 10, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
How to change the fuel line on a Husqvarna 455 Rancher
feed a wire threw the tank cut the new hose down to 1/3 about 1/2'' long slide it over the wire and pull it back till it pops threw then pull it threw
Aug 09, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
50to 60 compression on a husqavarna 455 rancher chain saw. Ring job and how hard?
455 is an X Torq engine, this means it runs very cool on the inlet side of the piston, they are quite prone to gumming the ring in if they have been used on a heavy two stroke mix, due to the designit is a full machine strip down to get to the piston, skilled man 3 hours to strip and rebuild.
Sep 07, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
455 rancher runs for about 5 min. than stalls and wont start until cold than problem repeats
Sounds like a fuel problem. Something might be expanding as the saw warms up and is cutting off the fuel or introducing an air leak. Carby may require a new kit and check the fuel line
Jan 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
My 455 Rancher Husqvarna 20 inch chainsaw wont stay running while idling. its a brand new saw. don't know if it needed to be adjusted or if its pre adjusted already. Starts and runs fine but just won't...
Carb adjustmwnt requires a special tool and a tacho, the saw is set from the factory for the best emmisions, however it may need a small adjustment, this should be done by a qualified dealer, incorrect adjustments can damage the engine.
Jan 02, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Lou
Mar 22, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a 455 rancher i have spark (dont know if good spark) and gas new spark plug and air filter and it wont start.
Check to see if your ignition switch ( on& off) switch still have both wires attached. Common problem with that saw, loose or disconnected wire
Aug 16, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
What size file to sharpen chain for 55 rancher
It depends on the chain you have installed on the chainsaw. You can look at the numbers stamped on the drive link side of the cutting chain and it should have a 2 digit number that correlates to the size.
The factory chain supplied with the #455 rancher was a .325" pitch 3/8" chain.
Here's a link to the specs for your saw with some useful info
http://www.husqvarna.com/us/homeowner/products/sawing/chainsaws/455-rancher/#specifications
Hope you found this very helpful and best regards!
Aug 06, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
