Question about Gateway FPD2275W LCD Monitor
Gateway ZX4931 all-in-one will turn on (power button only) for 2-4 seconds nothing on the screen, then one short beep and turn off completely. Will not turn on again unless the power supply is unplugged then plugged in again. I've already replaced the motherboard. Thinking it may be either the power supply or the video card. Any ideas? I'm about to try removing each of the two RAM chips one at a time.
    Champion:
  • 219 Answers
Power supply maybe but sounds like a motherboard issue. do you have a red light blinking on the front if so motherboard is your issue.
Posted on Oct 21, 2013
  • Lonnie Hinkle
    Lonnie Hinkle May 22, 2014
    I have recently ran across this on the ZX4931, and the issue was with the power switch. The brown wire had shorted, which caused the unit to shut-off after 4 seconds.
  • Lonnie Hinkle
    If you wiggle the brown wire ever so slightly in different directions you may find that the unit will power on normally
5 Suggested Answers
SOURCE: The power light blinks solid blue every four
Two days ago I received a Gateway 900w FDP1975W Monitor from a friend. He told me that he would have to let it rest and it would work for about a hour or so and flash green with lines, then Flashing blue power light, then nothing. I have seen this problem on several LCD monitors, including Dell and Sceptre. The problem with the blue power light on/off is with the power supply inside the back of the monitor. The manufacturer runs so close to the minimum that these power supplies burn out in about 2 years. I am typing this messege using the very same dead monitor. How you ask? You must remove the trim from around the out side of the monitor - this one had two(2) screws in the back. bottom, outside corners then the trim can be pried off (dissconnect power button cable) - then you must remove the LCD screen four(4) screws in the 4 corners. (remove with caution - lay it face down on a flat surface with soft cloth or towel - do not break LCD) lift up LCD (a little) from plastic case and remove two pairs of blue/pink wires connected to side of power supply.(these are in two sets of four - two connectors at topside and two connectors at bottomside - make note of which goes where - you must depress cliplocks to unclip) Lift a little higher and remove the main cable from back of power supply. Remove LCD to a safe place. Unscrew three(3) small, four(4) medium and one(1) large screw from the power supply cover and remove. The power board will be on top of the control board, remove four(4) screws holding down the power board and pull up to disconnect from control board (careful the power cord socket connection HAS to slide straight up out of its holder!) Then remove screw holding ground wire and remove the power board. NOW WHAT, do you say? Look at the Capacitors - on mine, it hade 4 680uf@25volt 2 470uf@25volt 3 220uf@25Volt 1 10uf@50volt and 1 22uf@50Volt . The 680,470,220 were all swollen (shorting/shorted) This probably happend because one of the small 10 or 22 control caps were going (high resistance) I went to radio shack and got 35volt (yes they fit and yes they work) 220, 470 and1000 (Yes 1000 fit and yes they work) (Think of capacitors as a glass of water - when they filter the power they fill only to the charge of the rail - This case 20volts (35 gives more space) and the MicroFarad uf to the use of the circuit - now I dont know all about electronics - but the small caps that control the rail MUST be the same 10uf - 10uf 50volt - 50volt (they control the circuit power and their values are designed into the circuit - but the large ones filter the power and in this case, are limited only by the space they have to fit into and cost of the parts - but these can be upped) Now with the larger 1000uf caps and the 470/220/10/22uf all replaced (I replaced the 10uf ad 22uf control caps because this is what probably caused the overvolt/overheat (they didnt show bad - just replace them all!) Cost $13.00us - Put all parts back together - Power board ground wire & screw first - slide power board power cord socket down and connect the 8 -10 pin connector and push down firmly - put back the four(4) small screws and replace power supply cover - put back the three(3) small and four(4) medium and one(1) large screw - reconnect the main connector and the two upper and two lower side connectors. Place LCD all the way down on the cover and replace all four(4) corner screws. Plug power button cable back in and rest trim on top of monitor - Plug power cord in to test - blue light should come on and stay on 'Gateway' logo should flash - then with no signal should go to amber - test with computer - If you soldered all your connection correctly - the monitor will work as good as new!
Einstooge.
