Question about GE Continuous Feed Garbage Disposal GFC520F
Stopped working. power is to disposal. makes a slight buzz noise when I press reset button
  • 2,113 Answers
It has a piece of glass or a pit stuck in it etc. I have had to completely remove units to try to remove pieces. with your hand inside the bottom disc should spin easily, if not locate the particles... use a long screw driver etc. press the reset button if necessary and reassemble.
Posted on Oct 21, 2013
Is there a reset button on the insinkerator 5-plus-7 model?
There is usually a reset button on the edge of the bottom. But before you take the unit out, get a hex key that fits the end of the rotor in the middle of the bottom. Put a mirror under there, as it is easily visible from straight underneath, but not visible from the side. Work the rotor back and forth with the hex key (also called an Allen wrench.). When you do free it up, and run it again, use lots of water. Good luck.
Dec 20, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Buzz noise behind dashboard 2001 GS300 LEXUS
The buzz noise is probably coming from the airflow controls turned off but being stuck in a particular mode such as vents and feet mode or winshield and feet mode, creating a buzzing noise while it is turned off. To stop the buzzing noise turn off the aircondition / heat by pressing the off button, next press the mode button for the fan controls to make the picture point to face only not feet or winshield, this should stop the noise.
Oct 01, 2010 | 2001 Lexus Gs 300
Drum will not turn and there is no heat.
This dryer has a circuit board that controls virtually everything. If it makes a buzzing noise when you press the power button to turn on the control panel, it's probably not going to be an easy fix. When you hire a professional, you avoid buying expensive parts that you might not need, such as a control board. If it makes a loud buzzing noise when you press the start button, it's possible that it could be a motor or belt problem. But again, I'd recommend a service call for this one.
May 25, 2010 | Whirlpool GEW9250 Electric Dryer
Admiral capacity plus stopped working mid cycle no power
When u press the knob to start the dryer is there a buzzing noise ???
If so i guess u nee to order a new moter ...
u can do it at..www.appliancepartspros.com
Jan 07, 2010 | Dryers
PS3 HDMI connection issues
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
Oct 21, 2009 | Sony Playstation 3 (PS3) Console
I turned on the wall swithch. there is a buzzing noise but no movement. blades move freely when i hand turn them. i have unpluged the unit from the wall, still no movement
I think you are talking about a disposal. Since the blades move freely and you have actually unplugged it from the wall, feel all around the bottom of it for a reset button. Even if you have removed power, if this button clicks when you push it, it was tripped. Otherwise, my disposal just did the same thing. The type I have only last for 2 years. Mine buzzes and thats all. The motor has gone out. I will have to replace mine. You may as well.
Jun 10, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Garbage disposal won't work!
Check to see if the cutting plate is free and will turn-be careful and be sure no one can turn the unit on while you are trying to turn the cutting plate-it is located in the drain hole that the food goes down. If it is locked up, hardware stores sell a special tool to break it loose. It should not be too expensive. If the blade is free, the motor is probably burned out.
Feb 03, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Open Questions:
See all GE Continuous Feed Garbage Disposal GFC520F Questions
GE Continuous Feed Garbage Disposal GFC520F Logo
291 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
