Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I have a GE profile built-in gas cooktop (model :JGP636WEV4WW). All of the five burners spark all the time. Is it switch problem or spark module problem? how do I determine it?
  • 2,113 Answers
Either one of your controls is partly on damaged or the wires from it have melted together just under your cooktop
Posted on Oct 17, 2013
Testimonial: "I checked the wires. They seem to be ok. There are five switches (one for each burner). How do I know which one is damaged? There are two types of swiches. It makes it difficult to order which type of switch or which one is damaged"
SOURCE: clicking of the burner ignitors
I pulled out the electrical cord and then let the system dry out for about 8 hours. When I plugged in the oven again, the clicking had stopped.
Posted on Dec 27, 2008
  • 71 Answers
SOURCE: I have a GE profile
unplug the cook top under the counter, let the switches dry out about a a day then try again.
SOURCE: GE profile gas range: Gas burners don't work
Used toothpick to unclock gas output and worked great.
Posted on Jan 23, 2009
  • 1214 Answers
SOURCE: GE Profile Gas Cooktop
Do you hear the spark ignitor trying got light the burner?
If not, then make sure there is not a residue or film of cleaning solution on the burner bases or burners themselves. It could be coincidental that the spark ignitor failed when she just happened to be cleaning the unit.
  • 3 Answers
SOURCE: ge profile gas cooktop -
Perhaps you have a similar problem that I did. I have a Whirlpool gas range and some of the lighters were cracked and not working. They are $26 - $35 each, OUCH. On the two broken ones I replaced the ceramic with epoxy putty, and they are working. As it turn out, they are only female wire connectors wrapped with ceramic. In a hobby store I got some oven bake clay, an I plan to make my own replacements.
Posted on Apr 21, 2009
Piezo igniter won't quit
Possible stuck burner switch or failed spark module. Unplug unit. Remove wires from burner switches at module and plug back in. If it starts sparking, replace module. If it stops, then replace switch harness.
Jan 18, 2011 | GE 30 in. Profile JGP932 Gas Cooktop
My GE Profile propane gas cook top was just installed yesterday. When I go to turn on one of the burners, all of the ignitors click. This can't possibly be normal. Anyone else have this issue?
Yes, thats okay when you turn the knob voltage gets sent to the spark module, Then the module sparks all the burner igniter. And frame ignition only happens on the single burner of the knob you turned that sends gas to the burner associated with that knob.
Please rate me a "4" if this information was useful.
Dec 14, 2010 | GE Profile JGP636 Gas Cooktop
GE Profile JGP636 gas cooktop
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Jul 01, 2010 | GE Profile JGP636 Gas Cooktop
Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
GE Profile nat gas cooktop, Model No JGP636BEV3BB won't ignite
If you can hear the clicking sound but are not getting a spark then there is probably a short in the ignition system. Check for any loose wires on the ignition system. Make sure all the wires are properly seated. Make sure the spark module is properly grounded. As far as testing the spark module it should be generating a spark of course. The problem is that the average voltage for the spark module is 15,000 VDC so actual testing of that voltage can be difficult. Is the spark erratic?(should spark evenly). An erratic spark timing is a sign of a bad spark module. Is the spark slow? Check the polarity of the electrical plug. If it is clicking evenly then it is probably arcing somewhere inside the cooktop and you just need to find out where. Also be aware that if you get water into the cooktop that can cause possible grounding of the spark module or ignition system.
Jan 18, 2010 | GE Profile JGP636 Gas Cooktop
Ge profile gas range. one burner with no clicking and no ignition
You may have a bad burner switch. If you turn one of the other burner switches to make the spark modules spark look and see if the electrode is sparking at the bad burner. Most of the spark modules send a spark to all 4 burners when activated. If it sparks when another burner is activated open the valve and see if the burner will ignite. If so you probably have a bad burner switch.
Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I own a GE Profile gas cooktop model number JGP940SEK1SS. The igniter continues to make a sparking sound when it is plugged in . We have to unplug the the stove to make it stop.
It could be one of the burner switches shot it out or spark module malfunctions.
Burner switches ***. part# WB18T10366
Spark module part# WB13T10046
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Nov 30, 2008 | Cooktops
One of four dials doesn't spark ignitors...
its a spark switch gone bad, 1 switch will turn on all four burner electrodes(its just easier 1 module)sometimes model dependant you can eplace justone switch, sometimes they come as a complete set
Feb 24, 2008 | GE 30 in.Profile JGP945 Gas Cooktop
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
88 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
