Loading of paper roll-I need instructions - Office Equipment & Supplies
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
What make and model printer/copier?
Posted on Oct 17, 2013
Flashing paper and power buttons
This error means jammed paper or a foreign object is blocking print head movement. Turn off the printer, press the adjust lever down to the lowest position, and pull out the jammed paper. Open the cover and remove any jammed or torn paper, or foreign objects. Then do one of the following:
Sheet Feeder: Return the adjust lever to the position. Turn on the printer, reload paper, and press the paper button.
Manual Feed Slot: See page 15 of your manual for loading instructions.
Roll Paper: Cut off the printed portion with scissors, then remove and reload the roll paper
Mar 08, 2014 | Unknown Epson Stylus Photo R2000 Ink Jet...
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
My HP1050c will print with the paper feed option fine, but when you try to load the roll feeder the rollers continue to roll backwards like it can't detect the end of the paper roll to size it. It seems...
I ran into this problem once on a Designjet 110 series and it turns out that there is indeed faulty sensors that cause this issue. Unfortunatley it required the replacement of one sensor that detects the start of a page. I checked HP and this issue is not noted for the 1050, but that only means it is not likely a common issue.Post a comment if you would like additional instructions on how to diagnose.
Mar 18, 2011 | HP DesignJet 1050c plus InkJet Printer
Canon Faxphone 15 user's manual
Plug the power cord it into the wall socket. Plug in the phone wire. There is an On/Off switch on the back. You will need some thermo-paper that comes in a roll, a roll like toilet paper, thinner than regular paper. The instruction of how to load it is on the top paper cover. Good luck
Aug 22, 2009 | Canon Office Equipment & Supplies
Reload Paper constantly shows up
This printer is very finicky about paper loading. I see this error most commonly when using auto-cut roll paper. If the paper edge is not cut perfectly straight, and it is not inserted into the printer perfectly strait, it will give you an error. When it does this, you can simply load the paper and press "cut" instead of "pause" when it says "press pause" and it will cut the paper straight. You can also set it to "Roll Paper Manual Cut" and load the paper, then set it back to "Roll Paper Auto Cut."
Jun 30, 2009 | Epson Stylus Pro 10000 InkJet Printer
Printer paper loading
Just achieved, after trying for 2 days
Paper should drape over like toilet paper.
Cut sides to form a point in the middle.
Feed through back of machine. Paper will have a tendency to point upwards.
Guide though metal roller, then hit feed........should go through.
May 12, 2009 | Canon P1-DHV Calculator
Loading label roll into Zebra tlp2824-z printer
If you are using thermal paper and don't have to use ribbon, you will only need to spread apart the roll holsters and place the roll in there, At the front of the printer, next to the printhead and the pressure roll you will find two paper guides which you can spread apart (depending on the exact model by muving them with the fingers or by turning a wheel in the right hand side of the pressure roll. feed the paper through them guides and close the printer.
Ensure that the printing surface is at the top.
Jan 20, 2009 | Zebra LP 2824 (clp2)
Loading paper
Follow the illustrated instructions on the first page of this manual.
Jul 18, 2008 | Sharp EL-1197PIII Calculator
How to load paper
Just put the thermal paper(paper roll) inside the machine and the SHINNY side of that thermal paper would be on the Top side where the thermal unit is place or vice versa.
Dec 30, 2007 | Sharp UX 108 Roll paper Thermal Fax
13 people viewed this question
jasbo
jasbo
