Question about Refrigerators
How to you remove the control panel from a GE Adora DFSS9VKBSS model? I need to replace the ice route case assembly unit. Any video of similar posted there is a trim that pops off. Not in this case though. There is a single screw that I removed under the panel, but the control panel seems to be intertwined with the curved panel that sits below it. I don't want to dent up the finish. Is there a trick to getting these pieces apart?
Techsim
  • 59 Answers
SOURCE: ice dispenser flap does not close after ice comes out
The trim on this model doesn't need to come off. Instead pry the control (with the buttons) panel off to expose the screws. the control panel has a small wire harness to it that is easy to disconnect. Let me know if you need more help. Good Luck!
Posted on Dec 28, 2008
stevefoobar
SOURCE: Replacing Defrost Heater and Bracket in Freezer Section of Fridge
I ended up having to remove things in this order: all shelves, ice maker insert, ice maker top ice tray, ice maker lower motor housing, shelving support rails (2), rear evaporator coil cover. This exposed the evaporator coils (which were already dry since the fridge had been off for two days) and most importantly, the defrost heater element below the coils. The heater element was easily unplugged from it's two connectors. I tested the unit with an ohm meter and it indicated it was open (infinity resistance). I then knew it was bad. I replaced it with a new unit and put everything back together in reverse order taking care to use the same screws. The fridge appears to be back in working order.
Posted on Oct 19, 2009
Sea Breeze
  • 4654 Answers
SOURCE: WR55X10415 on GE None of the panel lights are on. no water no ice
Before you go too far lets check the wiring harness. Your model is a Profile or Artica and model number? I would not buy anything until I traced out the wiring. You may have plulled the pinplug at lower left hand of door near floor and behind kick plate. Sea Breeze
Posted on Mar 20, 2010
SOURCE: How to remove front panel from ge ice maker model PSS26SGPASS
If you are talking about the ice/water dispenser palnel, on my PSF26NGPABB Arctica it just pulled off. there is double sided tape all the way around it and I used a thin, sharp knife to cut it as I pulled the panel off.
Posted on Dec 28, 2010
rockmeister
  • 2047 Answers
SOURCE: I have a Kenmore Refrigerator/freezer,
Usually Kenmore refrigerators are made to be very solid. Just like all their parts The white panel is usually not adhered to the stainless panel. Mostly it is still staying on because it has been fitted there for a while and has become kind of stuck to the space which it has stayed.
EAsiest way out is by allowing or putting some sort of greasy substange most likely oil and let it seep through the sides of the white plastic so it can create some friction between the plastic and the panel and the plastic will slip right off. Here is a picture of the assembly parts for the door handlerockmeister_0.jpg
Hope this solution has been helpful?
Posted on Feb 13, 2011
GE adora side by side French door ice maker keeps freezing up and led light blinks. Have had repairman several times for same problem. Can I removed unit to thaw?
  • Possible solenoid fill valve failure
  • Possible failure of the mold heater, not allowing the ice to be removed from the mold.
  • Possible failure of the mold heater thermostat
Aug 30, 2014 | GE Adora (DSF25KGTBG) Side by Side...
Our refrigerator stopped making ice. The water comes out fine. How do we correct this problem?
There are two sides to the water control valve=> WR57X10051 Dual Water Control Valve It's possible the side for the ice maker has failed. Try filling the ice maker with tap water and allow it to freeze. If the ice drops after freezing and the ice maker does not refill this will point to needing replace the WR57X10051 Dual Water Control Valve If the ice maker does nothing then that points to the ice maker itself=> WR30X10093 Ice Maker Assembly I will be here should you have questions, Thanks Sea Breeze
Jun 05, 2012 | GE Adora (DSF25KGTBG) Side by Side...
My touch pad keeps freezing up. To clear the issue I have to unplug the unit for 20 seconds or so, then it works for about 5 - 10 uses, then freezes up again. Any idea which part is bad?
Sadly on these models, GE does not make separate parts available for the controllers, such as the keypad or touch screen, etc.
So when the keypad or display, etc., has a problem, you have to replace the whole control panel subassembly. It's reference number 23 in this exploded view.
The part number is WB07X11113 and you can get it for $586.37 from the Pros here. They're our favorite supplier.
But there is someone called Appliance Guru on eBay who has them new for $320 here.
In cases like this, you might want to consider complaining to GE customer service here . Maybe they'll work with you if it's not too far out of warranty.
Otherwise, you might check eBay. Often you can get a replacement oven for less than the part price. As long as it works.
In case you or someone you know might want to replace the sub assembly, at our Web site , we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you remove your smart board and PC supporter (with connections similar to the photo below) and put them on the new subassembly.
Some connectors on the relays have a lock:
Sep 17, 2011 | GE CVM2072SMSS Microwave Oven
I have a GE Spacemaker XL1800 Adora Microwave (manufactured in 2004) and the light bulb went out but I can't located it to replace it. Where is it located? Thanks
If it is meant to be user replaceable, then your owner's manual will cover it.
