Question about Staples USBtoSerial Adapter (18762) Serial Adapter
ERRO 8020 WHEN USING ADAPTER FROM SERIAL TO USB
Usb serial driver
What is the brand of your USB to serial adapter, and what OS are you using?
Oct 06, 2013 | Staples USBtoSerial Adapter (18762) Serial...
Hi! What cable/adapter should I buy so I can use foot pedal in my laptop using USB? Foot pedal is 9-pin, used for transcription. Thank you.
The following link should meet the requirements assuming your existing cable is defective.
http://www.monoprice.com/products/product.asp?c_id=103&cp_id=10311&cs_id=1031104&p_id=2276&seq=1&format=2
Feb 28, 2011 | Sabrent USB to Serial (9-pin) DB-9 RS-232...
I have a Entrega Parrall to USB adapter, can I use it with Windows 7?
As long as you have the drivers for whatever peripheral you're using with the adapter, you should be able to use it.
Jul 20, 2010 | Entrega (CON-USB-S25) Serial Adapter
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
The computer does not recognise the adapter
You need to isolate the problem. You may need to connect the USB-Serial adapter into different USB port of your computer or you may want to try connecting it into different computer. If you get the same problem after using different computer, you may need a driver for it. Or it could be defective.
Have a great day!
Jul 09, 2009 | Belkin USB/Serial Portable Adapter...
I need a Vista driver for the USA-19QW Serial Adapter
I have an old 4-port Keyspan serial device that also doesn't work with Vista.  Unfortunately Keyspan didn't provide Vista drivers for some of the older USB to Serial devices before they were acquired by Tripp-Lite, so you will probably need to get a replacement (Keyspan usa-19hs has Vista support, that one works for me).  The support page for Keyspan USB devices is here: USB Connectivity & Device Servers
Apr 20, 2009 | Keyspan (USA-19QW) Serial Adapter
Connecting my computer directly to konica 8020
You can hook the copier directly to your computer using a USB cable.  You can purchase one at any computer store.
Oct 20, 2008 | Office Equipment & Supplies
Staples USBtoSerial Adapter (18762) Serial Adapter Logo
Top Staples Computers & Internet Experts
edoco
Level 1 Expert
_-__-___-_
_-__-___-_
Tom Chichester
Are you a Staples Computer and Internet Expert? Answer questions, earn points and help others
