Question about San Jamar T8400TBK - Compact Touchless Roll Towel Dispenser Adjustable
Will not dispense towels. We pull the batteries out and put them back in. Sensor will pick up twice and dispense normally then it quits. replaced batteries....same thing happens. green and red lights work on the settings.
Is there a reset button or a hole that requires a paper clip or nail? Sometimes reset means leaving the batteries out for 5-10 minutes. Have you contacted the manufacturer? - Especially if this a new purchase. Then I'd return it or exchange it.
Posted on Oct 25, 2013
I have a 1989 S10Pick up with a 2.8L, won't stay running. I can pull the ecm b fuse it will run about a min then quit, I've changed the fuel pump relay and checked crounds still has this problem?
if it runs for about 5- 10 minutes before it stops, when it stops remove the gas filler cap, do you hear a suck inrush of air when you remove the cap?
Dec 15, 2013 | Twister Auto Parts 89-93 Chevrolet S-10...
I was driving on the highway and ran out of gas, the truck started slowing down and eventually quit as I pulled to the side of the road. I tried starting it quite a few times and eventually had a friend...
You need to start with a GOOD battery-if you do not have a charger, borrow one or buy one that has starting capability. Turn on your key and check for fuel coming out of the fuel rail (use a rag to keep it from spraying all over you/the place).-Once you determine you have a STEADY STREAM of fuel, take the plugs out and dry them off with a towel-start it up, if you have fuel, spark and the plugs are dry, it will start.
May 23, 2011 | 1995 Nissan Pickup
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
Won't dispense soap. Changed batteries twice,
Sometime the viscosity of the soap could be the culprit. If you had changed to a thicker soap sometimes those pumps can't handle it. Try a less viscous soap and lets see what happens. Good Luck PAL
Jul 26, 2010 | NRS iTouchless Stainless Steel Automatic...
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
The ice maker will not quit dispensing ice and it no longer cools
For now unplug the pin plug at lower freezer door hinge and disable the dispenser control board until we see if the keyboard or the dispenser board is at fault. Sea Breeze
Feb 22, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Magenta ink ran out,continued to use printer,replaced ink tank twice,have done cleaning & deep cleaning several times no magenta coming through,all other colours ok. what to do next?? anybody have...
Think you may have killed your print head, but try this.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jul 01, 2008 | Canon Office Equipment & Supplies
San Jamar T8400TBK - Compact Touchless Roll Towel Dispenser Adjustable Logo
419 people viewed this question
Top San Jamar Home Experts
Donni Steen
Tom Chichester
Are you a San Jamar Home Expert? Answer questions, earn points and help others
