Question about GE JGBP32WEFWW Gas Kitchen Range
Jgbs60d how do I adjust the oven temp thru the user interface?
    Top Expert:
  • GE Master
  • 9,472 Answers
It is not adjustable. You will need to replace the temp. probe in the unit. Here is the part to order.
Posted on Oct 20, 2013
Testimonial: "thanks"
Why doesn't it heat to set temperature?
Hello. In most ovens with an electronic control, the temperature is regulated by 2 things--the sensor and the oven control board. The sensor is simply an electrically resistive device that changes resistance as the temperature increases or decreases. It is connected to the main control board by 2 wires(just a "pigtail") and the main board is supposed to be calibrated to adjust properly. Most control boards have a built-in program by which you can adjust the calibration +/- 35 degrees. If your oven is outside that range, and you're sure that the sensor is good, the connections are good, etc., then the oven control board temp control circuit has gone bad. Keep in mind, when you turn on an electronically controlled oven, the first time it heats up is USUALLY hotter by about 50 degrees--this allows the floor, walls, and ceiling to reach proper temperature. This is called the initial spike. In gas ovens, the user must wait approximately 8-10 minutes AFTER the oven beeps to cook anything. In an exposed-element electric oven, the user waits approximately 10-15 minutes after the beep. In the hidden bake element models, waiting 20-25 minutes after the beep is normal!
Also, keep in mind, ovens can have 60 degree temp swings higher and lower(as long as the midpoint is close to the chosen temp) I hope I've helped you!
Sep 15, 2015 | Kitchen Ranges
How do I access the menu on my oven control board to adjust the temperature?
Do you have the user manual? The mfr should gave this available. Google your model and you may get some help there. I have had great success there.
Dec 20, 2014 | Ovens
Oven runs hot not responding to temp knob.
refer to your use and care manual and there is a section on adjusting/calibrating the oven temps. tip do not use a small thermometer from the grocery to adjust your oven. buy a decent digital style...... then turn you oven on and let it cycle 3 times, that is elements come on then go off = 1 cycles. then watch the temp scale. record the temp when element turns off,,, then them temp when it turns on. add the 2 temps together then divide by 2 and that gives you the temp the oven is maintaining. then adjust accordingly. DO NOT ADJUST PER THE HIGH OR LOW TEMPS. use the middle temp as described.
Jan 31, 2012 | Ovens
I have a JT955 GE Profile 30"double oven...when the food is cooked, and I press "clear/Off", the oven won't shut off...continues to maintain temperature? Tonight, I had to shut it off,...
Your wall oven has two main components that control the oven. The main control computer and the user interface. Your problem is probably in the user interface, although it could be the main control or both. I have had some success cleaning the ribbon that connects the user interface to the control with a little rubbing alcohol. That only works some of the time though. Due to the fact that the oven works except for the cancel button I would lean towards replacing the user interface if cleaning the ribbon dose not work.
Aug 29, 2011 | GE Profile JK955SFSS Electric Double Oven
Shortly after end of 1 year warranty, KEMS378SSS04 began displaying F6E0 Lost Communication on lower over UI (not on the microwave). Turning power off/on (multiple times required sometimes) fixes the...
Below is the complete instruction sheet.
You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic
mode and verify the error codes. Ensure AM software, UI software and EEPROM
CHECKSUM versions appear on the lower text line. If AM software and EEPROM
versions do not appear, UI and AM may not be communicating. Verify this for the
lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show
the AM software version for the lower oven appliance manager, and the microwave
UI will show the AM software and EEPROM versions for the microwave appliance
manager.
If the lower oven UI is not displaying the AM software version, go to UI IS NOT
DISPLAYING AM SOFTWARE VERSION.
If the upper oven UI is not displaying the AM software and EEPROM versions,
go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND
EEPROM VERSIONS.
If lower oven UI and microwave UI are both displaying an error, go to LOWER
OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
UI IS NOT DISPLAYING AM SOFTWARE VERSION:
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully
inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the
lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between
P6-1 of the appliance manager and P2-1 of the user interface board.
Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to
P2-5(UI). All the measurements made should be less than 5 ?. If any of
these measurements exceeds 5 ?, go to step E.
D. Replace the appliance manager. Ensure all connectors are properly inserted.
E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
F. Replace all parts and panels before operating.
G. Plug in oven or reconnect power.
H. Observe for longer than 1 minute to determine if error has been repaired.
I. If error does not appear, initiate a bake cycle. Let the cycle run for at least
1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step A.
At step D, replace the lower oven user interface board if appliance
manager has already been replaced.
- If both are replaced the problem has been repaired.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 22, 2011 | Ovens
Oven cooks 10 degrees cooler. How can I fix it?
select bake
set the oven to 550 degres
hold the bake button until you see the temp go to zero
push the temp select up until it changes in five degree increments to the desired bump up in temp you can raise it or lower it up or down by 35 degrees in five degree increments, once you have the desired adjustment it will revert back to normal on the controls screen readout
check the oven temp and adjust as necessary, this info is available in your users manual as well.
Jul 14, 2009 | Maytag MER5775Q Electric Kitchen Range
Kenmore Elite Oasis HE Top Loader Washing Machine
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
The part number for the user interface for this model is 8564374.
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
The procedure for replacing this control board is shown in the images below.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the washer first.
http://media.fotki.com/1_p,wkgbsdrbswtkdqwxgtqsskgwtqkq,vi/ksgtwdgrtxkrrffsdss/1/1303472/5961857/image29464img-or.jpg
http://media.fotki.com/1_p,sqrbbsbrrbwrbdtxgtqsskgwtqkq,vi/kbqtdwdswxkbswddwbg/1/1303472/5961857/image23056img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 18, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
American Range ar6b-24rg
If you oven temp is off by +- 50 degrees, thermostat needed to be change. to check and adjust the oven thermostat usually we place the oven thermometer in the center of the oven, run the oven at 350 degrees for minimum 30 minutes and check the oven temperature, It should be +- 25 degrees, if it needed adjusting, there is the adjusting slot screw in the center of the thermostat stem, to adjusting it ( do not turn thermostat stem during adjusting ), turn adjusting screw counter clockwise to raise the the temp, clockwise to lower the temp, turn it a little at a time and wait 15-30 minutes before do the next adjustment until the temp match with the oven knob. To adjust the oven burner air and gas mixture, first turn the air shutter close, you will see yellow flame, then open the shutter until the yellow flame disappear and them open it a little more, now you are done. For the oven uneven cooking? you may have a bad oven burner tube, during operation some of the flame may be lift off, disappear or flame being uneven, you can check it with the kick panels off to see the flame, if these are the case, you needed to change the oven burner tube,
Feb 04, 2008 | American Range AR-4B-36RG-CL Gas Kitchen...
GE JGBP32WEFWW Gas Kitchen Range Logo
49 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
