Question about Saws
CRAFTSMAN JIG SAW SHUT OFF IN MID CUT AND NOW WILL NOT START
    Master:
  • 796 Answers
Did you get a smell of burning at that moment? the motor may be burnt out by the strain.
Posted on Dec 18, 2013
4 Suggested Answers
SOURCE: Instruction manual for Bosch Jig Saw 1587AVS
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00061v-1.pdf
This is the Owner's Manual for the Bosch 1587AVS Jigsaw.
Posted on Jun 24, 2009
rowdy45176
  • 2176 Answers
SOURCE: Need owners manual and parts manual for a
found a parts breakdown but most of the parts listed are obsolete no replacement. You can go to Searspartsdirect.com and type in your model number to look at it. Good Luck
Posted on Aug 27, 2009
Testimonial: "Just what I needed. This was my father's jig saw and i am trying to get it operational again. Some of the pieces that i need are even available!"
  • 95 Answers
SOURCE: My jig saw doesn't cut a straight line
Jigsaws aren't known for their straight cut performance. Use a radial saw.
Posted on Jan 08, 2010
I need a blade clamp for a model 105112 Mastercraft jig saw. Is there a substitute or universal clamp that fits?
Jig Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/jig-saw.html
  1. Cached
  2. Similar
Shop online for jig saw replacement parts for fourteen of the world's most trusted brands at Tool Parts Direct. We have the largest online inventory of Bosch jigsaw parts, Dewalt jigsaw parts, Black and Decker jigsaw parts, as well as replacement parts from other top manufacturers ...
mastercraft jig saw model 105112 Questions & Answers (with Pictures ...
www.fixya.com > Forum > Tags
  1. Cached
  2. Similar
Find solutions to your mastercraft jig saw model 105112 question. ... i need a parts list for a mastercraft jigsaw/sabre saw model 105-106 See this webpage: ...
Craftsman Jig Saw Parts ' Great Selection ' Great Prices ...
www.ereplacementparts.com/craftsman-jig-saw-parts-c-158286_171667.html
  1. Cached
  2. Similar
Repair Parts Home Power Tool Parts Craftsman Parts Craftsman Jig Saw Parts. ... 07021 Craftsman Sabre Saw Parts. ... 315171600 Craftsman Sabre Saw 1/2 Inch Stroke Variable Speed Parts. 105112 Mastercraft jig saw Google Search
Nov 23, 2016 | Saws
I have a craftsman jig saw made in1959,and I can't find the screw to put the blade back? where can I find the screws
Look in your can of used screws if you have some and get one and keep trying the thread is the same as the one in the saw. It took some looking but I found one that works.
Feb 19, 2015 | Craftsman 1950s Sears Scroll Saw / Jig Saw
Need brushes for an older craftsman scrolling jig saw
If sears does not have them many hardware stores have a selection of brushes that may fit.
Jul 21, 2011 | Craftsman Saws
How to cut a 45 degree angle on wood using a jig saw
use a combination sliding square to mark ecxactly where you want to cut. Measure the distance from the jig-saw blade to the edge of the jig-saw bottom plate. Use this distance to mark another line parralel to the first line. Nail or screew a straight piece of wood on the second line. Put the jig-saw plate against the wood fence and cut your perfect line.
Mar 17, 2010 | Franke EuroPro Series GN1845SP Solid Wood...
Saw stopped working mid-cut as if power loss. Blade turns freely, was no unusual odor. Reset button no help. No problems prior to that event. This is a Craftsman 10" table saw.
Could be the motor burned out. That shouln't happen and if it did craftsman is really good at replacing damaged tools. I'd return it for a replacement.
Mar 04, 2010 | Craftsman 10" Table Saw
Blade won't stay straight
Use a higher quality blade, this will help.
It happens with a Jig saw. You have to mind the direction of the force you push on the unit.
A better blade will cut easier and faster and will be less likely to bend.
ALSO: this tool has orbital. This feature makes the unit cut much faster but is much less accurate for cutting. If you need to make a really straight cut, make sure orbital is off.
Nov 20, 2009 | Milwaukee Tool Milwaukee 6266 - 22 6.2 -...
Problem guiding the direction of cut with a jigsaw.
check that surface plate is square with the blade.don't push too hard,or force the saw,let it cut at it's own speed,guide rather than force.a scroll saw or band saw is more accurate as you control the work piece instead of the tool.
Oct 11, 2009 | Festool Jig Saw Circle Cutter - 490118
Need owners manual and parts manual for a craftsman jig saw 103-23151
Aug 27, 2009 | Craftsman Saws
Problems with Bosch T101BR 4 Inch 10 Tooth Jig Saw Blades
Hi, The reason for a down cutting blade is to see your cut on the finished side of laminates ( which include veneers, plywoods, plastics, formica . When using an upcutting blade on laminates the smooth cut is on the bottom, which you can not see till you are done and turn the work over. Reversing the teeth allows that smooth cut to be on the top. This is usually done on smooth flat surfaces as you have found out and does not work with orbital or tight scrolls. As far as the pushing or pulling, smooth cuts in laminates require the saw doing the work at a speed that allows the teeth to cut and remove material with biting. So if you are biting, (This is a much slower process than pushing your jigsaw through regular wood) check that you are not pushing too hard and that your blade is still sharp. Good Luck to you, this should Fixya!
Mar 08, 2009 | Bosch T101BR 4 Inch 10 Tooth Jig Saw...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
