Question about Microwave Ovens
Sharp r250a microwave
How do I defrost things? I press defrost button but then can't press anything else? thanks
  • Microwave Ovens Master
  • 9,047 Answers
Try hitting "defrost" once, then hitting "defrost" again to see if it brings up any options. Otherwise Google the words Sharp X customer support (where X is your country name) and only click a link which is an official Sharp site, not some click aggregator (*cough!*) or malware site.
Posted on Oct 17, 2013
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp R-510AK Microwave Oven Fuse Blows
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links you or a friend can use for test help, but read their safety warnings first:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from Sears or from Tritronics at http://www.wehaveparts.com
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Microwave TimeCook defaults to Defrost Auto
It sounds like your keypad (membrane switch) is failing.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting. You can use it to test for a bad keypad.
If you'd rather have us fix it for you, we do that for $39.95 plus parts and you can visit us via our link her eon Fixya http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Carousel Microwave R-320FQ Serial # 26805 Mfg. Dec. 2002
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
It may have an intermittently shorting keypad or another problem on the control panel, which we repair for customers nationwide with our guaranteed $39.95 service.
Posted on Aug 09, 2008
  • 36 Answers
SOURCE: Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Posted on Jan 08, 2009
  • 3741 Answers
SOURCE: sharp carousel microwave model # 508ak has power
9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section. Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
thanks.
Posted on Jul 11, 2009
I can't defrost in the microwave Sharp S-250a. I choose defrost but then I can't choose any other option to set the time or start! thanks
GO IN CONTACT WITH SHARP...HAVE MODEL NUMBER READY......AND IF UNDER WARRANTY....GETTING IT FIXED OR GET SERVICE GUY OUT
Oct 17, 2013 | Sharp Microwave Ovens
Hi sharp microwave R-33ST 900w was used to defrost now won't heat anything up how do I change settings back?
It should default to the highest power setting.
If not, you can reset it by unplugging the power for a minute or two, plugging it back in, and setting the clock.
Otherwise, refer to your owner's manual.
Apr 15, 2013 | Microwave Ovens
WE have a Sharp Carasel Microwave and do not know how to defrost anything. Can you help?
You can download Sharp microwave owner's manuals here.
If you don't find your exact model listed, a similar one will do or call Sharp toll free at 1-800-BE-SHARP (1-800-237-4277).
Aug 18, 2010 | Microwave Ovens
My microwave has 00:00 where the time or cooking mins should be displayed. I am pushing buttons and nothing changes. I can't use the microwave.
Unplug the microwave for 10 minutes and then replug-in. This will reset the unit.after that if it still behaves abnormally , Press cancel button for 10 seconds and then try pressing the timer adjust buttons.
thanks
Aug 31, 2009 | Sharp Microwave Ovens
Sharp carousel microwave model # 508ak has power but does not heat food when you press the start button. thanks in advance!
thanks.
Jul 11, 2009 | Sharp R-510HW Microwave Oven
Stuck on but no power
it is the problem of the faulty heating element .the heating element needs to be replaced to solve this heating problem.
Dec 29, 2008 | Microwave Ovens
My microwave sharp 220hw 8oowatt
After snubbing the darned thing overnight, plug it back it to see if it has recovered. These things do have primitive computers and we all know how reliable those things are- It may just have 'crashed,' just like seemingly all others.
Nov 05, 2008 | Sharp R-220HW Microwave Oven
I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Gert
Aug 05, 2008 | Sharp Microwave Ovens
Jun 08, 2008 | Sharp R-1480 Microwave Oven
Manual for sharp carousel R-230 AV
Please walk me through the defrost on my sharp micor
Sep 21, 2006 | Sharp R-230 Microwave Oven
Microwave Ovens Logo
80 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
