I HAVE UPGRADES ON MY COMPUTER SINCE 2000 p l e a s e HELP ME GET RID OF THEM I AM SURE THEY ARE THE REASON MY COMPUTER IS SO SLOW.. thank you
    Sergeant:
  • 320 Answers
Unfortunately removing upgrades will also remove functionality of any software you have installed. It may also break some applications and cause them to stop working all together.
The recommended course of action would be to back up any data you wish to save (Photos, documents, music, etc) to removable media like USB flash drive, DVD, or even CD. USB flash drives will provide you the most space for the least amount of cost.
Once all of your data is backed up and safe, You can perform a fresh install of your computers operating system. This may also be a good time to upgrade to a newer version of your operating system if your computer specs have the requirements of the new version.
Windows Vista system requirements:
http://support.microsoft.com/kb/919183
Windows 7 system requirements:
http://windows.microsoft.com/en-us/windows7/products/system-requirements
Windows 8 system requirements:
http://windows.microsoft.com/en-us/windows-8/system-requirements
If you are still using XP now is a good time to think about upgrading, as Microsoft no longer supports XP, and you will miss out on security updates to protect your computer from newer threats.
If all of the above is a bit too much, I would recommend possibly taking your computer to a trained computer repair shop to be checked out.
Please feel free to comment if additional help is needed.
Posted on Oct 17, 2013
Network sharing center won't stay open
just been fixing a window vista laptop with problems
Microsoft stopped supporting windows vista years ago
no updates or upgrades
you are at base service pack one
and computer should have been updated to service pack 3 years ago
from service pack 3 a windows 10 upgrade is possible
try an ethernet or usb wifi connection .
.see if the computer will run the way you want it
any windows vista computer is a x32 bit system
with upgrades can run x64
x86 is the current
if you are running anything higher than 32 or x64 software the computer will be slow sometimes freeze or shut down
vista came out same time as and dial up internet
and early broad band
vista can run office 95 but windows 2000 is stable
May 29, 2016 | Microsoft Windows Vista Home Premium with...
My laptop is running slow
If your problem is that your computer is very slow and you have upgraded your memory to the maximum, then you should concentrate on cleaning up and optimising the Windows file system.
Download and install the following utility programs that can help you to improve the performance of your computer.
Advanced System Care Free - run the Deep Care option of this utility.
DiskMax - run a Detailed Scan and let it clean up all profiles, updates, cache etc.
Smart Defrag - run a Defrag and Fast Optimize
CCleaner - use this to compliment the above plus use the Tools Uninstall option to remove any unwanted software programs, browser tool bars etc. Also use the Tools Startup option to disable any of the programs being started on every boot that don't need to be, i.e. things like QuickTime, Adobe Reader etc.
One of the easiest methods of determining what memory your computer has and what upgrades you can install is to go to the Crucial Memory web site and use their Crucial System Scanner Tool, this will try to detect exactly what make and model your system is, and from this advise both what the currently installed memory is, and show compatible memory upgrades for your system.
Jan 14, 2012 | Computers & Internet
My computer is not performing to good. I'ts slow
Issue
My computer is running slow what steps can I do to fix it?
Cause
This issue can be caused by any of the below possibilities.
Not enough hard disk space.
Left over programs and bad files.
Data Corruption.
Missing Windows updates / Outdated drivers.
Computer is overheating.
Corrupt OS.
Bad Hardware.
Solution
This page only cover an overall slow computer and not a computer that has a slow boot up.
Try to use CCleaner which deletes the temp files
http://download.cnet.com/ccleaner/
Oct 20, 2011 | HP Compaq nx6310 Notebook
Slow to open
Is this slow when start up the computer or slow when you open an application?
If slow when start up the computer, the reason is your computer has too much start up programs and services. All these software, services is required to open as start up of the computer, that reduce speed of log on/ start up process. You can speed up by try these steps:
1. Start - Run: type: msconfig and hit enter.
2. The System Configuration Window will appear. Click on Selective Startup. Then go to Start up tab, untick the process that you think it not importance for start up such as Acrobat Reader...ect. 3. Then hit apply and restart your computer. You can disable all of start up services.
If slow when you try to open an application, then the reason is your computer busy work with some other higher piority process. If you think that you need this application open quicker, you can go to Task Manger and End the task you don't want it run or the task that took a lot of CPU resources.
Hope this will hellp
Thanks for reading.
Jul 20, 2011 | Computers & Internet
Pc is very slow
You can speed up a slow running PC by:
-- cleaning system junk
-- optimizing computer services
-- optimizing internet
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
Thank you..
Mar 02, 2011 | HP Vectra Xe320 PC Desktop
Hi my pc going slow
TRY EMPTING UNWANTED FILES. INCREASE RAM.SCAN WITH QUICK HEAL ANTIVIRUS TRIAL FOR VIRUS.THESE ARE MY SUGGESTIONS
Sep 24, 2010 | Computers & Internet
Yahoo messenger is not responding while clicking it is not poening
When you close the prog.that is it ,you just closed it .and you have to find the soln,you might want to try DIAGNOSE THE PROBLEM,it might help you or suggest to you what to do,or gives you an error msg you can work with,or go to microsoft.com/error messages/help,and see what you can do.THE REASON for all that could be your msgr version is not compatible with the operating system on that computer while it works fine on others.SO YOU EITHER UPGRADE THE O.S,orDOWNGRADE THE MSGR VERSION.Also make sure that o.s.and or antivirus firewalls are not blocking it,and allow it.Could be slow connection,or slow connection to msgr or msn,make sure nothing running in background such as antivirus scanning,or live sreaming or video,while running msgr.And it would not hurt to scan your computer to get rid of any junk before you even srart troouble shooting.Start with easy solns first.good luck.
May 19, 2010 | Yahoo Messenger
MY MAC LAPTOP IS RUNNING KIND OF SLOW- I DO NOT KNOW HOW TO CLEAN
Well, generally speaking there are a number of reasons that may causing a Mac computer running slow, but commonly two factors: hardware part & system part. For hardware part: I guess it's OK if your Mac is not that old. For system part: there might be a lot of junk files, caches, registry errors... out there which largely slow down any Mac machines. about 80% slow Mac caused by this reason, if so, try cleaning the system from: http://www.howtospeedupmac.com/
Jan 17, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
Psp gone really slow
try getting a memory stick for it.. so then lots of the memory is free'd up
Dec 28, 2008 | Sony PlayStation Portable (PSP) Console
67 people viewed this question
 Grubhead
Grubhead
