Question about Mountain Plumbing Water Heaters
How to clear Major plumbing clogs - Mountain Plumbing Water Heaters
    Sergeant:
  • 216 Answers
I am assuming that you are referring to a calcium or rust build up in the water heater.
If you are having this issue you will need to turn off the water to the heater. You will need a garden hose, access to a outside water soucre, cold water is fine.
Shut off the gas or power to the hot water heater before starting.
Now you will need to place the garden house on the drain fitting on the water heater, placing the end of the hose outside and lower than the drain valve. Open the valve and drain the heater, you will need to open a hot water faucet to help drain the heater. I don't suggest opening the TPR ( Temp Pressures relief )valve due to the fact that they sometimes leak or don't reseal after opening them.
Hopefully the drain valve is not clogged, you should hear and see water exiting the garden hose.
If you are not getting any water from the drain valve you are going to have a challenging task.
If no water is coming out, my recommendation is to get the required tools to remove the hot water line from the top or side or the heater, also a few towels to soak up water A bucket is helpfull also.
remove the hot water line, then you will have to use a small hose to siphon the water from the tank. Once the tank is empty you can then remove the drain valve and replace it.
once you have replaced the drain valve you should ensure that it's closed and use a Gallon of CLR. Poor this into the water heater through the hot water outlet where you removed the pipe from. Now make sure the faucets are closed and replace the hot water line. You can now turn the water back on to the water heater.
After a few minutes open a hot water faucet to let out any air until water flows out, than close the faucet.
Let the water heater set for a few hours, then drain the tank!
when the tank drains, close the drain valve again and refill the water heater. Once again open a a hot water faucet and let the air out till the water heater fills. Again let sit for a hour.
At this point open a hot water faucet at the farthest point from the heater and let the water run for 5 min. , than close it and move to the next closest faucet and repeat until all faucets have been opened and run for 5 minutes.
If you still have a slow flow in a faucet, you may need to repeat the CLR step.
I also suggest that you remove all faucet screens and clean them.
If you still have a clog than you are going to have to remove or replace a piece of water line in the house. The blockage may be hard to find but if you have access to most of the pipe or it's visable you may be able to hear the blockage with the water on. Otherwise this will result in using some water line taps and a pressure guage to find the blockage.
Posted on Oct 18, 2013
Does copper have to be used when connecting to the the top of the water heate? Does it have to be soddered?
First, id look into plumbing codes and regulations where you live as they vary greatly. Second, if you do have to, or decide to solder, pre- fabricate your male adapters x solder fittings and let them cool. The cold water inlet has a poly dip tube that melts due to the heat required to solder. That falls in.. Game over. Third, you can employ brass, bronze, galvanized or stainless threaded *******. The galvanized and stainless will come "di-lectric". Meaning they will have a poly sleeve in them to prevent electrolysis and clogging. Most plumbers also give free estimates and answers. Hope this helps.
Oct 18, 2016 | Water Water Heaters
What can restrict water pressure in my water heater?
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/New-water-heater-making-noise.html
Repairs made in water line can clog heat traps on new water heaters.
Old plumbing can have sediment at elbows.
DIY resource links above.
Otherwise call plumber.
Gene
Oct 11, 2014 | Rheem Richmond Encore Tankless Nat Gas...
I installed a dhc tankless heater, but when I open only the hot water everything is ok, but when I open the cold water at the same time the heater turns off.
Hi and welcome to FixYa, I am Kelly.
What is happening is that your cold water flow is greater in volume (gals per min) than your hot water. So when you open the cold water it is mixing with the hot water inside the faucett or shower plumbing and actually reverse flowing back into the hot water heater plumbing. The reverse flow slows the water flow sensing turbine inside the heater and it is thinking that there is not any water flow. (There isn't actually due to the equalization of water pressure when you open the cold water faucett) Since this is a safety feature of the tankless heater to keep it from overheating, it shuts off.
Somewhere in the hot water plumbing there is a major restriction. It may very well be the internal plumbing of the tankless hot water heater or the flow detector design.
There are 2 ways to correct this. The easy way would be to restrict the available cold water flow. You can do this by installing another shut off valve inline with the cold water plumbing and just not open the valve all the way. You would have to adjust the setting so that the hot and cold water can be on at the same time and the hot water heater stays on. The hard way is to locate the hot water flow restriction and eliminate it.
It is possible.... if you have a flow restrictor in a shower head or a screen in a faucett areator that they are partially clogged. Clean any flow restrictors and screens then see how the hot water heater performs before you start modifying plumbing.
Thanks for choosing FixYa,
Kelly
Apr 10, 2011 | Stiebel Eltron DHC-E 8 Tankless Electric...
Got a gocta w-26mixer shower bar fitted cold tap
from a plumber all hot and cold connections on all major showers are hot on the left and cold on the right just like the taps on your sink or washbowl
Dec 09, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Water Heaters Logo
52 people viewed this question
Top Mountain Plumbing Water Heaters Experts
rpar
paulcarew
Gene Haynes
Are you a Mountain Plumbing Water Heater Expert? Answer questions, earn points and help others
