Question about Buffalo Technology Computers & Internet
Removing encryption How do I uninstall the encrytion that is on my buffalo ministation?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 141 Answers
You can uninstall it on your buffalo mini station. The software are hidden on the drives just show the hidden files.
Posted on Oct 18, 2013
5 Suggested Answers
  • 88 Answers
SOURCE: buffalo ministation
if you dropped your hard-drive and it stopped functioning - high chances that the drive has a physical crash. Best suggestion will be to contact a professional data recovery team if the data on the drive is really important (Coz, they charge a bomb for the recovery) Suggestion would be to talk to drivesavers.com
Posted on Jan 11, 2009
bob_computer
  • 3153 Answers
SOURCE: remove all programs and encryptsion software from buffalo minista
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
BUT the section that may be of interest to you is just after step 5.
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Posted on Aug 23, 2009
  • 224 Answers
SOURCE: I have a buffalo ministation
It is possible to recover data after formatting. This guy does it remotely and works off of donations http://FreeDataRecovery.us
Posted on Jul 24, 2011
Geekman
  • 32281 Answers
SOURCE: Hi, I forgot my password for Buffalo Ministation 1TB Encrypted External Hard Disk and changed the password, later when I wanted to access files, I guess I typed old or wrong password for more than 10
Hard drive password is diffecult to remove.
These WEB sites maybe able to unlock the HD password.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/
A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
Posted on Dec 05, 2012
Formatting buffalo ministation stealth for mac
Probably the software could not recognize or support the disk type/model
Dec 18, 2013 | Buffalo Technology 1tb Ministation Stealth...
My buffalo hd pntu3 hard disk is encrypted using the default software from drivenavigator , securelock easy manager. how to remove the encryption?
In the software Secure Lock Manager Easy is a tab "Setting the Encryption mode" Pressing "Releasing encryption mode" will remove the encryption. Make a backup of the data before please.
Nov 03, 2013 | Buffalo Technology Buffalo MiniStation...
Buffalo Ministation not flashing or recognized
Im having the same problem sound like your cable is not working or you need a new case because the pins are broken.
Jul 22, 2013 | Buffalo Technology 320GB MINISTATION TURBO...
HD-PE500U3/BK-EU does not work
Compatible
Windows 7 (32/64 bit), Vista (32/64 bit), XP (32 bit), Mac OS X 10.4 or later (*2)
You could download and use TrueCrypt. It's free and has very strong encryption. http://www.truecrypt.org/
Jan 01, 2013 | Buffalo Technology Buffalo MiniStation...
I need to download secure lock ware
If you want to encrypt the drive. I'd suggest truecrypt. It's free and you can encrypt the entire drive.
Dec 22, 2012 | Buffalo Technology Buffalo MiniStation...
Can't see my buffalo usb ministation under my computer
right click on my computer click manage, then in the new screen click on disk management, can you see the device there? if so right click on it and click delete partition, then after right click and make a partition and format it with a quick format, this should then show it in mycomputer ,this will delete all data on the hard drive!
Jul 02, 2009 | Buffalo Technology 320GB MINISTATION TURBO...
How to open the case safely (without damaging it)?
Remove all screws from the enclosure, and then slide a then metal (non magnetic) slide to pop the clips off of the sides of the enclosure, lengthwise. You can do it without breaking the plastic
Jul 13, 2008 | Buffalo Technology MiniStation Turbo 120...
Computers & Internet Logo
132 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