Posted on Sep 03, 2009
Testimonial: "Accurate and well stated!"
  • 12 Answers
SOURCE: same problem 2 seconds on, then turns black
The problem with the monitor is the power inverter board. I took my monitor apart and tested all the power outputs. The ones going to the main board where ok but the ones going to the backlight where different. I changed the three capacitors on the power board that where located between the two heat sinks I think it was the 1000uf and the two 470uf. They looked ok but when i tested them they where off. Next on the opposite side of the board with all the little componites there are a few dry joins that you have to resolder. If you cant find then you can just resolder the whole back board it should only take 30min. If you have no idea what i am talking about i would not sugest taking the monitor apart.
Posted on Jul 28, 2009
bootz84
  • 197 Answers
SOURCE: Gateway 19inch wide screen, lcd monitor stopped working randomly.
It could be a faulty power cord. Try plugging it in and moving the cord around in the areas where it takes the most movement. Do the same with the data cable to see if you get a response there. If your cables are fine, the problem is most likely hardware in the monitor - in that case you're better off replacing the monitor.
Posted on May 06, 2009
octeks
  • 52 Answers
SOURCE: Gateway FPD2185W TFT LCD MONITOR
The backlight or inverter is going out on your screen.
Eventually it will just stay dark. You will need to replace one of the two if plan on keeping monitor.
If you find this helpful please rate so.
Thanks
Long beep on gateway computer
pls find the model no. and find the beep codes and match the order to identify the problem
ex:POST Beeping Error General Codes
  • Bad Motherboard - 1 long and 1 short beep
  • Disk drive related problem / Video card problem - 1 short beep then nothing happens
  • Bad video card - 1 long and 2 short beeps
  • Bad power supply - 1) continuous beeps, 2) non-stop short beeps
  • Bad memory - 3 short beeps
Nov 07, 2016 | Gateway Computers & Internet
My PC Desktop zx4931 starts to power up but then nothing, any ideas?
sounds like a lose wire some were.check mains lead,or what ever you are using to power it up.
somthing is lose some were.
Apr 01, 2015 | Gateway One Hd Zx4931-31e 21.5" All-in-one...
Get 3 long beeps and 2 short beeps when power on
Likely bad ram... but i need the make and model for the beep codes..
http://www.computerhope.com/beep.htm
Mar 11, 2015 | Gateway Computers & Internet
Gateway zx4931
My Gateway ZX4931 (purchased 2011) one day just would not power on. I have unplugged it and put it in different outlets, and it still wont turn on. Can anyone help?
Sep 17, 2013 | Computers & Internet
I just bought it off of craigslist hoping to fix
with nothing happening it is very possible the hard drive that needs replacing or is missing
Mar 24, 2017 | Gateway CX2610 Notebook
I have a Gateway 507gr pc. Pushing the power supply button the fans turn the cpu light turn on and the pc does nothing else.
you'll need a good power source.replace the old one ; remove all conection from hdd ,dvd's etc..make sure you have a speaker on MB.remove all the ram you have and power on the pc ;you must here a long beep folowed by 2 short one's;if you don't hear it your MB or CPU are gone.But if you do hear then put back the ram and remove your video card and power up the pc again , you must hear a long beep folow by 3 short one ; if you don't hear your MB or CPU are gone but if you hear that means the power supply was the problem.
Apr 21, 2010 | Gateway 507GR PC Desktop
Computer turns on, but won't work afterwords
Nev, the two loud beeping sound of the system when turning it on could be a problem with the memory or the system board.
Try disconnecting the power and take out the battery, then press and hold the power button for 5 seconds then look for the memory comparment and reseat it.
Keep me posted.
Thanks.
Nov 16, 2008 | HP Compaq Presario V2000 Notebook
Constant beeping and will not re-boot
Question- the beeping, is it short (1 second beeps) or long (2 or more seconds) and how many before it stops? or doesn't it? does it have any rhythm? The beeps correlate to some hardware problem, if you want to check the beeps yourself, just google "Bios beeps" and it will bring up a table of what the beeps mean.
J
Jan 07, 2008 | Computers & Internet
Gateway FPD2275W LCD Monitor Logo
257 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
