Question about Aurora Electronics AS1219CD (CrossCut) Shredder
Is there a way to remove the grey piece(credit cart part) from the Shredder (Aurora AS1219CD)?
    Top Expert:
  • Aurora Elect... Master
  • 36,514 Answers
You can remove power to gain access to the shredder mechanism. You may be able to pick out the remains of the credit card. Shredders, even "heavy duty" ones do not do well with credit cards and other plastic material.
Posted on Oct 17, 2013
Where is the switch that allows you to shred on the aurora as501-ms shredder
Shredding may start automatically when a piece of paper is sensed in the slot.
May 06, 2016 | Shredder Office Equipment & Supplies
How do you clean the "eye" on the Aurora AS1219CD? I heard that may be the problem with it not taking paper. But I am not sure how to go about it.
the best way is to take a q-tip and alcohol and rub the eye if you are facing the shredder it should be on the front but that is th only way we have to do it
Oct 17, 2013 | Aurora Electronics AS1219CD (CrossCut)...
Aurora paper shredder model AU1050XA
Stan Chandler:
First, unplug the shredder. Remove the shredder head from the basket and turn it upside down. You will see the screws on the bottom side of the shredder head.
Feb 23, 2013 | Aurora Electronics Office Equipment &...
I can not get the bin out of the shredder, i believe it is off track and completly full with shreds coming out. I want to know can I take it apart somehow and fix it myself (You know the screws on the...
Dont wont to do if shredder is under warranty. If not, you will usually see a sticker staying that if you remove this sticker you warranty is voided. There is a screw that holds the top on. If you take the sticker off your warrranty is voided so beware.
Apr 14, 2011 | Aurora Electronics AS1219CD (CrossCut)...
My shredder is jamed.
Take the shredder off of its bin, turn upside down, make sure it is unplugged, and pull any pieces of shredded paper out of the shredder teeth, If the reverse mode did not unjam it then you might try opening it, by the inside of the shredder, and unjamming it that way, may I add that there is a sticker covering one of the screw holes that will say "if removed warranty is not good anymore".
Aug 11, 2010 | Aurora Electronics AS662C Shredder
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
JAMMED SHREDDER
if you have reverse, run reverse.
if you don't have reverse, you will have to disassemble the drive shaft/cutters and clear manually
Apr 05, 2010 | Aurora Electronics AS662C Shredder
Jammed shredder
try shredding a old card, carefully but forcibly push the jammed plastic strip through the teeth.
might be faulty alignment of teeth, a factory defect!
May 07, 2008 | Aurora Electronics AS882C (Cross-Cut)...
Aurora AS662C paper shredder
I had the same problem. I found that the shredder was not placed squarely on the basket. There is a small switch under the rim of the shredder (mine is on the back side) that gets depressed when the shredder is placed on the basket. If this switch is not depressed, the shredder will not work.
Make sure the shredder is fully seated on the basket.
Hope this helps!
Mar 19, 2008 | Aurora Electronics AS-650C Cross-cut...
Aurora Electronics AS1219CD (CrossCut) Shredder Logo
87 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
Jim Keysor
ka4iup
ka4iup
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
