Question about Cobra 25 WX-NW-ST 40-Channels Base CB Radio
I have a cobra 25 ltd classic and im wanting to use the pa function but when i plug the speaker in it doesnt put my voice thru it but the speaker works on the cb function whats wrong with it?
    Scholar:
  • 95 Answers
It sounds like the switch is bad. I'd have Cobra warranty it for you.
Posted on Oct 18, 2013
Dodgem250
  • 68 Answers
SOURCE: Cobra 29 LTD Classic Operations Manual
For the operation manual, go to cobraelec.com or:
http://cobra.com/downloads/manuals/29LTDCLA.PDF
Thanks!
Dodgem
http://dodgem250.angelfire.com
Posted on May 10, 2008
Benimur
  • 6966 Answers
SOURCE: Cobra 29 Ltd
Appreciate the direct "Ask Me" again.
The initial posting would still hold true, best would be:
  • remove TR18;
  • replace 2SC2069 with 2SC1969; and
  • adjust L12, 13 & 14.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 08, 2008
  • 773 Answers
SOURCE: cobra 29 ltd classic cb not transmitting
Check the ground. Make sure its grounded well on bare metal. To see if the ground is bad, or not making good connection, disconnect the antenna and turn it on. if it does not power up, that means your ground is bad, and it was grounding only through the antenna.
Make sure not to key up with out the antenna connected.
Posted on Feb 08, 2009
  • 773 Answers
SOURCE: cobra 29 ltd classic antenna calibration ??
Wow. That's not at all a solution to what this guy is asking. And why all the caps??
The one point jm77437 has that is correct is that you do not set the radio, you set the antenna. The rest is blah blah.
Here is how you tune your antenna for you radio. First off it depends on what kind of antenna you have. most fiberglass antennas have a tunable tip to adjust the height of the antenna. Metal whips either have a collar at the base that the whip will either slide up or down in to adjust the height. The other type of metal whip's you have to physically clip to shorten the antenna, you must be careful with this type because once its clipped, that's it. You cannot add what you cut off.
I am going to give this example using a metal whip with an adjustable collar.
First after your radio is hooked up in the vehicle, drive to an open lot. Buildings and other structures can cause extra reflection. turn to channel 1. Flip the meter to CAL. Key the mic without talking. Now turn the CAL knob up until the needle reaches the little upside down triangle all the way to the right marked CAL. Now you have just celebrated your radio for your setup to measure you SWR. Now while still holding the key, flip the meter switch to SWR. The needle will move, and where it stops is your SWR reading. The lower the better. Anything under 1.5 is considered really good. But still, the lower the better.
Make note of what your SWR was on ch 1.
Now flip to channel 40. Repeat the SWR process. You must recalabrate each time you take a reading.
Now like jm77437 said. If your SWR reading is higher on 40 then 1, then your antenna is too long, and you must make it shorter. Loosen the collar and lower the antenna in the collar 1/4 inch at a time. check the swr each time you adjust the antenna.
If your SWR reading is higher on channel 1, then your antenna is too short. You must make your antenna longer. Do this by loossening the collar and pulling the antenna upward in the collar 1/4 inch at a time, again checking the swr each time you adjust the antenna.
What you want to achieve is having the same SWR reading on channel 1 and 40. then you have the best match you are going to get with that antenna.
If your swr is under 1.5 on all channels, you don't need to fuss unless you are a perfectionist. then by all means go ahead.
If your reading is higher then 3, or your ant light comes on, something is really wrong. Make sure your antenna is connected all the way, and the coax is not damaged.
Its important to have an appropriate SWR because if you do not, you are reflecting too much signal back into the radio, and eventually you will burn out your final transistor, and your radio will be toast.
Some tips: make sure you check the swr with the doors and windows shut. Make sure you are in an open lot. Remember to calabrate ecah time you take a reading. If you have had your radio peaked by a radio shop, and they have lowered your dead key, or have done a swing modification, then the meter in your radio will not work when taking an SWR reading and you will have to use an external meter.
