Question about Canon lc-710 - Laserclass 710 Super G3 Fax Machine
Getting error e354. What is it? - Canon lc-710 - Laserclass 710 Super G3 Fax Machine
    Master:
  • 552 Answers
Sounds like a pcb h/w problem - can u say expensive to repair?
Posted on Oct 20, 2013
Sony Walkman nwz-E354 water damage how do i fix it Droped it into the water
hairdryer and rice time
open as much as possible removing screws and making sure to remember how goes back together.
dry as best as possible with hairdryer without getting too hot
and bury in rice over night before putting back together
shake out and blow off again to make sure no rice stuck in device before putting it back together.
Nov 15, 2016 | Sony Walkman Nwz-e354 Black Digital Media...
Error E 354
Description
System error
Remedy
Contact to the sales companies.
Apr 01, 2014 | Canon imageRUNNER 1023iF Black and White...
E354 error
sounds like a pcb h/w problem - can u say expensive to repair?
Oct 17, 2013 | Canon Office Equipment & Supplies
E354 MANUAL
You may download the manual and more here.
Dec 16, 2011 | Sony Audio Players & Recorders
Hoo.comi want to solve the problem in my copier canon ir 2016, error code e354
this is error code that isn't stated in service manual and doesn't have description. When this error occures the procedure is to report to Canon service center. The same errors were on ir1600/2000 series, but without some good explanations.
So, call authorised CANON service partner!
Sep 13, 2011 | Canon iR 2016i Black and White Copier
Error E354-0002 ir 8500
Error E354 in Canon iR 2016
error e354 code appear when you replace PCB controller board.
Please note. Before replace your PCB board with other one.
Pull out a small (FRAM COUNTER) chip from your old PCB board you can found it right side of the PCB board near a battery cell the chip attached with screw open screw and pull it out and attached it with your new PCB board .install your PCB board in the machine and turn on power error e354 will go off.
Aug 27, 2011 | Canon imageRUNNER 8500 Copier
Error 354
E354
•When turning ON the power, inconsistency of the serial No. of
the serial number PCB and that of the controller PCB
(SRAM)/counter memory is detected.
•When turning ON the power, it is detected that no serial
numbers are assigned to the serial number PCB and the
controller PCB (SRAM)/ counter memory , if you are try to change the counter pcb to get rid of high meter reading this error is possible, this a security measure of canon to prevent meter tampering
Jul 15, 2009 | Canon Office Equipment & Supplies
SYSTEM ERROR 354
That code generally shows up when the main board id does not match up with the other controller boards. They cannot be interchanged between machines. They write to each other to check id's You will most likely have to replace all the primary boards, VERY costly.
Apr 18, 2009 | Office Equipment & Supplies
Canon IR 2016 en occassion
voir ce site : http://www.ots45.ru/support/canon_2016_2020_codes.html
Jan 06, 2009 | Kyocera KM-1505 Copier
Error E354 in copier ir2016
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Mar 26, 2008 | Kyocera KM-1505 Copier
Canon lc-710 - Laserclass 710 Super G3 Fax Machine Logo
90 people viewed this question
old marine
old marine
