Question about Garden
HI ,when I turn the ignition key the engine will not turn over.
  • 43 Answers
1. Make sure the mower deck is off.
2. Make sure the brake peddle is pushed in.
If that does not work there is several other places to check. If you have a test light or a multi-meter check the battery. Then move on to the safety switches, solenoid, and ignition switch.
Posted on Oct 18, 2013
If you change ignition switch do keys have to be recoded.
Hi
Yes I do believe that the keys will have to be coded to the new ignition switch as the codes won't match with your old keys
Hope this helps Nick
Dec 30, 2017 | Cars & Trucks
How do I reset the anti theft system
Hi Jodi, My name is Randy and I'm going to try and help you with your problem. Your anti-theft system is what's called PassKey this is the reset procedure.....Before you attempt this you must have a fully charged battery. 1.) Turn Ignition key to On position and attempt to start the engine, If it doesn't start release the ignition key to the On position. 2.) Security light will illuminate, Wait 10-12 minutes until it turns off. 3.) Turn the Ignition key off for 10 seconds. 4.) Try and attempt to start the engine, if it does not start, You will need to follow procedures 1-4, 3 times. Hope this helps and Good Luck, Randy.
Jan 03, 2016 | 2001 Oldsmobile Silhouette
Truck will not shut off. Running without key in the ignition. How to turn off?
If you messed with the ignition system on the vehicle to get it started without a key then you disconnect what you did to now stop the engine.
Dec 07, 2015 | Cars & Trucks
Will car turn over with bad transponder
Hi Dave many do turn over it just stops the fuel or spark or both. Regards Jim...
May 21, 2015 | Cars & Trucks
Starting problem
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below and good Luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jan 01, 2014 | 2010 Harley Davidson FLHX Street Glide
Hi, I have a suzuki swift 2000 model, the key has snapped in the ignition, i have a used replacement ignition barrel and key. When fitted the engine turns over but won't start. I'm guessing th
This car has a chip key, you can't just put any old key in it it must be programmed to not turn on the security system and disable starting, which is what you have now, the system has locked you out.
Feb 10, 2012 | Suzuki Swift Cars & Trucks
The ignition key will not turn to turn the car on
Hi Key,
Does the key turn at all?
When you turn the key does the engine turn over or just click?
If the engine turns, is it strong or barely moving.
Please comment back with as much detail as possible, help us help you
Best regards,
Mike
Oct 03, 2009 | 2000 Pontiac Grand Am GT
Ignition wont turn off
Hi and welcome to FixYa,
Offhand, it would appear that some of the contacts of the main (ignition) switch has fused together. To check, with the ignition switch off and key removed, all wires from the ignition switch must have no 12 volts reading except for the red.
Good luck and thank you for asking FixYa.
Jun 28, 2009 | 1999 Yamaha YZF-R6
Start up problems.
Hi FrostyRage.
I believe your remote start is jumping where your problem area is. I believe it to be somewhere in the wiring leading away from your ignition switch, best guess that I have.
Greg.
Jul 31, 2008 | 1998 GMC Jimmy
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
