Question about Fargo DTC Office Equipment & Supplies
P2400 dtc - DTC Fargo Office Equipment & Supplies
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 179 Answers
What is the problem?
Posted on Oct 18, 2013
My 4x4 is not working on my 2007 Yukon, I replaced actuator and the lights on the selective dial work but no dash warning light.
replaced what actuator ? The 4X4 switch on the instrument cluster ? Did you ever think of having it check for DTC'S - diagnostic trouble codes ? There are a number of them , they are there for shorting diagnostic time DTC B0770
DTC B0775
DTC B0780
DTC B0785
DTC B0790
DTC B2725
DTC C0300
DTC C0305
DTC C0306
DTC C0321
DTC C0326
DTC C0327
DTC C0359
DTC C0374
DTC C0378
DTC C0379
DTC C0550
DTC C0558
Feb 23, 2017 | Cars & Trucks
Replaced 4wd switch on dashboard, did not solve problem. 4wd doesn't connect.
Which of these transfer case's does your truck have ?
Transfer Case - NVG 149-NP3 Transfer Case - NVG 246-NP8 Transfer Case - NVG 261-NP2 Transfer Case - NVG 263-NP1
The NVG 263 transfer case features a three button shift control switch located on the instrument panel.
DTC B0790 DTC B2725 DTC C0306 DTC C0327 DTC C0359 DTC C0379 DTC C0550
The NVG 246 EAU transfer case features a 4 button shift control switch located on the instrument panel.
DTC B0790 DTC B2725 DTC C0300 DTC C0305 DTC C0306 DTC C0321 DTC C0327 DTC C0359 DTC C0374 DTC C0379 DTC C0550
Regardless both of these switch's are input's to a control module . There are probably DTC'S - diagnostic trouble codes stored . You should have the vehicle checked for DTC , That means taking you vehicle to the repair shop .
Mar 26, 2016 | 2004 Chevrolet Silverado 1500 Crew Cab
2001 Chevy S10 4x4 4L60E transmission works perfectly until 50MPH then I lose 3rd and 4th gear, 1st, 2nd and reverse are normal. Never happenend before, been parked since. Fluid is clean. Any ideas?
Are there any DTC's - diagnostic trouble codes ?in the PCM / BCM ? You have third an fourth below 50 mph but above 50 it down shifts to 2nd gear ,is this what your saying or you don't have 3rd or 4th gears at all ? Which engine did yours come with ? 2.2 L or 4.3 L You trans can set several DTC'S an not all will turn on the check engine light .
DTC B2722 (4.3 L) DTC P0218 (2.2 L) DTC P0218 (4.3 L) DTC P0502 (2.2 L) DTC P0502 (4.3 L) DTC P0503 (2.2 L) DTC P0503 (4.3 L) DTC P0705 (2.2 L) DTC P0706 (4.3 L) DTC P0711 (2.2 L) DTC P0711 (4.3 L) DTC P0712 (2.2 L) DTC P0712 (4.3 L) DTC P0713 (2.2 L) DTC P0713 (4.3 L) DTC P0719 (2.2 L) DTC P0719 (4.3 L) DTC P0724 (2.2 L) DTC P0724 (4.3 L) DTC P0740 (2.2 L) DTC P0740 (4.3 L) DTC P0741 (4.3 L) DTC P0742 (2.2 L) DTC P0742 (4.3 L) DTC P0748 (2.2 L) DTC P0748 (4.3 L) DTC P0751 (2.2 L) DTC P0751 (4.3 L) DTC P0752 (4.3 L) DTC P0753 (2.2 L) DTC P0753 (4.3 L) DTC P0756 (2.2 L) DTC P0756 (4.3 L) DTC P0757 (4.3 L) DTC P0758 (2.2 L) DTC P0758 (4.3 L) DTC P0785 (2.2 L) DTC P0785 (4.3 L) DTC P1810 (2.2 L) DTC P1810 (4.3 L) DTC P1860 (2.2 L) DTC P1860 (4.3 L) DTC P1870 (2.2 L) DTC P1870 (4.3 L) DTC P1875 (4.3 L) .
Shift Pattern This category contains the following topics:
One forward gear only
Two forward gears only
Gear missing or slipping
No upshift or slipping upshift
No downshifts
Non-First gear start
Refer to First Gear Range Only - No Upshift .
Refer to Third Gear Only .
Refer to Second/Third Gear Only or First/Fourth Gears Only .
Refer to Slips in First Gear .
Refer to Slipping or Harsh 1-2 Shift .
Refer to No 2-3 Shift or 2-3 Shift Slips, Rough or Hunting .
Refer to No 3-4 Shift, Slips or Rough 3-4 Shift .
Refer to No Part Throttle or Delayed Downshifts .
Refer to Second Gear Start .
