Question about Dryers
Casablanca fan intelli touch
Fan is several years old. Now runs only on high speed. Powered off, then pressed and hold fan button. Initial slight movement of fan, but then nothing. Quick press and release of fan button, and fan will run only at high speed. Reverse button works ok.
  • 3,187 Answers
There is a starter solenoid inside it works the speed setting. controls speed 1-2-3. 4 it bypasses it. in side the fan you will see a black box with c66 somthing that will need to be changed as that is the part that controls the speed.
Posted on Oct 18, 2013
SOURCE: hampton bay altura 68
Read this on another thread - apparently the solution came from HB's tech support.
Turn the fan speed to HI and then select Reverse.  You should hear a "click" and see the fan reverse direction.  It seems that the reversing relay only works when the fan speed is set to HI.
Good Luck!!
Two Metre Man
Posted on Aug 15, 2008
  • 833 Answers
SOURCE: Ceiling fan only running at highest speed
First, change the battery.  Second, turn off the power to the fan at the wall switch, if still installed.  If this doesn't fix it, it is probably dead.  Bring it back to Home Depot.  There may be a product bulletin.
Posted on Nov 15, 2008
  • 37 Answers
SOURCE: Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Posted on Jan 24, 2009
  • 57 Answers
SOURCE: Ceiling fan stuck on high
The Inteli-Touch system does have a slight learning curve.
How the system works is. You turn the power switch on, and leave it on, all the time. To set fan speed, you press and HOLD the fan button and it will go. . beeeep. beeeeeeeeep. beeeeeeeeeeeeeep. beeeeeeeeeeeeeeeeeeeeep beeeeeeeeeeeeeeeeeeeeeeeeeeeeep beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep (higher pitched) when you reach your desired speed you let go of the fan button and it stays on that speed. So if you want to go to speed 4 you wait for the fourth beep and let the button go. To turn off the fan, press and release the fan button, to turn it back on to speed 4, press and release again. It has a memory. If you want to go to a higher speed while on speed 4 (or any other speed) just press and hold. To slow down the fan, you must turn the fan off by pressing and releasing the fan button, then pressing and holding until you get to the speed your desire.
The instructions which came with the fan should explain the rest. After you get used to using the IT control system, you will love it. I do. I have two Casablanca IT Victorian II fans in my living room. They are featured in this video. http://www.youtube.com/watch?v=2pv55wZqohs
Posted on Jun 10, 2010
SOURCE: I have a Casablanca Intelli touch ceiling fan.
My fan operates the same way. To reverse it, turn it on a low speed. Then, turn it off and on, then off and on again, quickly. You should hear a series of beeps, and the blades will slow down and then reverse. You may have to play a bit with the timing of the off/on/off/on sequence to get it right but you should be able to get it fairly easily.
Posted on Sep 01, 2010
How do you operate a inteli-touch casablanca ceiling fan
i looked everywhere,casablanca doesnt have anything but a picture,but,i eventually found this for you,dont break it,there are no parts being made http://www.casablancafanrepair.com/HTMLFiles/do_it_yourself/InteliTouchCommonRep/ReplaceElectronicsIT.pdf
May 28, 2015 | Casablanca Fan CAS 66668T Panama II...
When the Casablanca fan remote control wall button is pushed the fan beeps and progresses to the fastest fan speed and stays there. How do I adjust the fan to be able to vary the fan speed so I don't have...
the button may get stuck or the sensor may be off.... also it could be that the setting is backwards on the fan to start on the fastest and end on the slowest
Dec 01, 2010 | Casablanca Fan Dryers
How do you program a casablanca fan remote control to work for the fan?
Howdy,
Casablanca control systems are specific, for instance Inteli-Touch (4 button wall control with power fan light and reverse buttons) uses power line signals to a computer board inside the fan's motor housing and a remote control using RF will not work. However, you do not state what control you have, or what specific control you wish to attempt to use with the fan. Some will work some, will not.
Thanks and Reply so I can better help you!
Sep 14, 2010 | Casablanca Fan (3845T) Brushed Nickel...
Intell-Touch instructions for casablanca fan/light
Light Operation: With the light in the off position press and hold the light button (do not let go). The lights should start at a dim setting and gradually get brighter and brighter. When they get to a setting you desire let go of the light button. To reduce the brightness of the light you must first turn the light off, and then press the light button and hold it in as described above. If the light is off, and you press the light button quickly to turn it on, the light will go back to the previous setting. So if you last had the light on the high setting, it will go back to the high setting, if you had the light at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the light intensity at any time by pressing and holding the light button, but to decrease the light intensity, you must first turn the light off, and start over by pressing and holding in the light button.
Fan Operation: With the fan in the off position, press and hold the fan button (do not let go). The fan should start at a slower speed and get faster and faster. When the fan is at the speed you desire, let go of the fan button. To slow down the fan speed you must first turn the fan speeds off by pressing and releasing the fan button. If the fan speeds are off, and you press the fan button quickly to turn it on, the fan will go back to the previous setting. So if you last had the fan at the highest setting, it will go back to the high setting, if you had the fan at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the fan speed at any time by pressing and holding the fan button, but to decrease the fan speed you must first turn the fan off, and start over by pressing and holding in the fan button.
Jul 20, 2010 | Casablanca Fan (3232A) Ceiling
May 20, 2010 | Casablanca Fan 6672G Panama® Ceiling Fan
I have a Casablanca Intelli touch ceiling fan. The remote is a simple toggle switch, turn in on, listen to the beeps, off an on quickly to set it. How do I reverse direction on this fan?
Apr 01, 2010 | Casablanca Fan 3245T Ceiling
It seems that we need a pc board for our intelli touch casablanca fan - where can I find one for out model #AS26069
Thank you, but I already found a web site that sells the conversion kit to update the fan.
I understand that the original parts are no longer made and it is recommended to convert.
Thank you!
Jul 17, 2009 | Casablanca Fan 3245T Ceiling
Oct 27, 2008 | Casablanca Fan Bel Air 3811T Ceiling
Dryers Logo
150 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
