"couldn't get pm power status" - Computers & Internet
2 Suggested Answers
emdzej91
  • 8 Answers
SOURCE: couldn't get PM power status MC9090
clean ribbon cable connector and connector at board
Posted on Dec 08, 2015
MC3090 "couldn't get pm power status"
I figured out, that the problem i caused by badly connected motherboard cable. I solved it by assembling the "display etc" part with the motherboard firts, then connecting the MB cable firmly, and finally put together with the "gun holder/battery closet" and secure it with screws
Feb 07, 2014 | Computers & Internet
Samsung Galaxy S4-Alarm Problem
Go to your alarm settings and make sure that the Smart Alarm is off, I know that the smart alarm makes the alarm go off early, this could be possibly be the problem.
May 23, 2013 | Samsung GALAXY S4
Couldn't get PM power status MC9090
Mc9090 does not have a battery door?! You should try a reflash by SD card or Activesync, you will need access to support.symbol.com and possibly a service contract to access the firmware.
Dec 06, 2012 | Zebra Symbol Technologies MC909X-G Series...
Could not get pm power status when turn on Mc9090
That error occurs when the LCD module is disconnected from the keyboard module. Check the ribbon cable/connector between the two. It has to be connected by hand prior to reassembling the unit.
Sep 27, 2011 | Symbol MC3090
The screen has been broken can it be repaired or replaced?
I couldn't find the screen in the available remplacement parts on their website so
you'll need to contact customer support to find out.
800-521-2010 in the U.S. and 877.352.8697 in Canada.
They will be able to issue a return authorization and advise you of any replacement/repair fees.
Consumer Services hours:
in the U.S.: Monday thru Friday, 8:00 AM to 4:30 PM, Central Standard Time
in Canada: Monday thru Friday, 8:30 AM to 5:00 PM, Central Standard Time.
Jul 31, 2011 | Vtech V.reader Animated E-book System
Couldn't get PM power status error shows while booting in MC3090-G.
Jan 06, 2011 | Symbol MC3090
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
HP4345 MFP printer and the print quality is fuzzy. I put in a new toner cartridge and that didn't work and i also created a cleaning page and that didn't help. what next? just had the tech out here last...
Fuzzy print is mostly related to 3 items in your printer. 1 the toner cart. 2 fuser. 3 transfer roller. A fuser replacement is a normal fix for this problem. Check your PM kit status by printing a supplies status page. A PM kit will have a fuser, transfer roller and feed rollers. If the PM level is low ,order and replace kit. If not you may want to get a new fuser
Sep 23, 2009 | HP LaserJet 4345mfp Printer
Burn fail or cd skip
Kind of sounds that way. They are pretty inexpensive now days, and simple to install.
Good luck
Mar 17, 2009 | Gateway M680X PC Notebook
YAMAHA CRW8424 gives Track following error..
PROBLEM DEFINITION: Basically, it is a hardware error that occurs when a drive is not capable of following a data track on a CD-R or CDRW or on the other hand, poor power flow may cause the problem SOLUTION: 1. Try use another disc, a disc with a different band. 2. If one doesn't work, you may have to open your system and use a different power connector, making sure no other devices are using the power connector in the same strand. 3. Lastly, if neither the above doesn't work, you may have to send your drive in for servicing as the head may be dirty or misaligned.
Aug 05, 2007 | Yamaha CRW 8424 Burner
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
