Question about JVC TH-A85 System
Hi, I've a problem with audio outputs from the sub. Specifically the front-right audio out plays both front-right and surround-right audio out while surround right out does not play anything. Can you help me?
    Master:
  • 359 Answers
Do you have your receiver setup for 5.1 and not stereo surround? It sounds like it does not have 5.1 enabled. Look in the manual to see how to configure for 5.1 surround. You should have separate audio configuration setting for each speaker.
Posted on Oct 18, 2013
Sorround speakers not working though connected correctly
Without knowing exactly what your problem is, perhaps you are not playing sound that was recorded in at least 5.1 format. A DVD or BluRay will indicate the format on the cover. The data is decoded and split into (for example) six discreet audio channels. Left front, Centre front, Right front, Surround Left, Surround Right and LFE (Low frequency effects) If you are playing a standard stereo audio disc, then the sound will only be heard from the front L&R speakers, which are expected to be full range speakers. You can, however choose an audio configuration that also provides a signal for the SUB (LFE) and even a pseudo surround. If you want more info I'm happy to help. Just tell me exactly what sound source you are playing and we can work it out.
Cheers for now, Don.
Feb 19, 2015 | Denon AVR-1804 Receiver
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Hello I have another question but this is containing my back up surround sound receiver til I can find a Sony receiver that I like. Ok this receiver is a AV receiver model ht-r420 onkyo surround sound...
Subwoofer sockets
The HTR-420 has only a single subwoofer output. It is the socket on the lower left corner. The other subwoofer socket is part of the multi-channel input.
Because of the age of the 420, it comes from a time when optical and coax connections were not so common and DVD players had 6x phono/RCA sockets to send out the surround signal in analogue format. The multichannel input is for sending a signal in to the amp, and not for getting a signal out. That's why the sub doesn't get a signal from that socket. Use the proper subwoofer out. That's what it is there for.
Speakers A+B
The 420 was designed to run Speakers A+B together if required. However, you must observe the minimum impedance loading if you connect up two sets of front speakers and run them simultaneously.
The minimum Impedance for each set of front speakers is 8 Ohms. If you're recycling old surround speakers from a Home-Theater-in-a-Box system, or the speakers have no labels for impedance on the backs then you can be fairly sure they are not 8 Ohm. That could be the problem.
Sep 09, 2014 | Audio Players & Recorders
Low sound output from Front Speakers
The out put transisters are probally fried for the front channels,
Nov 27, 2012 | Sony STR-DE695 Digital Audio/Video Control...
Sony CMT-GP5 subwoofer output very quiet
From the description the subwoofer is the problem, since the item is new return it to the place of purchase, this is a manufacture issue.
Aug 13, 2012 | Sony CMT-GP5 CD Shelf System
Unable to connect surround sound with a stero player
There is a obvious difficulty here. If you have a stereo receiver then it can't produce surround sound. You must have a surround sound receiver to present true surround sound. If you already do have that then on the back of your Phillips set there are audio outputs. The left and right audio out will be decoded in your surround sound receiver and they will automatically play from your speakers. You should have seven speakers, center channel, left and right front speakers, left and right rear speakers and left and right mid or side speakers. A sub-woofer would be nice too. Best bet is to speak with the store you purchased the set from. They will have that information.
Zashiban
Jun 23, 2010 | Philips Televison & Video
I got a teac ag-v8060 audio/video surround receiver and I'm tryin to hook up some surrounsound speakers along with a jbl g cinema sub can you describe where the wires go in the back of receiver? The sub...
On the back of the receiver, there could be "pre out-subwoofer". If your subwoofer has the same type cable input, that would indicate it is a powered(amplified) sub. Connect those two. If subwoofer only has red/black speaker inputs, it is a passive sub, which means spkr signal runs thru it and then to your main left and right spkrs.. Run your receiver main or front spkr left (red/black) and right (red/black) to those corresponding sub inputs, and then sub spkr outputs to each of your main left/right spkrs..
For surround, on the back of the receiver, there should be spkr outputs (red/black) noted as "rear".
Just make sure red to red, and black to black.
Hope this is helpful.
Apr 28, 2010 | Teac AG-V8060 Receiver
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
5.1 surround not working
adjust your sound outputs with the remote and adjust the +/- settings on them and ten try another sound output adjust the stero effectsand try playing around with that and try cutting the speaker cable back about 2 inches and using a new peice of the cable to see if it's the cable causing the issue.
Dec 31, 2007 | Yamaha HTR-5730 Receiver
JVC TH-A85 System Logo
49 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
