Wont play cd
I have an xds 110 dual radio in my car and it will play cd's but when i put a cd in it reads err the cds are brand new and have tried a few of them and i get the same results i have reset the radio multiple times and the problem still occurs please help
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 144 Answers
Look in the back of the owners manual for that radio, see if it has an explanation of "err". It may give tips on what to do. Also, contact the manufacturer if it is under warranty.
Posted on Oct 27, 2013
  • 1019 Answers
SOURCE: 16X8 DVD Dual won't read dvd.
set it up on a seperate IDE Channel, or change from master to slave. Or Vice-Versa.
Secondly you could try re-installing windows 2000, this should repair any corrupt or missing drivers.
Finally see the manufacturers website, to see if any firmware upgrades are available.
Hope This helps.
Mike @ Compurepair.
Posted on Feb 22, 2008
SOURCE: AMSUNG DVD WRITER PROGRAMME DISK ( NERO, BG68-01317A REV.00 )
how i get back the icon of CD/DVD writer to my system
Posted on Apr 12, 2008
kikoksky
  • 119 Answers
SOURCE: New DVR-112D can't read misic cds or cd roms.
there are several options you can do as follows:
1. go to support.dell.com and download from the website any firmware updates available for your player.
2. Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor.
3. try to update your bios which you can also download from support.dell.com under downloads and drivers. just enter your service tag
Posted on Jun 19, 2008
SADHSU
SOURCE: wont burn data dvd
dear
i have this kind of drive ( 7W036-A01) , IT READ AND WRITE CD BUT IT COULDNT WRITE DVD ( EVEN IT READ DVD IN GOOD WAY )
PLEASE CAN ANY ONE HELP ?????
Posted on Sep 07, 2008
compdoctor20
  • 172 Answers
SOURCE: dvd drive not reading properly
Have you loaded the dvd drivers to view the dvd's through ? you need something like Cyberlink or Power DVD
Posted on Dec 26, 2008
Why does the radio works but CD player does not? WE get an err code.
the cd reader cant support newer disks or is old and just cant read like when it was brand new
Aug 17, 2014 | Cars & Trucks
I have a dual xds 110 car radio that will not play cds radio works but when i insert a cd it says error my cds are brand new and unmolested i have tried resetting the radio but the problem still occurs...
are you hearing the disc spin when it is inserted. sometime the disc is just not sitting right to be read or failing these there has something happened the the laser and not reading the disc, most time it is the disc in not getting to sit to be read. you will need to open the player up and check to see if it is working properly. i use a battery charger and plug the power leads into it just to see what is going on. if you cannot do this take the radio cage out and unplug the plug off the cage and plug that part into the radio so you can see what is going on... this is a must never look at the laser as this will damage your eye/s look at an angle look for a red beam of light that will be the laser reading the disk if no red light and the disc is sitting in the right place then the laser has gone. you can sometimes get a replacement but that is upto you as the can cost a bit unless you do a search for faulty type with audio flats etc but not reading disks. then just swap over the laser unit.
Oct 17, 2013 | Computers & Internet
Lexus 2001 is 200 6 disc stereo error 1 code shows when trying to play cds
Error 1 - "disc is dirty, damaged, or is inserted upside down"
I quote other solution comments:
I've been getting the Err 1 and Err 3 for a while now, my headunit needs replacing but I haven't had chance yet...
I've found that the cold weather makes it worse as the CDs get that cold they are covered in condensation so the CD has trouble reading them..
In my experience when you get an Err 3 it's basically knacked and needs replacing and Err 1's can sometimes be read problems - what's the disk like?
Mine has started giving Err 1's on brand new CD's (not CDRs) so she's probably having trouble focussing....
If the car is less than 5 years old the headunit should be covered under warranty (ie free).
Hope helps.
Apr 02, 2011 | 2001 Lexus RX 300
My radio wont play Cd's. Everytime I put in a cd,
Your CD player's lens is not working, meaning either if you can open it and change the lens or install a new stereo, see which solution is cheaper.( you can find stereos for around $35) . Good Luck
Feb 09, 2010 | 2001 Pontiac Grand Prix
Tried several CDs
Try to reset the radio by unplug the power source to the radio
Sep 22, 2009 | Dual Car Audio & Video
Cd player wont work
Unfortunately unless you have a place in your area that repairs auto adio systems you will have to replace it.
Aug 01, 2009 | 2002 Nissan Sentra
2003 infiniti g35 cd player
its a very common problem with g35 in dash clarion cd changer head units. a small plastic gear gets worn or brakes and wont eject or change cds. you need a new one, should be covered under your warranty.
and to get your cds out try this.
Feb 03, 2009 | 2004 Infiniti G35 Sport Coupe
CD player will not work
some factory radios wont play burnt cds,dont know if thats the case?but i not the case the optcal lens in side the radio is bad got one id sell you out of a 05 ha ha.
Jan 09, 2009 | 2003 Chevrolet Cavalier
Califone 2385AV-02
PUT AN CLEANER DISK INSIDE(DISK WHICH CLEAN OPTICAL PATH INSIDE)-YOU CAN OBTAIN IT FROM NEAR RADIO SHACK.
PUT AN GOOD CD AND TEST.
Jan 04, 2008 | Califone International (2385AV-02 ) Single...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
