Question about Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer
Has anyone got the maintenance menu function codes for a 330c?
    Champion:
  • Brother Expert
  • 265 Answers
Specific functions only will be given
Posted on Dec 09, 2014
Brother DC8060 how to reset fuser life
ENTRY INTO THE MAINTENANCE MODE
Press the [Menu] and [Start] keys. Next press the [/\] key four times to make the machine enter the maintenance mode.
FAX models equipped with numerical keypads can enter the maintenance mode by pressing the [Menu], [*], [2], [8], [6] and [4] keys in this sequence.
The machine beeps for approx. one second and displays MAINTENANCE " on the LCD,
indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the keys.
To select one of the maintenance-mode functions press the [/\ ] key or [\/ ] key to display any function code on the LCD. Then press the [OK] key 88 Counter Reset After Replacing the Fuser Unit, Laser Unit and
Paper Feed Kit
Jul 21, 2014 | Brother MFC Office Equipment & Supplies
Enter maintenance mode
Menu. Black Start(Mono Start), Menu and Black Start(Mono Start) "Maintenance 10" will display on the LCD
Dec 07, 2013 | Brother DCP-330C All-In-One InkJet Printer
My printer brother dcp-330c have "unable to clean 46" problem.. the answer in your website doesn't help as i was unable to enter the maintenance mode from the instruction.. my printer does not...
I developed the same problem "unable to clean 46" on my brother dcp -330c printer.. after taking to a maintenance guy... he told me to remove my ink absorption pads and wash them out with water and leave to dry then once dry replace back in..
Apr 14, 2011 | Brother DCP-330C All-In-One InkJet Printer
Whenever i turn on my printer it always says error 46
1) Enter machine maintenance mode. Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 27, 2010 | Brother DCP-330C All-In-One InkJet Printer
Unable to clean 46 error for a brother DCP-330C printer
Error "unable to clean" on Brother MFC Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 28, 2010 | Brother DCP-330C All-In-One InkJet Printer
Brother printer dcp 330c - unable to print 50 error
Hi there
Solution:
· Machine off
· Press 80
Dec 05, 2009 | Brother MultiFunction Center MFC-440CN...
Does anyone have the reset codes for a brother dcp 115c printer. error code 46 unable to clean. can only find the instructions for the 110c on here.
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
Sep 02, 2009 | Brother DCP 115C All-In-One InkJet Printer
Unable to print 46
This is mainly due to dirty machine. Try following my steps:-
1. Press the Menu & Mono start keys. Next press the up arrow key 4 times to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. Press the mono start key several times untill the purge count appears on the LCD.
4. Enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero.
5. Press the stop/exit key to return to the initial stage of the maintanance mode.
6. Enter 9 twice by using the up arrow & set key's to exit from maintenance mode
Aug 14, 2009 | Brother DCP-330C All-In-One InkJet Printer
How to fix clean unable 46, pls tell me how
This is for the mfc5440 but should work I would really need the cleaning absorber pad replaced but takes a bit of getting to. - Machine off - Switch on the machine while holding down the ?menu?button until all the leds are flashing on/off. Now you are in ?maintenance? mode. - press 80 - press the ?mono start? button several times until you see ?purge: xxxx? - press ?2783? in order to reset the purge counter. You will see: ?purge:0000? - press the "stop" button. - press ?99? to exit the maintenance mode.
Jun 12, 2009 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer Logo
23 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
