Question about Canon PIXMA MX320 Color USB InkJet Printer
On 8/23/13, I started getting the "Line Busy" report when I tried faxing with my 4-year-old Pixma MX330; according to my Activity Report, everything was fine from at least 2011 to 7/14/13. Following your directions to someone with a "Line Busy" problem, I turned the Pixma around and discovered there was nothing connected to either the L input or the phone input. This makes sense since I haven't had a landline since at least early 2012; my cellphone is my only phone. I've also had a Netgear wireless router for a year or more. I hope you can help me.
  • Judith Davidsen
    Judith Davidsen Oct 19, 2013
    I don't know if this matters, but the wireless router is not connected to the computer and looks like it never has been; at least there doesn't seem to be any unused cable floating around in the cable pile. Is there any specific thing that you think you might need to know?
    Master:
  • Canon Master
  • 641 Answers
Sorry, you need a landline to send or receive fax in that model
Posted on May 02, 2017
How to stop automatic "activity report" printing
in the menu section search for activity report and turn it off
Apr 18, 2016 | Canon PIXMA MX452 Wireless Office All In...
How do we get an activity report on our uxp 400 fax machine
Printing a list
1 Press these keys:
FUNCTION
The display will show: LISTING MODE
START/MEMORY
2 Press the # key or the * key until the desired list appears in the
display.
or
3 Press the START/MEMORY key.
Activity Report
This report shows information on your most recently performed send
and receive operations (a combined maximum of 30 operations can
appear). The report is divided into two parts: the TRANSMISSIONS
ACTIVITY REPORT, which shows information on transmissions, and
the RECEPTIONS ACTIVITY REPORT, which shows information
on receptions.
Nov 13, 2009 | Sharp Office Equipment & Supplies
Can a sharp ux-p410 retrieve old sent faxes from its memory
No, your fax machine only records the fax number of the last 50 transactions
Oct 19, 2009 | Sharp Office Equipment & Supplies
My fax (pixma mx330)says memory in use and shows
Hi, you must reset the machine in the factory setting mode.
Oct 09, 2009 | Canon Office Equipment & Supplies
I faxed something last week and lost the transmisson verification report, can it be re-printed? does my fax keep it in memory?
It's possible to print a Fax Activity report which would show both incoming and outgoing fax activity. To do this, do the following:
  1. Press Reports
  2. Use arrow keys < > to select 3. Fax Activity
  3. Press Set
If Fax Activity hasn't been set up, do the following:
Setting the Fax Activity Report Interval
You can set the machine to print activity reports at specific intervals (EVERY 50 FAXES, 6, 12, 24 hours, 2 or 7 days). If you set the interval to OFF, you can print the report by following the Steps in the next page.
  1. Press Menu, 2, 4, 2.
  2. Press or to choose an interval,
    and then press Set.
    (If you choose 7 days, the LCD prompts you to choose a day at which to begin
    the 7-day countdown.)
I hope this enables you to recover your transmission report. Please post back with any questions or just to rate the solution. Thank you very much.
Greg
Aug 11, 2009 | Brother IntelliFAX 4100 Laser Fax
How do I print an Activity Report for faxes sent on the Canon Pixma MX310?
Hi ...
The fax machine prints an activity report automatically after every 20 transactions. To print a report manually, follow these instructions:
1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select [ACTIVITY REPORT], then press <OK>. The ACTIVITY REPORT is printed.
Don't forget to vote if this helps ... Cheers :)
Aug 02, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon pixma mp 830 on my fax activity report I
Yes,it means the fax did not go through,it will show OK on the report if it was succesfull
Jun 29, 2009 | Canon imageRunner C3100 Copier
I want to have the MX310 to answer on 4 rings
Change the ring count 1. Press the <Menu> button repeatedly until [FAX SETTINGS] is displayed.
2. Use the [ left.gif] or [ right.gif] to select [RX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif] to select [ RING COUNT] then press <OK>.
4. Use the [ left.gif] or [ right.gif] to select the desired number of rings. Press <OK> then press <Stop/Reset>.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
Try to download the manual
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15603#DownloadDetailAct
I hope it helps!!!
The TX Report and RX Report print upon transmission or reception offaxes depending upon the settings made in [FAX SETTINGS->TXSETTINGS->TX REPORT] and [FAX SETTINGS->RX SETTINGS->RXREPORT], respectively
Dec 08, 2008 | Canon PIXMA MX310 All-In-One Printer
FAX back
Do you mean to get the paper document back out of the machine? If it doesn't feed out automatically, it may need to be repaired.
If you mean that you want confirmation that a fax was sent, you can turn on the TX (Transmit) REPORT. This will print out the first page of a fax sent successfully.
1. Press the Additional Functions button.
2. Use the arrows to select FAX SETTINGS. Press the Set button.
3. Use the arrows to select REPORT SETTINGS. Press Set.
4. Use the arrows to select TX REPORT. Press Set.
5. Use the arrows to select OUTPUT YES. Press Set.
6. Press the Stop/Reset button.
The machine will automatically print an Activity Report after every 20 faxes (sent or received). If you want an Activity Report at any time:
1. Press the Function button.
2. Press Report button (number 03 on the left side of the keypad)
3. Use the arrows to select ACTIVITY REPORT.
4. Press the Set button.
Apr 17, 2008 | Canon PC-1080F Plain Paper Laser Fax
Canon PIXMA MX320 Color USB InkJet Printer Logo
44 people viewed this question
old marine
old marine
