Question about Canon Office Equipment & Supplies
E354 error Fax machine is giving me a system error e354 at power on. Can't find this error in manual to see what it is. What is it?
    Master:
  • 552 Answers
Sounds like a pcb h/w problem - can u say expensive to repair?
Posted on Oct 20, 2013
3 Suggested Answers
  • 272 Answers
SOURCE: MACHINE GIVE ERROR CODE 5100?
I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100. Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on May 30, 2009
  • 5 Answers
SOURCE: brother fax machine 420cn giving an out of memory
pls reset ur machine.MENU*2864-01.
Posted on Sep 26, 2009
Mfc-7840w /Cc3 205 03031f04
Your fax machine can work independently from your operating system. Print the document and try to manually fax from the fax machine. See if there is an error message on the fax when you try. Then if it doesn't work , post the new error from the fax machine.
May 23, 2014 | Computers & Internet
Error E 354
Description
System error
Remedy
Contact to the sales companies.
Apr 01, 2014 | Canon imageRUNNER 1023iF Black and White...
Getting error e354. What is it?
sounds like a pcb h/w problem - can u say expensive to repair?
Oct 17, 2013 | Canon lc-710 - Laserclass 710 Super G3 Fax...
Error E354-0002 ir 8500
Error E354 in Canon iR 2016
error e354 code appear when you replace PCB controller board.
Please note. Before replace your PCB board with other one.
Pull out a small (FRAM COUNTER) chip from your old PCB board you can found it right side of the PCB board near a battery cell the chip attached with screw open screw and pull it out and attached it with your new PCB board .install your PCB board in the machine and turn on power error e354 will go off.
Aug 27, 2011 | Canon imageRUNNER 8500 Copier
Error code 117-363 printer starts machine is awake
only see error code 117-363 and not permited other option
Nov 26, 2009 | Xerox 6180MFP/N Printer
Error 354
E354
•When turning ON the power, inconsistency of the serial No. of
the serial number PCB and that of the controller PCB
(SRAM)/counter memory is detected.
•When turning ON the power, it is detected that no serial
numbers are assigned to the serial number PCB and the
controller PCB (SRAM)/ counter memory , if you are try to change the counter pcb to get rid of high meter reading this error is possible, this a security measure of canon to prevent meter tampering
Jul 15, 2009 | Canon Office Equipment & Supplies
SYSTEM ERROR 354
That code generally shows up when the main board id does not match up with the other controller boards. They cannot be interchanged between machines. They write to each other to check id's You will most likely have to replace all the primary boards, VERY costly.
Apr 18, 2009 | Office Equipment & Supplies
Canon ir 2016 copier on display says ( Download Standby) thanks
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Apr 18, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
Error E354 in copier ir2016
Mar 26, 2008 | Kyocera KM-1505 Copier
80 people viewed this question
old marine
old marine
