Question about Mitsubishi Xl1xu/sl2u Lcd Projector User Manual 268
Using the projector with an acer 500 tablet - Mitsubishi Xl1xu/sl2u Lcd Projector User Manual 268
    Habit-Forming:
    Scholar:
  • 85 Answers
See my Video on You tube explaining EZ 500 500 pro , maximum resolution settings on these is 800x600 on the 550 and 640x480 on the 500 and the only input is via a IBM input lead usually supplied with projector , the 15 pin vga socket is merely a monitor output .
Posted on Oct 07, 2015
    Champion:
  • Mitsubishi Expert
  • 225 Answers
Not sure the problem set the tablet resoulution to 1024 by 768
Posted on Nov 26, 2013
I have an acer iconia 500 tablet, it worked fine last night ,but today it wont get past the acer logo on boot.tried to do a hard reset and push button reset no joy ,any advice would be welcomed
lol I know that feeling...you need to reinstall the bios...you can find them on a flash drive on ebay. Or go free and use a flash drive to get it free online...go to acer.com...Its a known problem by Acer :) update: My Acer 500 stopped working Friday, with the very same freeze at Acer startup screen detailed here. Reset button didn't work (there's a post here that said he pressed the vol/up button while pressing the Reset button-I've only been inserting the tip of a paper clip to press button, which is the correct way?
Did the hold power button while pressing vol/up then sliding lock button back and forth. "Erasing Cache" appeared, but screen goes back to Acer startup and nothing.
Found this thread from a poster at Androidtablets.net. Downloaded one of the zip files posted here. Went to copy to an SD card, Can the file be placed on a USB drive instead? While trying the power "Bootloader vo.03.12-ICS Fastboot USB Download
Aug 13, 2016 | Acer Tablets & eReaders
Hi I have bought a Acer 500 tablet from a pawn shop and it has a Google account how can i remove that one so I can use mine
Drag the google icon to the Trash icon. Connect to the web and install Google again using your credentials.
Nov 16, 2014 | Acer Iconia Tab A50010S32u Notebook
My acer tablet will not stay on turns off immediately
There is a user manual for the A 500. Go direct to the Acer website and go to search...enter.. User Manual and you should be able to find an answer. It sound to me that in the 'set up' section you should be able to adjust the length of time the screen 'stays open' Of course this will use up more battery.
Sep 17, 2014 | Acer Iconia Tab A500-10S16u 10.1-Inch...
Can i transmit video from tablet to acer x1260 via bluetooth putting into the usb projector an usb bluetooth key?
Very doubtful without something inbetween like another computer. The USB connection is for direct connection to a device, see page 33 in this manual
http://www.projectorcentral.com/pdf/projector_manual_4015.pdf
Jul 07, 2014 | Acer X1260 DLP Projector
How to connect my acer iconia tablet to my epsom data projector via vga cable
If your tablet has a VGA connection which I doubt, you'd just connect the two devices with a VGA Cable. Otherwise you'll need some type of adapter to go between the two devices to make them communicate. Good Luck!!! If you had purchased a normal laptop, you'd have a VGA connection.
Apr 23, 2012 | Acer Iconia Tab A50010S32u Notebook
Won't power up at all
There is a chance that it is fuse protected inside.
When a filament-equipped lamp fails, it can create a momentary surge; you've probably seen this when a standard tungsten bulb flashes very bright in the process of dying completely.
If you no longer have the User Guide, you can download it here:
http://safemanuals.com/user-guide-instructions-owner-manual/ACER/PD120-_E
It may contain information about any fuse it uses.
Aug 25, 2008 | Acer PD120D Multimedia Projector
Acer travelmate C110 & Acer projector X11602
Hi Andrew,
you can try changing the output of the travelmate, to VGA Or External Device.
ensure you have the correct output lead from computer to projecter. Then on your keyboard you should have a button that changes the output. i.e numerical 5-6-7 or 8. usually says LCD/VGA et,c.
failing this try altering the output in the systems bios setup.
you can enter this by pressing F2 Or esc at bootup.
if your unsure, and none of this helps, i,d suggest visiting acers site. and downloading the user manual(s)
Mike @ Compurepair.
May 22, 2008 | Acer TravelMate C110 Tablet PC
Connecting to various Media projectors
Bruce,
Once you get a given projector to work with your unit, establish a user profile or a hardware profile that will include that device.
Do the same with your other clients and you should be able to store the info under different profiles.
You might name each profile by company name.
Best of Luck
Blaino
Mar 17, 2008 | Tablets & eReaders
Acer projector
My Acer PD125projector was working perfectly but has been out of use for 6 months. When I connect it now, I get:- 1. "ACER - Empowering People" screen, then 2. After a short delay the message "The Lamp is approaching the end of its useful life at full power ........." is displayed for a short time, then 3. The initial screen returns, together with a "No Signal" message. After this warm up none of the controls on the actual machine nor the the remote controller, except for the power button, will do anything. What can I do about this?
Dec 06, 2007 | Acer PH110 Multimedia Projector
Mitsubishi Xl1xu/sl2u Lcd Projector User Manual 268 Logo
116 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