Posted on Apr 24, 2009
  • 773 Answers
You should not calibrate the antenna before you install it on the car!! the antenna needs to be calibrated on the vehicle that it is going to be on. Type of vehicle, different mounts, and many other variables can change the amount of reflection you will get.
j0hn9999 did a much better job but left some info out.
Take your SWR readings on channel 1, then on channel 40.... NOW, if your SWR is higher on ch 40 then ch 1, then your antenna is too long and it needs to be shortened. Refer to the antenna instructions on how to shorten the antenna.
If your SWR is higher on ch 1 then on ch 40 then your antenna is too short. You must lengthen the antenna. Again refer to your antenna instructions on how to lengthen your antenna.
You must calibrate each time you take a reading.
Make sure your doors and windows are shut when taking a reading
Make sure you are in an open lot when taking a reading as buildings, trees and other structures can cause reflection and give you an inaccurate reading.
If you adjust the length of your antenna on another vehicle and then put it on yours, the SWR will be off. It will need to be tuned again.
An external meter is better then the one in the radio, but will need to be hooked up in the vehicle you have the antenna on.
If you are not running any kind of power, or do not have a swing kit installed, and the radio is stock, the meter in the radio is more then enough to get a correct SWR reading.
Cobra 25 soundtracker with nightwatch
plug the external speaker into your PA jack and select the PA switch. If PA works then the audio chip is good. The cobra 29 must have a mic plugged in to get receive audio, You may have a broken wire at the mic connector.
Jun 19, 2014 | Cobra 29 LTD CB Radio
I have a Cobra ltd 25 classic in my pick up. the cb will turn on but i cant get any stacik no matter where i turn the squelch or rf gain. this doesnt seem right because it has never done that before. but...
Does the signal meter show any signal? Try plugging something into and out of the EXT Speaker jack to see if maybe that is preventing the internal speaker from working, or plug in an external speaker or headphone to test it. If the meter shows nothing, I'm concerned about your electronics, especially with the 'squelch' control 'wide-open'. 73's
Aug 13, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
When the mike is keyed to TR my audio comes thru the speaker. Cobra 29 LTD Classic. Best Regards Jim
If your voice is coming through the speaker when you transmit, it means you have talkback installed. If you don't like it, take it to a reputable CB shop and ask them to remove it.
Aug 06, 2010 | Cobra 29 LTD CB Radio
How do you hook up a pa to afree spirit model number tr127fs cb radio
You can get a pa speaker at Radio Shack.....in the back of the radio there should be a pa jack, just plug it right in and put your radio on pa function, and you should be ready to go.....hope this helps....
Mar 07, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
PA squalls when mike pushed
Try running a temporary wire for grounding.
Tom
Jun 29, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Weather bleads Over on 21 LTD WX CLASSIC(*HELP*)
sounds like your wx receiver is being activated by a bad switch replace the switch to disable the wx when you dont want it to come thru
Jun 10, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
PA speaker quiet
I think this is a double post,, am I right Freddy??? Mechanic
Oct 22, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Sound, But VERY VERY quiet
I have the identical model and also had the same problem. I took it in to an appliance repair and they found a problem with the output circut something about a burnt transistor is what they said. I had them replace it and has been working fine since. Hope this helps.
Feb 07, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
No sound
Yes It sounds as though the audio amp may have taken the hit go to this link and download the service manual it will give you voltage info http://www.cbtricks.com/radios/cobra/25ltd_st_25wx_st/index.htm ...Chia
P.S. If you have an external speaker plug it in to the PA hole on the back put the radio on PA and see if you get any sound then if the dynamike is turned up it will be LOUD.If not I would replace the audio amp.If you need one let me know and ill directc you in the right direction...Chia
Jan 10, 2008 | Radio Communications
Cobra 25 WX-NW-ST 40-Channels Base CB Radio Logo
76 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
