Question about Water Line - 4 Rolls
No water comes out of hot water faucet - Water Line - 4 Rolls
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,554 Answers
Most likely water heater.
If it's electric heater, check circuit breaker in breaker box.
If it's gas, check if pilot light is lit.
If it's a gas, pilotless heater (quartz igniter), check that the igniter works.
Posted on Oct 17, 2013
No water coming out hot water faucets cold is fine.
First check to see if the main faucet to your hot water system is turned on. It could be someone has closed it. It is located around the bottom of your system. If that is open, water should be entering the tap.. To check this shut the main faucet at your water system and using a wrench loosen the connection from the faucet to the system and slowly open the faucet to see water comes out.. If it does that means the main water serivce to the system is fine .. You can also check this at the system by gently opening the outlet connection which should be at the top of the system , ensure that the main faucet At the bottom of the system is closed, once the connection at the top has been loosened slowly open the faucet to see if water comes out of the outlet.. If it does then the problem is from the system to your household faucets.. Could be a crushed water line . Also check to see if your hot water faucet is not Jammed. Sometimes the rubber inside the hot water faucet could be blocking the water if the faucet has been recently over tightened when closed.. Hope all goes well
Jun 04, 2013 | Kitchen Ranges
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
My moen single lever faucet problem is no hot water. The water is warm at most and when you turn it off and on it goes to cold. The faucet is only 8 months old. The only way to get real hot water is to...
The hot side sounds like it has some junk in the hot side blocking the hot water from coming through check hot water line to make sure that it is coming through down below and if so you would need to take it apart and try to get the junk out of that side of the faucet.
Nov 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Developed hot running water all the time
If the problem is that there is not enough hot water coming out, or when you can not get the hot water to shut off you may need to replace the cartridge inside the faucet.
Jun 26, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Oct 07, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Turn hot handle on - water does not come out of faucet
is the feed on the bottom of the sink open . if it is shut the water off from the bottom and take apart the handle to see if something is stuck in there
Sep 26, 2009 | Moen 4551___ Monticello Popular Two Handle...
The hot water stops coming out of faucet
if this is the faucet in picture, turn off water, pull out cartridge and inspect for any debris in cartridge or valve body, if not, turn on hot water to see if water is getting through valve body. May have kinked line or debris from or in angle stop line.
Apr 12, 2009 | American Standard Kitchen Faucet 6310 020...
No hot water flowing thru faucets
check the temp setting on hot water heater
if it is electric and 2 elements one could be out
You will have to take a multi meter and check continuity on elements
Purchase new element and replace
if it is gas increase tem
Jan 09, 2009 | Samyang Phoenix Faucet Shower Valve
Water Line - 4 Rolls Logo
Top Water Home Security Experts
Lawrence Oravetz
Are you a Water Home Security Expert? Answer questions, earn points and help others
