Question about Craftsman 12 x 80" Band Saw Blade 6 tpi Regular Tooth
I have Sears- Craftsman 10" band saw #113.244510. after installing new tire the blade tracks to the rear. Have followed manual but cannot solve proble- any suggestions?
    Sergeant:
  • 468 Answers
Check this blog first. Are you installing a new blade? If the blade is running backwards, you just have to reverse it, turn inside out. Try watching the Alex Snodgrass' Youtube video Band Saw Tune Up .
Posted on Oct 17, 2013
5 Suggested Answers
  • 2692 Answers
SOURCE: Band Saw Blade won't stay on
A lot of the larger band saws, and I don't know about your particular model, has an ajustment on the bottom wheel that tilts the wheel in order to track the blade. It is right at the axle and tilts it from there.  If the back guide is a roller bearing I woud think you would want to roll all of the time.  If a solid bearing block natually a small space where it  will not hit is enough.
Posted on Jan 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: I have a 12 inch Sears/Craftsman band saw. I got
that is where I would look first, you would need your model number and go to Searspartsdirect.com and type in your model number to find and order the replacement rubber tires and that should take care of your problem
Posted on Dec 17, 2009
FixYaSteve
  • 57 Answers
SOURCE: I have a 12" Sears - Craftsman - Band Saw and the
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Posted on Jun 14, 2010
Testimonial: "Very helpful. My problem is that I have moved, I'm 90 years old and I can't find my manual. But thanks. I'll keep working on it. Foster Williams"
  • 32 Answers
SOURCE: My band saw (craftsman 12" tilt head) stopped
Hello'
I have the exact same saw. It sounds like the key stock came out of the pulley attached to the lower wheel. I will give you a quick rundown.
-unplug saw
-you will have to lay the saw on its side so you can remove the motor and drive belt.
-there are 2 seperate pulleys , the one connected to the motor and the one connected to the bottom wheel.
-loosen motor nuts and remove motor, pay close attention when removing motor 3 of the 4 studs have sleeve like spacers.
-once motor and belt are out of the way check the pulley on the bottom wheel,my guess is that the key stock came out and the pulley spins freely.
-loosen set screw,replace keystock and tighten.
-NOTE the keystock may have came out of the motor pully instead,check.
Now this next part is real important.
-once you get it figured out and are ready to put everything back together the 2 pulleys must be perfectly lined up, use a flat ruler, using your eye will not work.line the drive pulley up with the lower pulley. ( the pulley on the motor has a shoulder on it so when it is pushed towards motor it will be set in the right spot) .
It is either the pulley on the motor or the wheel that has lost its keystock.
It should be a easy fix,Good luck
Posted on Nov 15, 2010
Get a 12 "Sears craftsman band saw blade model no 113.279521c
I'm using Haltbar band saw blades that I got from sawblade.com . They have great quality band saw blades. I ordered 10 blades from them last month and shipping was free.
Oct 18, 2014 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
How do I adjust the blade to stay on?
Many times this is caused by worn beearings or a worn rubber "tire" on the idler or drive wheel.
Aug 13, 2014 | Saws
Manual for 1.3 hp Craftsman band saw
The blade length of the saw is 70.5" . You can get custom length blades on www.sawblade.com . You may visit sears site to get manual for that saw.
Jul 26, 2013 | Craftsman 1/3 hp 3.5 amp 10" Band Saw...
Sears manual model103.24550
Check this informative article about installing band saw blade . However, I am in doubt if that article could really help you in properly replacing the blade. But you may use it as your reference. I can refer you also to sears support site or to vintagemachinery . I am not sure how old your band saw is , you may also visit owwm.org or make posts on different forum sites. If you have questions, you can post your comment to this thread.
May 06, 2013 | Craftsman 12 Tilt Head Band Saw Owner...
My Craftsman Bandsaw's (Model 113.243310) tension wheel is bouncing the blade off every time I turn it on. Any suggestions?
Please be sure that your put correct tension on the blade. Check the blade guides and check if the blade is tracking
properly. Make sure the tires are clean. If they're well worn out, change them . You may try to install new blades too.
Feb 18, 2013 | Craftsman 113.243300 & 113.243311 12" Band...
I have a 1945 chraftsman 12" band saw W/O manual
fooksia2774-
You absolutely need tires on both wheels. This will allow the blade to track smoothly and save premature wear of the blade, not to mention make the saw run much more quietly.
Hope this helps.
Regards,
DIYpro
May 01, 2011 | Craftsman Saws
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
I have a Craftsman 10 inch band saw. The blade keeps coming off. I can't find my manual. How do I adjust the alignment on it?
the blade tension shaft in the rear top of the saw should also have a tracking adjustment knob that tilts the top wheel. Open the top guard and spin the top wheel by hand and adjust the tracking knob until the blade atays on. Better unplug the saw until you get this done, then you can power the saw back up and fine tune the tracking while running until it is perfect. hope this helps you.
Oct 17, 2009 | Saws
Blade is walking off the tire.
There should be a tilt adjustment on the TOP wheel, this is what adjusts the tracking (centering of the blade) on the wheels. Watch the tension adjustment too, not enough will allow the blade to walk off
Mar 30, 2009 | Saws
I have a craftsman band saw model 113.244580. I can not find the service manual/owners manual. I can not get the blade to track properly
Go to SEARS PARTS DIRECT.COM and type in your model number and you can view a manual or get one.
Dec 15, 2008 | Saws
Craftsman 12 x 80" Band Saw Blade 6 tpi Regular Tooth Logo
451 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