If not, then you may need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Either way, you can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jan 17, 2011 | GE XL1800 1100 Watts Microwave Oven
Adora Space maker XL1800 has problem right now.. it says F3....i bought microwaver since 2004... i cant find trouble shoot book.. i need to know what it is F3?? thanks, Tim Lavelle...
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
If you (or someone you know) might want to replace a separately available keypad yourself, I have uploaded a
handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number* here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
To see if this is the case for your model, enter your full model number* here.
* To show you this importance of an exact model number, the "XL1400" series included the following specific models:
JVM1410BC001
JVM1410BC002
JVM1410WC001
JVM1410WC002
JVM1420BB01
JVM1420BB02
JVM1420WB01
JVM1420WB02
JVM1421BC002
JVM1421BC01
JVM1421WC002
JVM1421WC01
JVM1430BA01
JVM1430BD001
JVM1430BD002
JVM1430BD01
JVM1430BD02
JVM1430BD03
JVM1430WA01
JVM1430WD001
JVM1430WD002
JVM1430WD01
JVM1430WD02
JVM1430WD03
JVM1431BA01
JVM1431WA01
JVM1440AA01
JVM1440BA01
JVM1440BD001
JVM1440BD002
JVM1440BD003
JVM1440BH01
JVM1440BH02
JVM1440BH03
JVM1440BH04
JVM1440CK01
JVM1440LK01
JVM1440LK02
JVM1440SH001
JVM1440SH01
JVM1440SH02
JVM1440SH03
JVM1440WA01
JVM1440WD001
JVM1440WD002
JVM1440WD003
JVM1440WH01
JVM1440WH02
JVM1440WH03
JVM1440WH04
JVM1441BD001
JVM1441BD002
JVM1441BD003
JVM1441BH01
JVM1441BH02
JVM1441BH03
JVM1441BH04
JVM1441CJ01
JVM1441CJ02
JVM1441CJ03
JVM1441CJ04
JVM1441SH001
JVM1441SH01
JVM1441SH02
JVM1441SH03
JVM1441WD001
JVM1441WD002
JVM1441WD003
JVM1441WH01
JVM1441WH02
JVM1441WH03
JVM1441WH04
JVM1442AA01
JVM1442BA01
JVM1442WA01
JVM1443BK01
JVM1443BK02
JVM1443LK01
JVM1443LK02
JVM1443WK01
JVM1443WK02
JVM1450AA01
JVM1450BA01
JVM1450BC001
JVM1450BC002
JVM1450WA01
JVM1450WC001
JVM1450WC002
JVM1451AA01
JVM1451BA01
JVM1451WA01
JVM1460AA01
JVM1460BA01
JVM1460SA01
JVM1460WA01
JVM1490BD002
JVM1490BD003
JVM1490BD03
JVM1490BH01
JVM1490BH02
JVM1490CD002
JVM1490CD003
JVM1490CD03
JVM1490CH01
JVM1490CH02
JVM1490SD002
JVM1490SD003
JVM1490SD03
JVM1490SH01
JVM1490SH02
JVM1490WD002
JVM1490WD003
JVM1490WD03
JVM1490WH01
JVM1490WH02
Oct 01, 2010 | GE XL1800 1100 Watts Microwave Oven
The screen says - F3 - and none of the buttons work
In some cases, you would need to replace the keypad itself.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
But on some
Feel free to contact me directly (and please include your full model number from the tag on the unit) for more free information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Adora side by side will only dispense crushed ice...the buttons seem to be working, as in the light comes on each button when pushed. But only crushed ice!
Turn off icemaker. Remove ice bin, empty it, rinse with warm water and leave to dry overnight.
If this did not help - check solenoid in the freezer behind the ice bin, make sure it's not stuck and has continuity. If all checked out ok, but still no cubed ice - control board or interface board may need replacement, and you'll need a professional to diagnose that.
Good luck,
Vlad
First Choice Appliance
Jun 02, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
The water dispenser on our GE Adora refridgerator (DSS25KGRA) stopped dispensing water. The internal icemaker still makes ice and the door unit dispenses ice both cubed and crushed. Could the water line be...
Most of the time it is the half of the dual water control valve on rear of refrigerator. The part number Click Here=> WR57X10032 Usually the coil on that side will go bad before buttons or controls. You can test that side by setting a test meter on AC voltage and you should read 120 volts while someone presses dispense water on front. There are two sides one plugs into icemaker side and other water dispenser. When replaced they both come as a kit. If you would like you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Oct 18, 2009 | GE Refrigerators
GE Adora Griddle Top replacement
part number for the griddle is WB31K10140
partstore.com has it for $87.95 hope it helps
Dec 23, 2008 | GE 30" Self-Cleaning Freestanding Gas...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
