Question about Samsung RF4287HARS French Door Refrigerator
Samsung french door refrigerator ice paddle broken
elbozi
  • 4 Answers
SOURCE: Samsung french door ice maker
Check my solution here. The noisy sound is the swing arm trying to knock out some stuck ice.
http://www.fixya.com/support/t1141317-two_issues
Posted on Oct 31, 2008
carlsbiz
  • 1124 Answers
SOURCE: My icemaker in my large French door Samsung
There is no way to speed it up..
If the bucket is empty - 2 to 3 days to fill is normal..
It takes somewhere around 37 minuets for new cubes to freeze,, then dump.. Cant make the ice freeze faster..
If it has a inline filter on the water line - replace it.. If it is clogged it could slow the water that is going in..
If you-all use allot of ice and empty it before it catches up - I would suggest getting a bag of ice from the store and put some in the bucket to keep the ice level up..
Have a nice day...
Posted on Sep 08, 2009
  • 1891 Answers
SOURCE: Samsung French Door Refrigerator not cooling
it's only 4 weeks old ./ don't mess with it it has a warranty you may void it if you work on it . it is probably in the main digital control in th fresh food .. but i would call the seller and they can set up a service for it .. mm
Posted on Dec 24, 2009
SOURCE: Front ice/water dispenser stopped working.
I had the same problem. Turned out to be a microswitch under the lever used to activate it. The microswitch fell from the original position so it wasn't turning on anything. I tried gluing into position but the fumes from the crazy glue messed up the switch and I had to replace the whole rig.
The part is under the control display. You can pry it open from the left side.
Posted on Jun 04, 2010
  • 122 Answers
SOURCE: I have a Samsung RF267ABRS
If you hear a clicking sound sometimes, it is your ice maker. Replace ice maker, all you need is a short phillips screwdriver. Remove ice bucket, to the left you will see a philllips screw holding a long plastic panel going all the way to the back, remove the screw and the panel, it has clips that slilde in, unplug ice maker and push down on tab on top of ice maker and pull out
Posted on Sep 03, 2010
Model # RF4287HARS/XAA
No it's a whole assembly the plastic clip is broken. Give me a model number I'll track down the part for you.
Oct 05, 2015 | Samsung French Door Refrigerator Right...
Samsung french door freezer will not open
Aha!
The Samsung wants the password.... in French! No!
Sorry.... couldn't resist....
If it's iced up then that would hold it shut until it melts.
Icing up is usually caused by a bad seal!
Sep 18, 2015 | Samsung RF217ACPN - 20 cu. ft. French Door...
Can this ice maker be set to make more ice? And faster?
Icemakers cycle cubes from the air temperature inside the freezer so you can't do much to increase speed except adjust the freezer control colder. As to the bucket not filling, most icemakers have a feeler arm or plastic paddle that is suppose to sense the ice level in the bucket. Make sure the feeler arm or paddle at the bottom is free and no sticking or hitting anything. It needs to move freely ask the icemaker dumps the cubes. If your refrigerator is less that a year old it should be under warranty and a free repair to you.
Apr 30, 2015 | Samsung RF4267HARS Stainless Steel French...
Samsung model rf4287hars only dispenses water when ice lever depressed
3b662ccb-018c-4390-ab7a-74a2025960df.jpg 3d562c7f-18a6-4fa7-9993-373c8c5d3c7f.jpg 763378c4-5f13-435a-aac3-b67d9041b031.jpg
First photo shows paddle assembly that can be purchased you need to got to Sears web site to find part # other wise you will have to buy the whole circuit board assembly hundreds more than the paddle assembly. The circuit board and paddle assembly is removed buy removing screw on inside of door and pulling it out be careful it seems strange but it just pops out. The paddle assembly slides on to the circuit board assembly look close and take your time to slide it off I thought I was going to break mine but did not and save me big money.
Second photo shows tab for water dispensing still there.
Third photo show ice dispensing tab broken and missing.
If you leave the assembly plugged in press the micro switch for the ice dispenser and see if it works most likely the tab has broken and is what hits the switch telling the door to open and ice dispensing screw to push ice to the door. Hope this helps
Mar 04, 2014 | Samsung RF4287HARS - 28 cu. ft. French...
Ice and water dispenser stopped working
Welcome to the computer world. When depressed, the paddle actuates a switch attached to the bracket above. The switch sends a low voltage signal to a small circuit board mouted right behind the display. A computer chip on that small board communicates with another chip on the main control board mounted in the rear wall. Your situation could be a bad actuator switch, a broken paddle tab, possibly a bad door switch (the fresh food doors must be closed to dispense), or a bad electronic control.
Jun 05, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
LG wont dispence ice
hi there,
sounds like you have ice in the ice bucket. it's most likely that the ice paddle is jammed or broken. check around the ice door and paddle for anything visibly broken as well. you may have to replace the ice paddle.
Sep 30, 2008 | LG LFC25760 French Door Refrigerator
Samsung RF4287HARS French Door Refrigerator Logo
95 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
