I have a thermoheat RMC-KFA75TL/125TL i tried to
I have a thermoheat RMC-KFA75TL/125TL i tried to adjust the pump pressure but i cant get it to go high enough. its at about 3p.s.i. but it needs to be at 5.5
2 Suggested Answers
SOURCE: The valve on my Thermoheat heater RMC FA50 will
I'm assuming this is a gas heater valve? Typically, one must slightly depress the valve in order to turn it to pilot or on--a safety feature of nearly all gas appliances...
Posted on Jan 19, 2011
Will only heat on high mode hot tub
Sounds like low speed isn't providing enough water flow to close the pressure switch that allows heater to run. Its unlikely anything has changed in the pump other than a possible obstruction so to troubleshoot by most common failures first, try removing filter cartridges. If it heats on low speed with no cartridges installed then you need new filter cartridges (even if they look ok). If not the pressure switch might need adjusted or replaced. Most pressure switches can be bypassed with a jumper wire to diagnose but should never be left bypassed for normal operation.
Dec 16, 2016 | Pool & Spa
Tip
Torpedo Heater Pump Pressure Adjustment
The most critical factor in getting your kerosene torpedo heater to run is the air pressure that the pump puts out. This air pressure is what pulls the fuel out of the bottom of the heater. It is very important that this is set correctly.
You will need a low pressure gauge (0-15 PSI) and a screw driver to make this adjustment.
On the back of your heater there will be a short and a long protrusion. Pull the plug out of the short one and insert the pressure gauge. The longer one is the adjuster screw. This is a very simple device that has a ball a spring and a set screw. Turn in on this screw just places more tension on the ball to allow less air to escape and raise the pressure inside the heater.
If you cannot get a high enough pressure then there is a leak or the pump is worn too much. To check for a leak use soapy water and check all the parts. The black plastic back can crack or the cork of the pump gasket can leak. Sometimes the rotor and vanes will go bad but not likely.
So, insert the pressure gauge in the short port, start the motor and check reading, you will only have a short time to do this if your heater is not firing. Turn the longer screw in or clockwise to raise the pressure and out CCW to decrease the pressure. Adjust to factory specs. And you will be getting warmed up.
http://www.fixya.com/support/r3818299-reddy_heater_troubleshooting_torpedo
http://www.fixya.com/support/r3903547-torpedo_heater_kerosene_heater_portable
on Jan 06, 2010 | Heating & Cooling
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Thermoheat forced air heater hard to start after sitting overnight or for extended time. It blows diesel out pressure is 3.5 everything turns on just won't ignite. after turning it off an on several t
The pressure should be higher than 3.5 psi.
You have an output filter under the rear plastic cover that is held on with the 4 screws.
Check that filter to see if it is dirty.
The PSI for the heater should be on the side of the heater.
Nov 22, 2014 | Heating & Cooling
Thermoheat dtu torpedo heater reads E1 error
These are some possible causes:
1. Wrong pump pressure
2. Dirty Air Output,Air Intake or Lint Filter.
3. Dirty Fuel Filter.
4. Dirt in Nozzle.
5. Dirty Photocell Lens.
6. Photocell Assembly not
Properly installed.(Not seeing the flame)
7. Bad electrical connection between photocell and MAIN PCB assembly.
8. Defective Photocell.
If all those check out ok, then check these:
1. No fuel in tank.
2. Wrong pump pressure.
3. Carbon deposits on spark plug and/or improper gap.
4. Dirty fuel filter.
5. Dirt in Nozzle.
6. Water in fuel tank.
7. Bad electrical connection between ignitor and MAIN PCB assembly.
8. Ignitor wire is not attached to spark plug.
Nov 29, 2013 | Protemp 125000 BTU Kerosene Forced Air...
I have a liquid cooled 20hp kawi motor on a j.d. Riding mower. The guy next door to me gave me. He has been having an issue with the running. Replaced fuel cap, lines, pump, carb, and spark plug. Still...
Have you checked the fuel pressure with the pump running? If you have a way to measure the pressure at the carb check what it is on gravity feed and with the pump running. Some fuel pumps have a return line to the tank that may be clogged causing the pressure to be high.
Nov 13, 2013 | Garden
The valve on my Thermoheat heater RMC FA50 will turn from the off position therefore I can not light or start the heater. It is stuck in the off position.
Jan 19, 2011 | Heating & Cooling
Need a control knob for: dyna-glo pro propane heater. model: # rmc-tt30dgp-01, # rmc-tt30dg, # rmc-tt30gd. this is the off/low/med/hi temp. control knob.
I AM TRYING TO FIND A PROPANE REGULATOR FOR A DYNA-GLO PRO. THE MODEL # IS RMC-TT30DGP. THERE IS A NUMBER ON THE OLD REGULATOR. THAT # IS S2NTT0002-2.THANK YOU.
Dec 17, 2010 | Heating & Cooling
Heating & Cooling Logo
163 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
