Question about Rustoleum Enamel, Gloss Black, 12 oz
I have put a strip on my 1995 mustang with rustoleum automotive gloss black the paint started to orange peel a few minutes after application what could i have done to avoid this problem and what should i do to fix it
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,554 Answers
Ensure the surface is clean AND wax free.
Posted on Oct 17, 2013
  •  Steve
    Steve Apr 13, 2014
    After you tape the surfaces not to be painted I would wet sand with very fine sand paper then clean well and that should avoid any peeling.
Paint flaked off. How to repaint?
Scrape off any loose paint. Sand it down, removing any rust. Use an enamel spray paint primer first. Then finish with a good quality exterior spray paint like rustoleum. Put on a few thin layers of paint allowing it to dry between coats.
Feb 21, 2016 | Garden
How do I fix gloss paint that dried with multiple matte areas after second coat was applied? 1st coat went on fine and dried glossy.
the matte areas could be blushing from the paint
although the temp was 68 degrees it is the humidity in the air that causes the problem
when covering gloss with a second coat , it may be advisable to rough up the gloss coat first
Sep 17, 2015 | Rustoleum Stops Rust Brown Hammered Enamel...
Gloss clear fish eye
Your question is not clear, what do you mean by fish eyed?
Dec 20, 2012 | Rust-Oleum Corp Painters Touch" 2X Ultra...
Will plasti dip paint work on chrome rims?
It will go on and adhere as it is drying but once it's fully cured it won't take much pressure to make it start peeling off a chrome surface. Chrome is very hard and very, very smooth. Because of these properties, the Plasti Dip will coat it and dry properly but will have a very hard time ashearing to the chrome after it dries completely.
Jun 28, 2012 | Plasti Dip Multi-Purpose Rubber Coating...
1995 paint on cherokee peeling
The peeling paint is a factory defect caused by the paint process they used in this year and others starting in the early 1990's. The cars and trucks with the defect where repainted free of charge on a case by case process, mine did this and being an employee of a dealer got it painted free of charge ($5,500 bill). Your truck is now to old and they will not repaint it.
Jun 12, 2012 | 1995 Jeep Grand Cherokee
I have a problem with an exterior front door. I had undercoated and glossed using stronghold exterior paint after sanding and sugarsoaping. The undercoat went ok ok but the gloss started to wrinkle and...
It sounds to me like you have some bad paint as everything else you are doing sounds good. I would strip it back down, let it dry and try another brand. Good luck. Thank you
Apr 14, 2011 | Home
I am an experienced spray painter, but I have been out of the game for a few years and things have changed in that time. I am familier with most types of paint, including synthetic, cellulose, 2 pack and...
water base paints are out there but as far i know i think you should error on the safe side and use a resporator with most all paints........ as far as i know they havent fully improved waterbase paints to the point that they hold up on metal correct me if i am wrong when the car companys use them for all cars then i will! ( base coat clear coat is the best so long as you follow the mixtures as directed on the cans ( call some paint suppliers , savage dupont ect they can guide you on most types of paints)
Feb 24, 2011 | Air Tools & Compressors
Same problem with grill bubbling what to do 2004 niss murano
I've decided to "black" mine out with a high gloss black. First I'm going to take the grill off & see if I can use airplane paint remover on a small area to remove the coating that is bubbling.
If so, then i'll primer the surface & repaint it as is since it should be smooth after the remover works and I scrape it down and wash it clean.
You could then leave it once the clearcoat is removed, re-coat it with clearcoat, or paint it any color, even to match. Automotive spray paint is available at auto-parts stores for this type of material, just get the right can of spray paint.
If I find the paint remover won't work without hurting the actual grill, I'll use some fine grit sandpaper and prep the surface, then primer it and paint it high gloss black. Color choice is optional of course!
Maybe this will help.
Jan 29, 2010 | 2004 Nissan Murano
There is extensive rusting around the liquid bleach receptacle of my four year old stackable Maytag washing machine. Am constantly removing rust and painting over with appliance paint. Rust reappears in...
I can not respond to the whitlpool ceo but I can tell you how to fix your problem.
Go to the hardware store and get a small container of a product called naval jelly. Paiint this on the rusty area, let it sit for thirty minutes and wipe away all of the rust. Next paint the area with rustoleum primer followed by rustoleum paint.
Jul 06, 2009 | Maytag MTW6300TQ Top Load Stacked Washer /...
Rustoleum Enamel, Gloss Black, 12 oz Logo
135 people viewed this question
Top Rustoleum Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Rustoleum Tool and Hardware - Other Expert? Answer questions, earn points and help others
