Question about Fellowes Shredmate Shredder
My shedder wont shedded
The cutter won't turn in either reverse of forward. there is power and a low humming noise when the paper is entered into the machine. I have cleared and paper jams and tried turning or the power but it does not slove my problem. Can you help
  • 3 more comments
  • Anonymous Dec 06, 2007
    I need to purchase one of the drive gears for my shredmate. Where can they be purchased?
  • Anonymous Nov 22, 2008
    I have cleared a paper jam and it is not working correctly. What steps are needed to correct the problem?
  • Anonymous Mar 17, 2014
    motor just hums but locks upp both forward and back when not turned on everything turns free no paper jam
  • Anonymous Mar 28, 2014
    I was using it to clear files before my move. When it has gotten hot it will shut-down and that is OKAY,happened many times and I am not surprised. After cooling period it will power up and run in reverse; however when trying to go forward, the motor doesn't power up and no wheels are moving. Nothing going forward, A-ok going in reverse.
    Novelist:
    Champion:
  • 254 Answers
It could be you have a broken or stripped gear. If you can disassemble the rig and look at the drive mechanim, this should tell you what is happening. Availability of parts would be questionable. check the motor- is it turning, or are the bearings dried out and sticking? Check the mechanim for freedom of movement.
Posted on Sep 26, 2007
How do i clear jammed cutter blades
Does the shredder have a reverse button ?
If it has, just switch between reverse and forward a couple of times.
If that does not work it may have to be dismantled and the cutters turned by hand as you pull the paper out. Disconnect the power first though.
Dec 17, 2014 | Office Equipment & Supplies
HOW DO I UNJAM SB 99C SHEDDER
Try spraying some WD40 into the cutting blades then turn it on to forward it may unjam itself.
Aug 25, 2014 | Fellowes SB-99Ci Shredder
TAPPING NOISE, NOW IT WON'T GO INTO GEAR WITHOUT LOUD GRINDING NOISE AND ACTS LIKE TRANSMISSION WON'T ENGAGE TO DRIVE
If it is an automatic transmission, first check the fluid level. If it is low, fill it up and try it again. If the level is fine, then there is a bigger issue and you should seek a professional's help.
Jun 18, 2017 | 1996 Buick Century
Shredder won't stop running
THERE MAY BE SOME PAPER SHREDS BLOCKING THE LASER LIGHT.
UNPLUG SHEDDER AND CLEAN CUTTER HEADS.
Sep 30, 2011 | Office Depot Ativa DQ60M Shredder
Shreds in reverse only
I think there is a shredded buildup on the bottom. Unlpug the device ... turn it over and clear out the residue you will find there.
Sometimes I find the addition of shredder oil during the shredding process helps to eliminate this problem. Get the oil where shredders are sold.
May 31, 2010 | Tech Solution TS-4500 Shredder
Motor and cutter do not rotate - strip cut model
Soak the clog with dishwashing detergent and a little bit of water overnight. This should dissolve the paper.
Jan 07, 2010 | Fellowes Manufacturing C220 (Strip-Cut)...
Runs continuously when in the on position.
there is paper jammed in front of the sensor. it was likely caused by feeding too much paper into the shedder at one time and now a chunk of shedded paper bits it blocking the sensor from seeing that the shedder is clear
Dec 18, 2009 | Fellowes DM8C Cross-Cut Shredder
The paper is stuck in the shedder and now it will not turn on/off
Try reverse, forward, reverse a few times. If thet doesn't work, unplug it, turn the shredding unit off and pick out whatever paper you can see, both top and bottom. Watch your fingers, the cutters are sharp.
Aug 10, 2009 | Fellowes DM8C Cross-Cut Shredder
Blades rotate twice but stop-motor continues to run, both forward & reverse mode its the same. Have tried to oil, unblock, run forward & back but to no avail. Can anyone help
Is the motor just humming after the 2 rotations? If you are over oiling the unit, tha shreds will soak up the oil and start sticking to the blades and begin growing a paper tumot in side the cutter shroud, whish in turn will start to slow down and jam the cutter asm and motor. Best to take apart and thoroughly clean.
Jun 01, 2009 | Office Equipment & Supplies
Royal orca wont forward will reverse shredd.
May have paper bits jammed above fixed curved metal surface that spiral cutter slices against.  Need to spend time removing built up material with stiff wire or flat tool.
May 04, 2008 | Office Equipment & Supplies
Fellowes Shredmate Shredder Logo
444 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