Feb 18, 2016 | Cars & Trucks
My top does not work
Diagnostic Starting Point - Roof (Folding Top)
Begin the system diagnosis with the Diagnostic System Check - Vehicle in Vehicle DTC Information. The Vehicle System Check will provide the following information:
The identification of the control modules which commands the system
The ability of the control modules to communicate through the serial data circuit
The identification of any stored diagnostic trouble codes (DTCs) and their status
The use of Vehicle System Check will identify the correct procedure for diagnosing the system and where the procedure is located.
Have vehicle scanned for DTC'S . The power roof has a number of DTC'S that can be set ,could make diagnosing easier !
DTC B1010 DTC B1296 DTC B1307 DTC B1325 DTC B1335 DTC B1345 DTC B1395 DTC B316A DTC B3602 DTC B3669 DTC B366A DTC B366B DTC B366C DTC B366D DTC B366E DTC B3674 DTC B3675 DTC B367A DTC B367B DTC B367F DTC B3680 DTC B3683 DTC B3685
There are a number of sensors for your convertible top !
DTC B1010 08: System Sensors Data Mismatch signal invalid
DTC B1010 08 sets when the folding top control (FTC) module detects a switch is not in the proper state when compared to other switches. The conditions that cause DTC B1010 08 to set may also set other Folding Top DTCs. The position and direction of the folding top when the fault occurs will determine whether DTC B1010 08 will set or another Folding Top DTC will set. If any Folding Top DTCs between DTC B1296-DTC B3685 are set, diagnose those DTCs first. After diagnosing any other Folding Top DTCs, clear DTCs and operate the Folding Top to see if DTC B1010 08 resets before diagnosing it.
DTC B1296 01: Movable Roof Header Unlatched Sensor Circuit short to battery
DTC B1296 06: Movable Roof Header Unlatched Sensor Circuit short to ground or open
DTC B1296 58: Movable Roof Header Unlatched Sensor Circuit incorrect reaction after event
DTC B1296 59: Movable Roof Header Unlatched Sensor Circuit circuit/component protection time out
You best bet is to take your vehicle to a ASE certified repair shop or to a GM dealer .
The f
Jan 14, 2016 | 2007 Pontiac G6 GT Convertible
I put another abs moule on my 2002 Cadillac and lights are still on how do I clear the lights
Have the codes checked ! Do you know what codes are ,What the light is for ? The light is to warn the driver that there is a problem in the ABS system . Have the codes checked before replacing parts ,the code will point you in the direction to go .This system can set numerous DTC'S
DTC C1211 DTC C1214 DTC C1217 DTC C1218 DTC C1221-C1235 DTC C1236 DTC C1237 DTC C1238 DTC C1242 or C1243 DTC C1248 DTC C1251 (w/F45) DTC C1254 DTC C1255 or C1256 DTC C1261-C1274 DTC C1276, P1644, or P1689 DTC C1277 or P1571 DTC C1278 DTC C1281, C1283, or C1286 DTC C1282 DTC C1284 or C1285 DTC C1287 or C1288 DTC C1291 or C1293 DTC C1294 DTC C1295 Maybe your best bet would be to take your vehicle to a ASE certified repair shop or the dealer
Jan 10, 2016 | 2002 Cadillac Deville
Push button for four wheel drive isn't working
Do you have any lights on the dash lit ?
SERVICE indicator (4WD/AWD) Lamp
The SERVICE indicator (4WD/AWD) lamp is an integral part of the cluster and cannot be serviced separately. This lamp is used to inform the driver of the vehicle of malfunctions within the automatic transfer case (ATC) system. The SERVICE indicator (4WD/AWD) lamp is controlled by the transfer case shift control module via CKT 1567. this system will set DTC'S if there is a problem .
Diagnostic Trouble Codes DTC B2725 ATC Mode Switch Circuit Malfunction DTC C0300 Rear Speed Sensor Malfunction DTC C0305 Front Speed Sensor Malfunction DTC C0308 Motor A/B Circuit Low DTC C0309 Motor A/B Circuit High DTC C0310 Motor A/B Circuit Open DTC C0315 Motor Ground Circuit Open DTC C0323 T-Case Lock Circuit Low DTC C0324 T-Case Lock Circuit High DTC C0327 Encoder Circuit Malfunction DTC C0367 Front Axle Control Circuit High DTC C0374 General System Malfunction DTC C0376 Front/Rear Shaft Speed Mismatch DTC C0387 Unable to Perform Shift DTC C0550 ECU Malfunction DTC C0611 VIN Information Error you probably should take this to a repair shop !
This tt
Feb 22, 2015 | 1999 Chevrolet Silverado 1500
I have a 2003 vw passat with multiple codes p2257,p0414,p2400,p0341,p0030
if the cats are getting red they need replaced its stop up and thats y u have no power your motor has to breath meaning its getting air in the intake but the cats are stoped up so air cant leave the motor replace them and you should be ok
Sep 14, 2014 | 2003 VW Passat Power Heated Mirror Driver...
35 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
pkwc
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
